london travel cards
12 Jun 2007
By The Track
Im hopeless if im honest at these things and knew someone here could help.
My brother is going to be travelling from oakham to Londons o2 arena on the 18th of this month now the bit to london is easy but does a travel card cover him to north grenwich as im not sure. Also i have an oyster card could he use that to get there?
Also whats the cost if he uses oyster? so i know how much he needs on it
MCR247
7 Nov 2008
He can use the oyster or a travelcard, he'll need to go from Kings Cross St Pancras - London Bridge then the Jubilee to North Greenwich :)
RJ
25 Jun 2005
Back office
Yes, North Greenwich is in Travelcard Zone 3. If he's there for just the day I'd suggest he purchases a Zone 1 - 4 Travelcard (because Off Peak rates are available with a 1 - 4 but not a 1 - 3), or consider purchasing an Oakham Travelcard ticket.
MikeWh
15 Jun 2010
Crayford
It is, but it's also in zone 2. As long as you travel from the Central London direction and not from the Stratford direction then you only need a zone 1 and 2 travelcard. If he's only making the one return journey then is it possible to buy an Oakham to Underground zone 1 and 2 return? If not the oyster option is £1.80 each way off peak so you'd need £3.60. My hesitation over the oyster option is that (assuming he's off to a show/concert/event) there's a high chance of failing to touch in properly at North Greenwich on the way home.
222007
12 Jun 2007
By The Track
Guys thank you so much for your help he's already got his tickets to london so i'll give him the options :)
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
I have just realized that he can't use your Oyster if it has staff travel privilege's loaded on to it. ;)
222007
12 Jun 2007
By The Track
No it doesnt. I wasnt aware you could get PRIV rate oyster? I've had the oyster card since about 2005 and rarely used it TBH but does come in handy every now n then
