London area Track gradient heights
DoctorApple
24 Jul 2016
From the people that play Train Simulator (By DTG) I am sure you know the Route London to Brighton...
I have started another route; around the general London area. I own Gradients of the British Mainline Railways, by Ian Allan.
A lot of great routes, except for some lines that are missing; and yes I know the book is base around the 1960s.
Anyway question is: (sorry about that) I cannot seem to find gradient heights for London Waterloo to Reading, Clapham Junction to Willesden Junction, Guildford to Surbiton, Alton area and Chessington area.
I have tried looking online again. I must of not done well, as I don't know any good train info sites.
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
Have you tried the Freedom of Information system, I know it has worked for a friend in the past, the government may well have the information at the ready.
John Webb
5 Jun 2010
St Albans
The Ian Allan book is a reprint of earlier editions by The Railway Magazine in 1936 and 1947.
Part of the Reading/Waterloo line is covered by S15 at least to Wokingham, but the direct route via Bracknell isn't covered.
The West London line (Clapham Jun-Willesden) isn't in these diagrams.
S1 gives you Waterloo - Woking, so includes Surbiton, S6 takes you from Woking to Guilford. but not the direct route via Oxshott and Effingham.
Alton and Chessington aren't in these diagrams either. Possible the Mid-Hants Line may have a gradient map of their line west of Alton?
You might be able to use 1:25,000 OS maps and their contours to deduce possible gradients?
Many years ago I was making my first trip to the West Country on a family holiday - I was in my early teens - and wrote to BR at Paddington asking for information. I was invited up to a Paddington drawing office and spent a happy couple of hours copying their gradient diagram! Two years later I got a copy of the 1947 edition of the Gradient Diagrams.
John Webb
AM9
13 May 2014
St Albans
You can actually plot the path of a line on Google maps and then look at the elevation profile from which the gradients can be calculated.
DoctorApple
24 Jul 2016
I actually did something like that before with DEMs and Google Maps over lay, turns out they were very wrong, until I found that book.
daikilo
2 Feb 2010
Try Network Rail, they must have the data and hopefully in a form from which they can extract a ownload for you. They may even be obligated to do so.
Perhaps if people need it so badly, and for such an important reason, they should pay for it.
DoctorApple
24 Jul 2016
I am pretty sure I tried something like that before, they never got back to me.
Normal source of gradients are 5 mile diagrams (3rd party owned and NR can't give them out) or signalling diagram, which again are unlikely to be given out from a FoI request..
Ploughman
15 Jan 2010
Near where the 3 ridings meet
I read in the NERA's book on NE Region gradients, that as a surveyor working for BR he was tasked with checking gradients in the NE Area.
Even allowing for previous renewals, subsidence and a number of other factors, he could not match any gradient values.
Profiles should only be taken as a guide not as a fact.
As an example, I surveyed a section of the NYMR for a renewal between Goathland and Beck Hole.
The stated gradient is well known as being 1 - 49.
In reality it varied from 1 - 60 to a minimum of 1 - 20 for a length of approx 30 metres.
That spot just happened to be where any train that was going to stall did stall.
The renewal cured that one.
rebmcr
15 Nov 2011
St Neots
Perhaps the best solution for the OP is to use a professional-grade GPS/barometer unit that can display accurate altitude measurements, and gather the information manually?
daikilo
2 Feb 2010
I imagine that if the paper documents are now owned by a private company it is because NR have a digital database for everyday use. This is why I suggested asking for a down-load of the data you need. I am pretty sure that this data is used to calculate the performance of different train formations for scheduling purposes (at least it used to be 40+ years ago).
Gradients for modelling systems that we use are taken off what Ive said. What AEA in Derby used is lost in distant memory I suspect.
One day we will put info in places that its readily available and easy to get to, I doubt very few know this exists, first Ive seen of it.
Don't think that would work from a moving train as accurate survey equipment tends to take a little while to work. Getting safely to track level at frequent intervals would also be tricky.
I shared an office with them for a while and remember the leather-bound books of profiles including no doubt lots of routes long disused, but the probably went into a skip along with most of AEA (including the people...).
The modern equivalent would be Railsys - I believe Network Rail holds models of its entire network from which gradients could be extracted, but you'd need a good reason or to pay to get hold of it.
Railsys is fed from 5 mile diagrams and signalling diagrams and has gaps in it. A licence is the best part of 10k too.
I've just done the training course this week! Someone with access to the software and a model of the relevant area could export the gradient data as a spreadsheet.
DoctorApple
24 Jul 2016
You assume the models are half decent!
