LNER announce CAF fleet (Class 897)
Kite159
27 Jan 2014
West of Andover
I guess the proof will be in the pudding (as they say) when the first 897 enters service. To see if CAF have improved on the ride quality and what the seats are like in both standard & first class. Although seats can be very subjective depending on the person.
But at least long distance services out of Kings Cross won't be all fully Hitachi (considering Grand Central are getting Hitachi units as 180 replacements)
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
Why is it worrying?
It's "worrying" in the sense that more than 2 years after the 897 order was placed, basic traction information still hasn't been provided by London North Eastern Railway / LNER (except for @hwl very kindly since telling me that their diesel engines will be MTU 1600s, the same basic type as the 800s).
By comparison, in July 2017, around the time that the 195 and 331 order was placed, Northern posted on their website that the 195s would use MTU engines and ZF transmissions (suggesting MTU 1800 and 6-speed Ecomat/EcoLife) and that the 331s would use ABB transformers and CAF traction packages (although the inclusion of TSA traction motors in the CAF traction packages wasn't mentioned).
Everybody who needs to know will know.
Yes, but maybe there are people who don't need to know but would like to know, you know? :) Also, as Northern did provide basic traction information in their 195/331 press release, I'm not sure what's stopping LNER from providing the equivalent information in their 897 press releases.
You don't need a press release telling everyone what engine is being used because passengers won't care.
I actually did sort-of imply that, in making an admission/acknowledgement (bold):
So, more than 2 years after we got exterior renders of the 897s, we now have interior mockups of them, but there still seems to be a worrying lack of information about (admittedly, not so "customer facing") the traction of these units.
That didn't stop Northern from providing basic traction information in their press release!
Ah yes, because all passengers have no interest in that :)
Not necessarily, if they only planned to run on diesel between Leeds & Harrogate, Doncaster & Hull etc where the line speed isn't 125mph.
Why so? Everywhere they're likely to operate on diesel the line speed will probably 100mph at best. You're not getting above 100mph going to Harrogate, Hull, Lincoln or Middlesbrough. None of the diversionary routes like the Tyne Valley, Durham Coast or the Joint Line are going to be going over 100mph. Maybe a few stretches north of Edinburgh where you get 110mph? But I could be imagining that, either way it would only be very short stretches.
There aren't any of those either, so there isn't any need for the 897 to be capable of doing more than 100 mph on diesel. I don't know what was actually specified though!
Wrong, the speeds they need to do on the non electrified branches off the ECML are all sub 100mph and often much lower (Harrogate is 65mph max)
There is little point in them having high diesel hp because nearly all their routes have much lower speeds off the wires (typically 65-90mph, few miles at 100mph).
Ah thanks all, and apologies for my lack of familiarity with the speeds, being based in Wales!
70 mph requirement on diesel in the spec, but doesn't mean the 897 won't actually be designed/capable for more, just that's what is required of it.
Wow, that low in the spec though, still!
Wrong, the speeds they need to do on the non electrified branches off the ECML are all sub 100mph and often much lower (Harrogate is 65mph max), hence installed diesel power can be much lower than 80x, because it doesn't need it be as high. This enable both capex and opex to be reduced though having fewer engines.
MTU 1600
Many thanks - do you know how many of them per unit, and what power output they'll be set to? Now I can't wait to hear the combination of "800" diesel engines with (presumably) "397" traction motors :lol:
I hadn't seen the "fewer engines" part when I first read your reply. So you're saying that this 10-car unit may well have fewer than 5 MTU 1600 engines - 4, or even 3?
If you want to know, put a Freedom of Information Act request in. Unless it's commercial in confidence due to things not being signed yet, they will just tell you.
I would agree that baffling "normals" by telling them what engines are in it is not necessary. The difference from other TOCs is just that LNER have a pretty well oiled PR machine whereas when the likes of Northern have been talking about new fleets they've just got technical directors and the likes talking about them, not PR bods, and technical directors love talking about, well, technical things like the precise specification. Normal passengers don't care about the precise specification, they care that it's got enough seats, that they aren't like sitting on a metal bar, that there are enough toilets etc.
GRALISTAIR
11 Apr 2012
Preston Lancs
I would agree that baffling "normals" by telling them what engines are in it is not necessary. ———- Normal passengers don't care about the precise specification, they care that it's got enough seats, that they aren't like sitting on a metal bar, that there are enough toilets etc.
Exactly!
tfw756rider
30 Nov 2024
Oh I totally get you both.
@Bletchleyite To be fair, yes, I could make a Freedom of Information request. Thanks for that suggestion (although maybe @hwl would be up for providing information on the quantity per unit of MTU 1600 engines and their power ratings), and for the explanation on London North Eastern Railway and Northern taking different approaches.
AM9
13 May 2014
St Albans
Patience is a virtue. When it is appropriate, the information will be released.
tfw756rider
30 Nov 2024
Ah, so be grateful for "MTU 1600" and "fewer engines on a 10-car 897 than on a 9-car 800" and don't expect anything more for now - yeah, fair enough :)
FrontSideBus
11 Feb 2025
I still think that excuses for poor seating being blamed on fire and crash regulations is a load of rubbish.
I bet commercial airliners have more stringent of both regulations and they manage to get quite comfortable seating that people sit on for 10+ hours. Doing only one or two on some of these modern train seats is bad enough!
800001
24 Oct 2015
Wasn't the 'excuse' actually down to someone misinterpreting the rules and regulations with regard to what was allowed?
I'm sure I've heard/read that before but can not remember where.
Goldfish62
14 Feb 2010
Plus it's odd to me how different the supposed regulations are to mainland Europe, where you can still routinely travel on new trains with comfortable, sometimes extremely comfortable, seating, plus silly smooth ride quality.
GoneSouth
17 Dec 2018
That is a matter of personal taste. You might like it, others will not. Leather done badly does look quite cheap, tacky and uninviting. The first class colour scheme in the pictures does look a little garish.
Yes, leather can look a bit like something from the 1970s :D
Sorcerer
20 May 2022
Although I'm not the biggest fan of the LNER livery, I think it looks a little bit better here than on the 800/801s. I wonder if they'll keep the yellow front for fleet uniformity or if they'll go with black like the 397s.
Russel
30 Jun 2022
Lichfield
Are these still being delivered in LNER livery though?
Sorcerer
20 May 2022
Possibly not given that GBR is coming within the next few years, and it's not unknown for initial concept art to be different from the final design. Eurostar's 374 fleet was originally mocked up in the original white livery before the fleet was actually delivered in the rebranded blue.
Capex = capital expenditure (purchase of the engines)
Opex = operating expenditure (servicing and fuelling of the engines)
With the context that "purchase" in TOC terms means leasing charges which will be Opex to them, not Capex (the Rosco, or lender, bears the capital cost).
There might well be capital needed for depot expansion or infrastructure changes - Network Rail will pick up that cost (as Capex) and add it to the TOC access charges as long-term Opex.
Either way, the DfT has to authorise the extra spend.
Sorcerer
20 May 2022
I wonder whether any will actually be built before LNER is eventually subsumed into GBR.
Apparently the planned introduction for these trains is 2028, so they could very well be the first fleet introduced under the Great British Railways brand from the start rather than being units rebranded from a previous livery. This despite the fact it's interior is still very much of the LNER colour scheme. Easily the most confusing thing about the rebranding will be the lack of consistently coloured seating even if the 897 interiors are changed during construction.
BR never had consistently coloured seating across fleets. It was a proper hotch potch. It's only Network SouthEast that got close.
Goldfish62
14 Feb 2010
Maybe GBR will decide that the interior colour scheme becomes the default long-distance scheme (shades of the red InterCity scheme), although some fragile egos will no doubt shout and scream that the interior should be covered in flags. ;)
Blaine
3 May 2023
Surely the doors between First and Standard will be frosted in the final version... though I wish the screens could be smaller / switch off at times, as there's often more than an hour between stops.
Gaz55
27 Mar 2020
Doncaster
Are those USB-A ports at the table seats in standard?. If they are, it seems a slight retrograde step when USB-C ports are being introduced to other fleet's currently being refurbished.
hexagon789
2 Sep 2016
The release states:
As with the LNER Azuma trains, each seat will have its own plug socket, along with the introduction of USB-C ports for phone charging. At table seats, sockets and USB-C ports will feature in a power bar on the tabletop.
Kite159
27 Jan 2014
West of Andover
At least EMR had the best way when it came to dealing with USB sockets by including both USB-C & the older type, at least on the table seats of a 170. Give the passengers the option
