Tottenham Flyer
Ex London Midland 321 426 on it's way from Doncaster to Ilford in NXEA livery.
I dont think its in service. 321 426 still hasn't been seen in service yet, and thats been back a while now! The only ex LM 321's NXEA appear to be using are 421, 422 and 423.
321421/422/423 are in regular use. 425/426 have worked at least once, but arn't used normally. Only know they worked because they failed and it got mentioned!! 427 has not seen use AFAIK, it and 426 were both on IL today.
To sum up the NXEA situation, 321313/316/318 and 317890 are all shown as undergoing C6X attention which means a repaint. There also appears to be a 357 on IL being repainted, not sure if this is still 357044 mentioned as there in late August?
I did put a message on my post which said I'd incorrectly put 321315 as going to Doncaster.
There are so many roumers flying round about 511, but this was taken out of service due to an arson attack. 3 coaches were damaged, but I believe have been repaired, but since this train has been robbed of lots of parts. 317 502 was also set on fire at Hertford East, but only one coach was damaged, so the one good coach of 511 was put onto 502, hence 502 is still in service.
Although out of sevice, it does still receive the mods that all the other 317's have, ie its been stripped of its 'one' livery, and has had cab air con mods. Heres hoping that it does return to service.
Is NXEA 321315 still not yet sent away to Doncaster?
