Lines with significant counter peak flows
telstarbox
23 Jul 2010
Wennington Crossovers
Which lines have the most significant passenger flows "against the tide" in normal times?
Every time I've got a morning suburban train out of London Waterloo it's been quiet departing WAT but lots get on at Vauxhall and Clapham Junction.
LSWR Cavalier
23 Aug 2020
Leafy Suburbia
Hamburg - Luebeck, lots of lucrative jobs in Hamburg, but about a third as many commute in the other direction to Luebeck
Mcr Warrior
8 Jan 2009
Pre-COVID19, there always used to be a fairly significant counter-flow from the Central London direction into East Croydon.
xotGD
4 Feb 2017
Between Leeds and Manchester both directions are peak flows.
Tomos y Tanc
1 Jul 2019
Logic would dictate that you're looking for pairs of cities or centres of employment which are within a commutable distance of each other. Bristol & Bath and Portsmouth & Southampton spring to mind. I'm guessing that the traffic between some outer London boroughs like Croydon and the more central ones goes both ways as well.
duncanp
16 Aug 2012
Between Edinburgh and Glasgow there are significant numbers of commuters in both directions.
Similiarly quite there are quite a few commuters going from London to Cambridge, Milton Keynes and Reading.
Also from Milton Keynes, there is a not insignificant flow of commuters to Birmingham.
Lots around Yorkshire, since there are quite a few large employment centres around.
Mojo
7 Aug 2005
I always found that the Great Western Main Line to be like this, Reading in particular being a significant traffic generator with people travelling toward against the flow. Also on a similar line whilst most lines lose customers as you’re travelling away from London, the intercity services in particular often pick up similar numbers at Reading heading westbound as they drop off.
paddy1
11 Oct 2011
Beds
Coventry and Birmingham. Leicester and Nottingham. Derby and Nottingham.
Mag_seven
1 Sep 2014
here to eternity
We have had a similar thread specifically for flows around London:
As already mentioned, Paddington - Reading is the example that springs to mind.
RPI
6 Dec 2010
Truro towards Falmouth can be almost as busy as towards Truro in the morning peak
PeterC
29 Sep 2014
Into Watford from Central London on the WCML , Thameslink into Elstree and Borehamwood.
Whenever I have been in that part of Watford in the morning there seems to be a decent number alighting from northbound Overground services at High Street.
Peter Mugridge
8 Apr 2010
Epsom
In normal times, into Epsom from both the Wimbledon and Sutton directions can be quite heavy in the morning peak and vice-versa in the evening.
Ianno87
3 May 2015
Waterloo / Clapham Junction to Richmond / Twickenham / Brentford
Peregrine 4903
18 Aug 2019
Canary Wharf isn't in central London so technically London Bridge to Canary Wharf on the Jubilee Line is a counter peak flow. Although it probably shouldn't count as one.
Paddington to Slough and Reading to Slough are also big counter peak flows.
43066
24 Nov 2019
Waterloo East - London Bridge, for those sensible enough to avoid the Jubilee line!
Peregrine 4903
18 Aug 2019
Before Covid, I once used the Jubilee line going Eastbound at Waterloo and I had to wait for 6 trains, and even then I could only just about squeeze on.
Sod
3 Jul 2011
From 1966 to 1973, I commuted to school down the New Guildford Line from Claygate to London Road Guildford, and the trains running 'against the tide' were surprisingly busy. The high-quality schools in Guildford (both maintained and independent) generated substantial early morning and late afternoon traffic which may well continue today. Back then, the rolling stock was a mix of trusty 4SUBs and 4EPBs, with slighty flashy 4VEPs in later years, invariably running in eight car formations. It was always exciting when industrial action or closures in the late 60s brought visits from 2BILs and 2HALs from the main line, bringing a flavour of the exotic to a mainly suburban route. Happy days!
Cheshire Scot
24 Jul 2020
North East Cheshire
Manchester to Crewe has significant contra peak flows into Stockport, Wilmslow (even before school traffic is taken into account) and Crewe itself.
Scotrail314209
1 Feb 2017
Edinburgh
Kilwinning - Ayr seems to have a significant flow. Quite a lot of workers and college students board at the intermediate stations to go to Ayr.
cle
17 Nov 2010
Echoing the centres around London which either have quite specialised sector employers (Oxford, Cambridge) or general HQs/large offices (Watford, Slough, Reading, MK, Croydon) - there are some smaller ones in the same vein too.
LSWR Cavalier
23 Aug 2020
Leafy Suburbia
What about the fairly equal flows? Nottingham - Derby for example
Thousands of people going back and forth, costs a lot in time, money, energy
Maybe people could be encouraged to try to swap and work nearer home
A win-win situation, shorter trains could be run at the same intervals
I used to get the train out of town to work in the suburbs, my train was nearly empty, the trains going in were full + standing
Ianno87
3 May 2015
I have always wondered what commuting would look like if housing were theoretically allocated to be 'optimal' to minimise the total national travel to work time/distance.
telstarbox
23 Jul 2010
It's not that simple though - some of the jobs in Nottingham won't exist in Derby and vice versa e.g. Boots and Rolls Royce will have different specialist roles. Then people have other family members with ties to one place or the other.
RPI
6 Dec 2010
Exeter to Digby & Sowton is another, lots work on the retail Park nearby
A few which spring to mind
Cambridge (this is a big one, and has exploded since the 1990s).
Crawley
Guildford
Stratford
East Croydon
Reading
Oxford
TheSeeker
15 Feb 2016
Braine-l'Alleud
When I worked in IT in Reading and Slough a lot of colleagues had studied in Kingston and decided to settle in West London. A lot in Ealing who came out to the sticks every day.
