Leeds-Preston validity
John @ home
1 Mar 2008
I agree that a Leeds - Preston route Any Permitted ticket is Permitted via Chorley by map combination WY+GM+NW.
I agree that a Leeds - Preston route Any Permitted ticket is Permitted via Warrington Group by map combination TP+NC.
Is it your intention to end your outward leg at Chorley and to start your return leg at a station in Warrington Group?
Waverley125
2 Sep 2008
Leeds, West Yorkshire
so, the result is....yes?
Yes, not actually travelling through to preston.
John @ home
1 Mar 2008
Will a Leeds-Preston return be valid via Warrington?
Eagle, note the word "includes" in the text of the trainscanbecheaper page. It does not claim to show all Permitted Routes in the text description, so we can't use it to eliminate a potential route without an exhaustive check of the map combinations.
If you are able to use trains which call at Stalybridge in each direction, and you are returning the same day, then a £13.70 Off-Peak Day Return Leeds - Stalybridge and a £10 GMPTE Wayfarer: rail (see map for area of validity) would give better value than a £28.10 Leeds - Preston route Any Permitted Off-Peak Return.
Waverley125
2 Sep 2008
Question, would a ticket to Ormskirk be valid?
Presumably it's legitimate on
Leeds-Bradford-Burnley-Preston, change, Orsmkirk
and
Leeds-Huddersfield-Piccadilly-Warrington-Liverpool, change, Ormskirk
with a railcard that's £17.10 Off Peak Day Return (CDR)
John @ home
1 Mar 2008
and Leeds-Huddersfield-Piccadilly-Warrington-Liverpool, change, Ormskirk?
No. The Routing Point (RP) Identifier tells us that the RPs for Ormskirk are Liverpool Group, Preston and Wigan Group. To find out which RP(s) are appropriate for a Leeds - Orsmkirk route Any Permitted journey, the Routeing Guide Instructions tell us (Step 4) to compare Anytime Day Single (SDS) route Any Permitted fares:
  • Leeds - Ormskirk SDS £28.60
  • Leeds - Liverpool Stns (all) SDS £29.20
  • Leeds - Preston Lancs SDS £25.40
  • Leeds - Wigan Stns (both) SDS £30.30
The only appropriate RP for a Leeds - Ormskirk route Any Permitted journey is Preston and travel must be by a Permitted Route Leeds - Preston then by the shortest route Preston - Ormskirk.
