Leaf blowing trains.
Pompey00
Repeatedly returning banned member
15 Aug 2022
Portsmouth
Working at a train station you normally see the leaf blower train pass through twice a day one way then the other pushing air and water onto the tracks to get them off but not long after more leaves are back onto the track and glued to be Rails again when trains come through. Is this effective and what would happen if they wasn’t about.
24 Nov 2019
I’d ask a slight different question - do you really think millions would be spent on doing this ever year by network rail if it wasn’t effective?
If this wasn’t done there would be far more slip throughs and delays caused by low adhesion meaning trains struggle to stop and get going again.
Northampton
It's called the RHTT - Railhead Treatment Train, and it's effective but no 100% effective. NR regularly test other technologies, such as dry ice, plasma beams, and lasers but so far none have been as successful as the Waterjet. If they weren't around you'd have a lot more SPADs, with lack of railhead adhesion a factor in the Salisbury Collision.
The interim RAIB report: https://assets.publishing.service.g...IR012022_220221_Salisbury_Tunnel_Junction.pdf notes the impact of low adhesion, and the fact that the RHTT was due to run through every 24 hours year on the day of the incident had been retimed to run through 36 hours after the last treatment.
Navajo8686
15 Aug 2014
I think that the OP was asking if there was a better way of track cleaning not if it was necessary.
pdeaves
14 Sep 2014
Gateway to the South West
Network Rail works in conjunction with (or shares information with) overseas administrations to develop the best anti-leaf technology. Various new things have been tried (as zwk500 states above) but what we have now is currently the best way of doing things.
snowball
4 Mar 2013
Indeed there was a press release about the latest attempt at this just last week.
Space-age technology using lasers and plasma jets are being trialled as a more sustainable way to vaporise autumn leaves from railway lines and minimise passenger delays in the future.
Northampton
Yep. There was an article in one of the magazines about a similar test in the US, just after I'd joined NR 5 years ago.
There were all sorts of ideas on adhesion, and the related problem of detection by track circuits, throughout my time at British Rail Research and successors (1987-2006). A big one that hasn't been mentioned is bringing back sanders, which are now fitted to many multiple unit classes.
Purple Train
16 Jul 2022
Exile or exile
As it's the anniversary of the Salisbury Tunnel Junction accident last year, there's currently an article on the BBC about Network Rail pledging to run more RHTTs, or "leaf-busting trains" according to the article.
https://www.bbc.co.uk/news/uk-england-wiltshire-63438590 (link to BBC article entitled, "Salisbury rail crash: Anniversary pledge on leaf-busting trains.")
Rail firms say they are stepping up their fight against leaves on the line after a crash a year ago involving passenger trains in Salisbury.
Two moving trains collided inside the Fisherton Tunnel on 31 October 2021, with an interim report revealing it was caused by compacted fallen leaves.
Seventeen people were injured, including one of the train drivers.
Network Rail and South Western Railway (SWR) say "leaf-busting" trains will run more regularly this autumn.
In last year's crash, the SWR driver was unable to brake properly for a red signal as compacted leaves on the line had made the rails slippery and the train travelled 626ft (191m) past the signal until it hit the side of a Great Western Railway (GWR) service at a junction.
As an aside, I hope that dreadful accident will serve as a reminder to the tabloid media whenever they moan about "leaves on the line" being a pitiful excuse.
I seem to recall hearing about the possibility of using technology fitted to the front of passenger trains instead of RHTTs - did that ever progress any further than a couple of inches of column space in RAIL?
Pompey00
15 Aug 2022
Portsmouth
True they and Thankyou.
skyhigh
14 Sep 2014
Northern are trialing the water spray during braking on some of their 170's I believe.
There's 2 170s fitted with Water-Trak. Will be interesting to see what happens, as drivers are essentially told to drive as normal and there's no obvious way of telling that the unit is fitted with the equipment.
43066
24 Nov 2019
Any idea whether that’s onto the wheels or the rails? I know some modern stock (700s for one) has tread brakes on certain wheels to remove leaf mulch from the wheel rims.
skyhigh
14 Sep 2014
The rail. There's a description on their website of how it works. From memory the capacity of their water tanks is enough to give the same range before refilling as the fuel tanks on the unit.
Supercoss
5 Jun 2016
Balfour Beatty had a Vacuum wagon , I recall trialled in tunnels at Stansted airport branch , pic from BB Rail plant site AA32178D-B3BC-4B4D-B1EA-78A7EF0610DB.jpeg
Need2
15 Jun 2016
Are you saying the tread brakes are fitted for this reason?
I was under the impression they use tread brakes on the motor coaches because there was not any space for the disc brakes.
I believe that's the reason for 700s. Some 158s were fitted with tread brakes as well as disc brakes on the end bogies, which I recall was specifically to do with cleaning the wheel treads, but may have been more for track circuit detection than for adhesion.
pdeaves
14 Sep 2014
Maybe the use of tread brakes makes it practical to put 'other equipment' where the disk brakes would be... (i.e. maybe look at it the other way round) :)
43066
24 Nov 2019
Apologies I had thought that but, having read back over it, it seems lack of space was indeed the main reason on the 700s.
Supercoss
5 Jun 2016
All motored axles on c700 have tread brakes which is why they perform so well in Autumn, every station stop or junction stop the motored wheel tread is scraped , yes they still slip and yes they still slide but the tread brakes make so much difference . I can't remember exact speed they apply but it is below 7 mph 8E4968C9-7202-4866-8C28-59A985E390F1.jpeg
furnessvale
14 Jul 2015
To answer your last question. The other day, the scheduled rail head treatment train for the Hazel Grove to Buxton line did not run for whatever reason. All trains on that line were cancelled and rail replacement buses ran.
Edited to add. A quick check on RTT shows a few trains DID run, but those were HEAVILY delayed.
Yes, this is why there were specified.
All motored axles on c700 have tread brakes which is why they perform so well in Autumn, every station stop or junction stop the motored wheel tread is scraped , yes they still slip and yes they still slide but the tread brakes make so much difference . I can't remember exact speed they apply but it is below 7 mph View attachment 122959
AIUI, at certain times of year (eg now) they are used for main braking at any speed. My 700 today certainly had something that sounded like tread brakes applied, which was just as well as the train had bad wheel slip at the previous station.
Need2
15 Jun 2016
So when I was told by instructor during my traction course on the 700 that the reason for tread brakes was because of lack of space for disc brakes, he was mis informed?
Regen braking is used for all braking down to 7mph (can’t precisely remember exact speed!) then the disc and tread brakes take over.
The only other times the disc and tread brakes are used are in emergency braking or in snow brake mode
Rather than delete the above I will explain what I meant in a better way!
The tread (friction) brakes on a 700 are only found on the motor coaches.
When braking, the motors on the motor coaches perform the braking until the tread brakes take over at 7mph. On all other coaches the disc brakes are used 100% of the time.
As said above, emergency braking and snow brake mode uses only the friction brakes. ( tread and disc)
If the tread brakes were only specified for adhesion purposes (and not because of space limitations) don’t you think that leaving them to work, in normal circumstances, at speeds below 7mph would be of any use?
yes.
I was told by the bloke who owned the train specification.
ComUtoR
13 Dec 2013
I must admit, I agree with Need2. What you have probably experienced is where the TMS and the brake modules can adjust the blending. I have a brake graph somewhere that shows where the blending adjusts.
Surely it would take an update to adjust the braking each year otherwise.
