It is right that the actions of the passenger in this case where reported as a Factor . If for nothing else so that records of passenger actions such as this can be held and used for training staff and deciding on when and where dispatchers are needed to manage the risk from passenger action .
I also think some passenger education posters and information can be deployed , I cant remember where I was but there was painted outlines of people by the edge of the platform showing them as if they would be falling under a train , highlighting the risk of running and slipping or tripping on a platform . There are also the posters about train doors closing 30 or 45 seconds prior to the departure time .
For all those saying the conductor should be sacked I actually tend to agree that someone making such fundamental mistakes and being so fundamentally lax when carrying out safety critical work should not be allowed to carry out that work unless fully retrained , or ideally should be given something non safety critical to do .What he did in failing to the check at a location he knew was actually quite dangerous is not just a minor error of judgement or a mistake , it shows complete disdain for the importance of doing his job properly .
Alas this will not be the case because the employers have to follow the set disciplinary procedure . I can only imagine he will have been seriously disciplined and if anything like this occurs again he will be looking for a new job .
I dont think james street is 100% relevant as a comparison to this case because at James Street the guard knew someone was leaning against the side of his train when he gave the RTS to the driver , At newcastle the conductor did not know someone had their arm stuck when they gave the RTS .
It is concerning the mess that occurred in the reporting of this incident , and the fact that it didn't come to light until some time after the incident . Is this the fault of the conductor for not stating how serious the report was , or was it the fault of the control staff for not asking the right questions (which if they aren't they should be trained to do )
Personally all of the detail and discussion about the design of the doors and the fact that it was possible for something to be trapped in them seems a bit academic to me given that the traction I work(sprinters and pacers) does not have any fancy detecting equipment. The TOC I work for and the passengers that play race the hustle alarm on my trains have to rely on me/dispatchers doing the job properly .
That being said apart from the occasional 155 the traction I work doesn't have an indication inside the unit to tell you the doors have been locked so you have to rely on a visual check of the doors themselves and the hazard lights which means you are also checking the doors have not got anything trapped in them . Also even with the class 185's , even if the door detection circuit is substandard , surely the fact that the conductor is required to do the safety mitigates the substandard sensing system
It's not even true, though. There was a fTPE service in 10 last week albeit Not In Service.
it will be one of them wont it where TPE have committed to avoiding working out of 10 as far as is reasonably practicable . Which basically means nothing has to change .
