Landslip between Rugby and Coventry. (11/02/24)
Would probably make more sense for them to follow airline practice and publish a "next update in" date/time.
I suspect this one is going to take a few weeks.
that1giox
6 Jan 2024
Coventry
Are some of these trains using the Chiltern Line?
They're not using the Chiltern Line, as like said above the Chiltern Line has an extreme lack of overhead wires and practically all of the trains running on the line between Coventry - Rugby are EMUs. However ticket acceptance got agreed with Chiltern and Cross Country, which is how passengers would have to get to London.
MarkWi72
13 Nov 2017
Doubt it, as they're mostly EMUs and there is a distinct lack of wires over there! (Does that tell us something? :) )
Thought some were Voyagers? The they could go across to Leamington from Nuneaton.
On another note, there was someone on Social Media suggesting they went north of Stafford then to Dorridge. I cannot comprehend that, so probably not true.
Ok, I see.
D1537
11 Jul 2019
North Yorkshire
https://www.recenttraintimes.co.uk/Home/Service?ServiceId=119507759 implies that 1R07 did indeed start from Wolverhampton today, 5R07 certainly arrived in time, so RTT has over-written the up times with the later times from the reverse direction I think. Mind you, if I'd rushed to make the 06:03 departure I'm not sure I'd have been happy to see Wolverhampton again an hour later.
1R15, the 0645 Wolverhampton-Euston, also did the same thing. Arrived at New Street at 0707, then departed at 0720 northbound again.
Having said that, if you'd been at Wolverhampton for 1R15, I presume you'd have been advised to wait for 1R07 on its return journey from Birmingham (it left Wolverhampton for Stafford at 0700), which would have got you to Euston only 15 minutes later than 1R15's booked time.
The trains after that (which are generally from the north, rather than starting there) appear to have reversed at Wolves.
QueensCurve
22 Dec 2014
I did wonder if they'd consider using double Voyagers to run an hourly Euston<->Birmingham via Nuneaton, which was the classic diversion I've experienced many times during West Coast route modernisation. I guess it's too hard to path that on the Trent these days.
If it goes on for a long time I suspect they may well consider this even if it requires dropping something e.g. one of the Manchesters.
What I don't get is why WMT are spinning at Northampton when Rugby has a south facing bay they could use (even if only for a shuttle from NMP if that doesn't work for the normal paths). They take that lazy option an awful lot.
that1giox
6 Jan 2024
Coventry
With the Down line open, it seems another classic example of where bidirectional signalling could have kept services moving with minimum distruption.
That's what I was thinking, they could've just made it into a single line and use the one track in both directions rather than messing up all the services, but I guess this would just cause them to have to pay out to customers more because of the delay repay scheme and the amount of traffic that tends to pass through. (Avanti and LNWR.)
Could also not be a decision they decided to make due to engineers being on the line? Although engineers on other lines carrying out repairs never seem to be an issue.
Avanti services seem to be running on the line towards Nuneaton and then Rugby rather than coming down the line here, London Northwestern Railway have also seem to put in some sort of reduced timetable with hourly services now departing from my local, Canley in either direction. Avanti services through Canley have been dropped from the usual 6-8 to now only 2.
SCDR_WMR
17 Dec 2017
Crewe
I'm not sure, there were a pair of 730s in the bay this morning, so if they haven't got any drivers available to move them, the bay isn't available.
It has been a pain today, having guards from Crewe have to go to MKC and then to Northampton to work trains that could easily be met (as diagrammed) at Rugby.
I would guess it's so they have as many blocks as required without stiffing all services up the swanny. Far easier to manage, and whilst it's inconvenient, passengers can still get to the Trent Valley stations pretty easily for Euston services.
that1giox
6 Jan 2024
Coventry
I was at Rugby on Friday and I watched the 730s come into the bay there, according to Traksy the 730s still remain there.
WMR Could easily terminate services at Platform 2 or 3 though, don't really see why they wouldn't do that instead. It would also be much more efficient and faster to just have RR services running between Rugby and Coventry rather than Coventry and Northampton.
It wouldn't have been minimal. It would have been single line working from Long Lawford to Coventry. As well as the issue of having safe clearance for people to work.
Avanti don't sign the Chilterns.
Jimini
8 Oct 2006
Reading
Think I’m right in saying that you can only access the down line towards Rugby from Cov from platforms 3 and 4, which would make shuffling everything around at Coventry an additional headache on top of the long SLW?
Think I’m right in saying that you can only access the up line towards Rugby from Cov from platforms 3 and 4, which would make shuffling everything around at Coventry an additional headache on top of the long SLW?
Yep. You would get 1tph each way.
Class 170101
1 Mar 2014
why is there, what looks like, a full signal 9310 at Long Lawford Crossovers if not to permit Bi-Di working from Coventry to Rugby on the Down Line then?
Martin_1981
15 Jul 2011
What about some Class 390 drags between Brum and Nuneaton using Class 57's? I guess that's not possible anymore due to lack of route/traction knowledge?
Class 170101
1 Mar 2014
Frankly with the time penalty and hassle of the attachment and detachment a Birmingham New Street to Euston via Stafford Class 390 service is the correct option here.
If a Class 221 then running via the route you suggest seems sensible.
PyrahnaRanger
16 Aug 2022
Lancashire
That isn’t a simple fix.
I may not have explained myself well, I wasn’t intending to say it was a simple fix, merely that it looked like a simple fix. For Joe Public, i was suggesting that the word “landslide” brings to mind images of Carmont or the S&C when it was well covered with mud and rock, whereas this one looks like a a bush that needs trimmed, whereas in reality, it has been moved by the ground sliding away under it, it’s just there’s none of that visible, hence my comment that this is one of those occasions where sharing information actually works against you rather than for you.
BrianW
22 Mar 2017
The pictures here (BBC today)
Agreed- it is more than 'a bush'! The second image here is more informative:
: https://www.bbc.co.uk/news/uk-england-coventry-warwickshire-68271990
and here (from 2020) may also be informative regarding 'landslip': https://www.bbc.co.uk/news/uk-england-coventry-warwickshire-51419258
Efini92
14 Dec 2016
No you can get on the up from all platforms.
M60lad
31 May 2011
Is there a reason why these services have to run to Wolverhampton only for them to return back up-to Stafford to get onto the Trent Valley route?
A0
19 Jan 2008
Probably a mix of reasons:
It's fully wired, so it's a route Pendos can use - unlike Water Orton or Nuneaton - Coventry.
It's probably easier to effect a reversal at Stafford than Rugeley TV.
It's a route Avanti's crews are probably passed to drive (may not be the case on the Chase Valley to Rugeley).
Means only Coventry loses its direct train to London, as Birmingham and Wolves both keep theirs albeit with extended journey times.
AIUI, the teams shifted nigh on 1000 tonnes of muck overnight, work going well, line should be open later this afternoon.
Efini92
14 Dec 2016
Wolves is a relieving point for the crews.
Also there’s more services from wolves to Birmingham and beyond.
