Kicking up a stink - non retention toilets.
mwmbwls
14 Dec 2009
The BBC carries a story about the health risks to track side workers from the spray and detritus spread from non retention toilets.
http://www.bbc.co.uk/news/uk-england-cambridgeshire-25430657
Cambridge rail worker's health fears over excrement spray
Rail workers are being sprayed by human urine and faeces from passing trains, putting their health at risk.
A Network Rail worker said staff were "genuinely concerned" about excrement, urine and sanitary towels on the tracks.
Network Rail accepted that train toilets which emptied on the track were "outdated and unpleasant" for track workers.
Greater Anglia said it was hoping to phase out toilets which dump waste.
The man who works across the East Anglia region said: "A train would be coming and we'd stand back the recommended distance.
"It's not unusual to feel a spray, a kind of mist in the air. That's bad enough, but then you walk back to where you've been working on the tracks there's [faeces] everywhere."
This is a long recognised problem - although the introduction of powered doors and the removal of external door handles means that it might be less obvious to passengers, apart from the faeces and toilet paper seen in the track bed at stations.
Just how much of this stock remains in service? When is it scheduled for replacement? Is a retention toilet system something that can be fitted during the life of a carriage or is this a new build only issue? Are toilet conversions to allow for disabled passengers always linked to the installation of a retention system?
A-driver
9 May 2011
Not sure if there are plans to upgrade the GA fleet but it's certainly possible to do. All FCC 317s were fitted with tanks about. 5 years ago. All FCC 321s were upgraded to tanks earlier this year.
alex17595
15 Mar 2013
Burton on Trent
I have only worked open line with 390s and 350s.
Some idiot went to the toilet and flushed in Nuneaton station, it cleared the platform!
How do you get covered in it when they always seem to be out of order :D
jopsuk
13 May 2008
do the GA 317 & 321 refurbishment proposals include retention loos?
A-driver
9 May 2011
So which are the classes that have toilets but no retention tanks?
If it's around Cambridge station we are talking here the. The only stock I can think must be GA 317s and 156s. Don't know specifically that they don't but all FCC units do, 379 and 170 do aswell.
LBSCR Times
17 Sep 2013
Sussex born and bred
And when South Eastern installed facilities at Grove Park Sidings to empty toilets, the local residents kicked up a fuss (was going to say kicked up a stink but.....)!
Monty
12 Jun 2012
But I was under the impression both 390s and 350s have retention toilets and don't flush effluent onto the track.
jopsuk
13 May 2008
What was the last British class built without retention toilets? Networkers as fas I know had tanks from new. Pretty sure all post-privitisation stock does.
Buttsy
20 May 2011
Hanborough
I think 158s had retention tanks but 156s didn't, so anything built prior to the 158 probably doesn't have them unless retro-fitted.
Easiest way to tell is if there is a notice asking you not to flush when stopped at a station... ;)
455driver
10 May 2010
158s were not built with retention tanks.
SWTs 158/159s had tanks fitted after being built.
sprinterguy
4 Mar 2010
Macclesfield
Class 158s were not fitted with retention tanks from new, they have been retro-fitted with them in the last few years. This most probably makes them the most recent DMU not to have been built with retention tanks (The 159s had them retro-fitted during the conversion from class 158s before they entered service).
I'm not sure about EMUs, though: I've checked and the 323s do have them, so I suppose that would make the mark 3 based EMUs the last not to have them: 321s (and their derivatives - 320 & 322) and 456s (EDIT: Since realised that 320s and 456s didn't/don't have toilets) being the youngest of these.
Yew
12 Mar 2011
Personally I'm of the opposite opinion, retention tanks should be ripped out of voyagers so the carriages dont smell. :D
Silv1983
8 Jun 2012
Somewhere in Stockport
This notice is like a moth to a flame. People just can't help themselves it would seem looking at the sludge which lines the track in most busy stations.
thetangoman
26 Feb 2013
Helensburgh
I'm not sure about EMUs, though: I've checked and the 323s do have them, so I suppose that would make the mark 3 based EMUs the last not to have them: 321s (and their derivatives - 320 & 322) and 456s being the youngest of these.
320's have only just had toilets fitted to them so I will imagine that they do have retention tanks
Cheers
Russell
sprinterguy
4 Mar 2010
Macclesfield
Cheers
Russell
Oh, I hadn't realised that they were originally toiletless. :oops: Just realised that the 456s are the same - I'll make an edit to my original post.
Buttsy
20 May 2011
Hanborough
The 456s were originally built with toilets (probably track discharge ones) but had them removed.
Tracked
30 May 2011
53.5440°N 1.1510°W
follow the general rule for travelling by coach:
"No Solids"
Mind you, suppose it's easier for coach passangers because of the service station stops. People would moan if a train had a similar 20 minute waste disposal stop - as a suggestion: perhaps Service Stations are needed on the railways too :)
Welly
15 Nov 2013
When all passenger trains gets retention tanks, naughty schoolboys will not be able to play "Bomber Command" on their train rides to and from school! That game consists of stuffing paper in the bog and flushing so that it dumps on a particular bit of track such as a foot crossing! <D
I remember reading in the paper many years ago that DB retrofitted ALL the non retention tank fitted coaches after one farmer complained about the mess left around his occupation under-bridge!
VP185
13 Feb 2010
The idea that the train operating companies should pay to have retention tanks fitted to 'their' trains is ridiculous. It's like renting a property and then building an extension on it out of your own pocket!
The train operating companies do not own the trains, they are leased. Therefore it should surely fall to the leasing companies to fit retention tanks??
455driver
10 May 2010
Agreed, but how many trains can the TOC spare to have the leasing company fitting the tanks?
Plus the fact you will need to install emptying equipment at the depots.
You will also need to change the diagrams so each train will visit a location where the tanks can be emptied every couple of days.
The there is the biggy, there are no spare units and the ones in service are worked very intensely with no spare capacity!
jopsuk
13 May 2008
It is more like a firm leasing a building, then paying for work to configure it to their needs. Which is very, very common. Very normal.
455driver
10 May 2010
The trains have to be handed back to the leasing company in the same condition as at the beginning of the franchise unless there is an agreement in place.
If the work is done by the leasing company then they will increase the leasing charges to cover the extra expense, any way you look at it the TOC has to pay.
jopsuk
13 May 2008
Quite. More likely if tanks are to be fitted a financial agreement between the TOC, ROSCO and mediated by the DfT will be arranged.
