Is a four track preserved railway possible ?
74A
27 Aug 2015
Is there anywhere in the country you could reopen a 4 track railway. Im guessing probably not as places that needed 4 track have probably not been closed only reduced from 4 to 2.
In preservation you have 2 track railway on the Great Central (which also has loops at Swithland but not long enough to call it 4 track)
Just wondered if there was anywhere it could be done ?
Ianno87
3 May 2015
Why would a preserved railway *want* a 4 track railway, other than for the photographic appeal? You'd need to be running enough trains to justify its cost and upkeep, for starters.
Cowley
15 Apr 2016
Devon
I can't think of any of our preserved railways that ever had four track? Mainly because of course most of them (apart from the GCR) were fairly minor and often single track routes.
It was a major achievement putting the double track back on the GCR too.
Maybe the RH&DR would be the best bet :)
61653 HTAFC
18 Dec 2012
Is it possible? Yes, it doesn't defy any universal laws...
Is it likely? About as likely as my plans for an open access service from Cuckoo's Nest on the Kirklees Light Railway to Altnabreac, using special multi-gauge modified 142s.
Cowley
15 Apr 2016
Devon
I was waiting for something to invest my money in and I think I've just found it. Happy new year by the way.
This time next year Rodders... :)
steamybrian
26 Nov 2010
Kent
Horsted Keynes station has 5 platforms (four running lines) through the station but was double track to Ardingly, West Hoathly and single to Sheffield Park (earthworks built for double)
AndyW33
12 Aug 2013
The GCR does run to double track with a passenger-rated running loop on each side (at Swithland Sidings). That's probably as close as you'll get to quadruple track in preservation.
MK Tom
31 Aug 2011
Milton Keynes
I've often wondered if this is the largest station in preservation in terms of number of platforms, and where else might come close.
A similar discussion would be where other than the GCR has workable double track? Bewdley on the SVR and Butterley-Hammersmith on the MRC strike me as possibilities.
Regarding Swithland there was a similar complex on the GCR(N) where the Gotham branch turned off. I don't know if the GCR(N) has any plans to do anything with that site or the Gotham branch.
Setting aside the "why" or "how", the old Midland Mainline through Cudworth used to be four track and has since closed. I believe mining subsidence had something to do with this, so you might not be able to reach high speeds !
mr_jrt
30 May 2011
Brighton
Practicality aside, the Swithland Viaduct rather puts a dent in any 4 track plan for the Great Central. Best you could hope for would be adding the loops at Quorn & Woodhouse and linking them to those at Loughborough, then repeating the process at Rothley and linking them up to those at Swithland. Double tracking down to Leicester North would be a good start though :)
Bedpan
4 Feb 2010
Harpenden
The cheapest resolution surely would be to rip up the standard gauge track and relay with 15 inch gauge.
Cowley
15 Apr 2016
Devon
Or this (not my photo), 7' 1/4 inch at Beer? Quadruple track (sort of) and freight too.
Eat your heart out GCR. :D
18 Dec 2011
While not a 4 track railway, at MRC Swanwick Junction Station 4 trains have in the past departed to different destinations at the same time. Platform 1 demo goods up towards West Shed. Platform 2 passenger towards Butterley. Platform 3 passenger towards Ironville and a train (can't remember if it was goods or passenger) from platform 4 up the Swanwick branch.
Cowley
15 Apr 2016
Devon
Well that's pretty impressive. I can't think of many preserved railway stations with four trains on the move at the same time.
Deepgreen
12 Jun 2013
Gomshall, Surrey
No preserved railway could afford to install and maintain a significant length of four tracks, nor run enough trains over a four track route to make it worthwhile. I suspect Swithland sidings will be as close as it will get.
10 Mar 2013
as others hve posted i think it;s a vain hope except in and aroudn a station of junction on one of the lager twin tracked 'main line' preserved railways ...
Flying Phil
18 Apr 2016
Re Swithland .
.. In theory you could possibly have Five trains moving - if the Mountsorrel branch is counted, as there could be two Very slow, short trains shunting in the two loops, two Main Line trains passing and one just in sight on the branch line. It is a shame the Branch line is "Blocked" on the curve, it would be nice to go further into the siding complex, pausing, to coincide with a regular service train.
Taunton
1 Aug 2013
I've seen four on the go at once at Didcot; one on the main demo line, one on the "branch demo line, one on the shed bypass, and one moving into the shed. However, Didcot doesn't seem to do the galas any more like they used to.
