*International* Guess The Station
chrisjo
18 May 2024
Llanishen
Binissalem?
A few seconds later.........You got it, Binissalem, Mallorca.
One of the six 91 series tram-train units built by Vossloh between 2009 and 2011 for the Manacor-Arta line that didn't happen. Now in use on the Palma-Sa Pobla 'Inca Express', with low-level platform extensions built at each station on the route.
itfcfan
7 May 2011
Szentgotthárd
That's right!
The yellow/green train was indeed from the GySEV/Raaberbahn - a joint Hungarian-Austrian railway company. I used this combination of trains to get from Budapest to Graz. Here's another view of the same station, looking in the opposite direction:
Over to you @Andover.
chrisjo
18 May 2024
Llanishen
Hmm. So we need a country where a platform is a 'spor', but also has english-language signage.....
....so, I find that Denmark seems to fit the bill, and not only that but they have a system in which STOP FOR U-SIGNAL is a specific sign. Plus climate / vegetation look plausible for Denmark.
Here's an example.
chrisjo
18 May 2024
Llanishen
Here's an example.
There's even a possibility that simply by doing a Google image search using the STOP FOR U-SIGNAL sign that I might have hit on the right location - Kagerup.
Andover
30 Mar 2019
Correct! I hadn't thought of it, but although quite an isolated junction it makes up most of the results when you search for that signal, probably thanks to being on a non-DSB line.
Up to you.
chrisjo
18 May 2024
Llanishen
Well we don't seem to be making much progress with this one. How many are actually playing?
We all know what country it is and the train is obviously a 598, of which there are less than 20 sets all based in Seville, and the landscape/vegetation is clearly mediterranean. The station name must be pretty long, judging by the size of the name boards.
AndrewE
9 Nov 2015
Given that it's not electrified, on a curve and rural/mountainous and the hint about units based at Sevilla, I'm wondering about somewhere between Utrera and Bobadilla Junction, or between there and Algeciras...
The services were so infrequent - and booked solid - last spring that we did several of those legs by bus!
chrisjo
18 May 2024
Llanishen
It's on a line between two of the places you've mentioned.
chrisjo
18 May 2024
Llanishen
There seem to be four per day stopping here in each direction at the moment, but there was no need to book when we were there in September.
