Information on Disruption
vlvstvir
13 Aug 2020
United Kingdom
Currently sat waiting at Bristol Temple Meads for a train, due to the fact that there’s an incident between Bristol and Taunton.
It got me to thinking - what’s the best way to get information on cancellations and incidents? Other than tracking down a member of staff.
I used to use X, but have to admit I deleted it a while ago!
Northampton
RTT can be quite good, some TOCs have better live status webpages than others (GWR's can be patchy at best)
Frontera2
11 Dec 2007
Some operators now have WhatsApp channels for broadcasting information during disruption: bit.ly/seWAchannel being a good example
Horizon22
Jobs & Careers
8 Sep 2019
Journey Check - or some sort of equivalent - seems to be the best way as it goes to each individual service/headcode. It is reliant on some manual input though.
Otherwise a combination of a good rail journey planner (like Railboard or RTT) & some mapping software (like SignalMaps, if you know what headcodes are useful to you) will set you up fine.
For bigger disruptions, even NRES will eventually list the headline details.
Pacef8
21 Mar 2020
Wirral
Last monday the wirral line was off from the first train until about 4 pm due to what merseyrail called a signal failure . When infact it was a engineering train that cut through a cable around green lane . They didn't mention the last bit .
Horizon22
Jobs & Careers
8 Sep 2019
It would be a “signal failure” though ultimately because a cable - presumably affecting signalling - was cut, preventing the normal movement of trains. You have to be concise enough with your delay reason otherwise it becomes overly long-winded.
