Hydrogen Locomotives
randyrippley
21 Feb 2016
Slightly off-topic, but LU looked seriously at hydrogen locos as a potential replacement for their battery powered maintenance locos a few years ago. Not sure why it didn't happen.
Hydrogen in a confined space is a disaster waiting to happen. A leak - and explosion - would be inevitable.
xotGD
4 Feb 2017
I take it you don't have a natural gas supply to your home, in order to avoid the inevitable leak and explosion?
DerekC
26 Oct 2015
Hampshire (nearly a Hog)
Quite so. And even better, a fuel cell powered mining loco using metal hydride as a safe storage medium was demonstrated more than ten years ago.
randyrippley
21 Feb 2016
Heck of a difference between hydrogen and methane. Size of the molecule makes containment difficult
randyrippley
21 Feb 2016
Metal hydride technology has never commercially scaled
xotGD
4 Feb 2017
That is one factor in the risk of an explosion. You also need to consider the potential for getting a fuel/air mixture between the lower explosive limit and upper explosive limit, the risk of ignition and the magnitude of any blast wave formed.
Research looking at the relative risks of using natural gas and hydrogen in a domestic setting has concluded that they are pretty much the same. The various factors balance out.
You also take away the risk of carbon monoxide poisoning if you switch to hydrogen.
randyrippley
21 Feb 2016
In a domestic setting if you get a gas leak you can leave the building.
You don't have that option in a train in a tunnel.
And for what its worth, hydrogen is far more likely to leak than methane, especially where you have fuel lines subject to vibration
xotGD
4 Feb 2017
Well at least nobody has mentioned the Hindenburg yet.
