HST traction question
NoviceJames
21 Aug 2017
Hi,
Apologises for the possibly repeated question.
After looking online, it looks like the Class 43 HST has a 'BO-BO' wheel set arrangement, which is described as "Two bogies or wheel assemblies under the unit. Each bogie has two powered axles individually driven by traction motors"
So with 2 bogies per power car, are there 2 engines per power car?
Also with that in mind, I believe both power cars provide traction in top and tail formation, so are there 4 engines providing traction in total?
Thanks for the replies!
D365
29 Jun 2012
Class 43s are fitted with MTU 4000 series engines, with the exception of the EMTs (VP185) and the prototype.
One engine per power car feeds the four Brush or GEC traction motors.
NoviceJames
21 Aug 2017
Ahh, that makes perfect sense, thanks.:E
I was just confused with the term of traction motors and engines.
After looking at the Class 91's, as they are electric, they only require the traction motors.
Whereas with the HST they require the diesel engine, alternator and the traction motors you described.
randyrippley
21 Feb 2016
the only British locomotives with two diesel power plants were
class 17 "Clayton" - the centre cab meant there wasn't room for one big diesel, so instead two small ones were used.
class 41/42/43/52 "Warship" and "Western" diesel-hydraulics. In these, each of the two diesels drove one of the two bogies via a mechanical linkage and automatic gearbox. Two diesels because they were based on german designs, and german technology post-war had developed from the small devices used in tanks and aircraft - not big maritime diesels, unlike UK designs.
class 55 "Deltic" - two high speed diesels each with its own electrical generator, both providing power to both bogies as required
randyrippley
21 Feb 2016
Note - the class 43 Warships are not the same as the class 43 HST power cars
43096
23 Nov 2015
You've missed "Falcon" (later Class 53) and, much more recently, the Loram conversion for Network Rail of 73951/2 which have two QSK 19 engines.
10 Mar 2013
Hi,
Each power car has one engine , other posters have talked about the different types of engine fitted either the original Paxman Valentas or the VP185 or MTU fitted as part of life extension work
This engine drives a big alternator / generator which then sends electricity to each of the four traction motors ( one per axle) in that power car ... the only link between the two power cars is that the feed the 'hotel' power for the carriages and the control signals for each seperate powercar . if the engine is stopped in one powercar the train can continue but it is towing that switched off power car as the running powercar onl provides electricity to the traction motors at it's end ...
randyrippley
21 Feb 2016
Agreed, you're right
I forgot those oddballs
I deliberately ignored the Fell loco as well as being not really relevant
Mugby
25 Nov 2012
Derby
You could add the Fell Diesel Mechanical locomotive, 10100.
I think that probably held the record for the number of engines contained in one loco!
Cowley
15 Apr 2016
Devon
Ha yes. What an absolutely ridiculous machine! As far as I know it had 6 engines (not too much to go wrong then?) of which four powered the loco and two powered the superchargers I think?
It was carried on a massive 4-8-4 chassis and was apparently able to reach about 80mph.
It must have been quite a sight when travelling at speed...
Billy A
9 Jan 2017
Just Googled, never having heard of. Must have been just about the weirdest diesel ever!
Mind you, Bombardier do a four engine one, albeit without the eccentricities.
100andthirty
Milton Keynes
The forthcoming Stadler hybrid trains for AGA will have four diesel engines in one short vehicle on the 4-car trains (only two on the 3-car trains)
birchesgreen
18 Aug 2015
Solihull
Depends what you mean by "engine", in a diesel-electric the traction motors are the "engines" that provide the traction, the diesel engine (and assorted bits) just provides them with juice.
delt1c
4 Apr 2008
What about the 27/2, they had 2 engines a Deutz to provide ETH and the Sulzer for traction
43096
23 Nov 2015
No they are not. The engine is the engine and traction motors are traction motors. Not difficult really.
100andthirty
Milton Keynes
It must have seemed like a good idea at the time!
Kneedown
29 Dec 2007
Nottinghamshire
This engine drives a big alternator / generator which then sends electricity to each of the four traction motors ( one per axle) in that power car.
Just to add, that the ac current produced by the main alternator goes to the main rectifier which converts it to dc. Then it goes to the traction motors.
