HST Derailment
Failed Unit
26 Jan 2009
Central Belt
What colour scheme is that? Just asking as I've never seen that one before
It the MML Blue / Gray. Hopefully looks worse than it is (trains on thier side always looks bad). Glad no-one was hurt but the UK can afford to have stock out of use (or even writen off).
87031
25 Jun 2009
Its an East Midlands Set cant quite make out the one in the distance although it dosent look damaged like he EMT one
25 Feb 2009
East Midlands Trains - I think it might be the old Midlands Mainline colours
67029
23 Feb 2009
Hindley, Wigan
The two MML Sets were for 5C11 04:09 NL to Sheffield and 5C13 04:17 NL to Sheffield. It Appears that 43059 on 5C13 went side into buffet FO 41113 sat at 45 degrees. 43043 was leading on the set for 5C11 derailed pointing towards mainlines. The incident happened at approx 04:00 this morning:o
87031
25 Jun 2009
Theres 2 Leeds-St Pancras early morning trains at 0525 and 0634 culd be ther set that was due to work them or it might of being going to Sheffield to work 0741 Sheff-St Panc
Crossforth
20 Aug 2009
Lancashire
If I didn't have to be back in school by 3 o'clock, I would take a train out there but I doesn't look good. It looks like some bogies have been ripped off the MK3s. Good job it's old liveried stock and not been refurbished yet :lol:. Someone is gonna be in trouble though :oops:.
Good to see noone was hurt
Royston Vasey
14 May 2008
Cambridge
Bogies are only superficially attached to coaches anyway... hence why most derailments end up with bogies detached.
The coach in the middle looks like a write off to me.
matt
30 Jun 2005
Rugby
why go via Bescot ?
Is a crane out of guage for the trans-pennine routes ?
Its meeting up at Bescot with another break down train. I presume both sets will join and go to Neville Hill this evening.
Edvid
7 Feb 2008
According to 67029 the ECS moves were 5C11 04+09 NL - Sheffield and 5C13 04+17 NL - Sheffield, so I suspect they were due to work the 0527 (1C11) and 0556 (1C13) Sheffield - St Pancras International services respectively.
If I travelled to London at a particular time this morning I suspect my quest to avoid FCC (living near Luton Airport Parkway as I do) and still get there by train would have been a failure. :lol:
SouthEastern-465
24 May 2009
Greater London
Was it the drivers fault or somthing wrong with the rail?
As everyone else has said it's a good job no-one was hurt but I wonder who is at fault and what there excuses will be.
GB
16 Nov 2008
Somewhere
I guess we will have to wait for the outcome of the investigations to see what actually happened.
Edvid
7 Feb 2008
1C13 0556 Sheffield to St Pancras and 1C15 0525 Leeds to St Pancras both cancelled this morning.
Also 1B23 0634 Leeds to St Pancras started at Nottingham at 0828, stock probably blocked in.
I was half-(right/wrong) then. Thanks for the info.
route:oxford
1 Nov 2008
Is there sufficient "slack" in the UK rolling stock to accommodate 2 HST sets out of service for even a short period?
You mean EMTs rolling stock? Probably! No cancellations at all in the evening peak, and no delays at St Pancras (except for a single FCC service) this evening.
djw1981
10 Jul 2007
Postponing of maintenance? they should manage to get one usable rake even if one PC and a couple of carriages are damaged.
royaloak
11 Oct 2009
today I will mostly be at home decorating
Whats the UK got to do with it, this is an EMT problem, they did well this morning though only lost the 2 trips to St Pancras and one started at Nottingham, nothing the rest of the day.
EMT do have plenty of spare coaches so could possibly get both back in use fairly quickly using these, only really 1 power-car and maybe 3 coaches damaged so not huge problems, although could possibly make 1 good set out of the 2 if
asylumxl
12 Feb 2009
Hiding in your shadow
Not true at all The 19:00 service to Corby was delayed due to problems creating the set. I can only assume this train was booked to operate this service.
