HS2 trains - Interior design
Nottingham59
10 Dec 2019
I see that Alstom have released mock-ups of the HS2 train interiors.
The trains won’t be built until 2026 – but in a dedicated room in the manufacturer Alstom’s factory in Derby, full-size wooden mock-ups of the train interiors to the contracted specifications have been constructed for diverse user groups to test.
Transilien
10 Mar 2024
Ayrshire
I hope the lights aren’t as bright in the production trains! It reminds of the IET’s interior with it’s blindingly light LED’s.
Disappointed they've gone with the FISA LEAN seat. It's an awful design that wastes space, leads to poor legroom and isn't particularly comfortable. Really should do a lot better for a premium high speed train.
Mock-ups don't always reflect the actual turn out on train interiors, once the bean-counters have got involved.
I note they have Avanti people involved, as part of the original West Coast Partnership franchise scope.
That might well change when GBR takes over.
DanNCL
17 Jul 2017
County Durham
They say they want the most comfortable train and then they pick an existing seat that, whilst not an ironing board, isn’t great…
Interesting that even the standard class seats are to recline though.
Edit: just seen that whilst it’s the FISA LEAN in the mock-up, that’s not what’ll be in the final interior and that a new seat is being developed. The Yahoo article also has an image of what appears to be a wooden mock-up of a new seat, one that looks considerably nicer than the FISA LEAN. https://uk.news.yahoo.com/hs2-unvei...VGVk9qyHbvTla3InCJjNrHBFSJ57lS4U4C5uDZUbqjrSf
Which current trains use them?
196s, 745s and 755s
stuu
2 Sep 2011
It's very dull. It would be good if they could do something similar to the ICE Neos which have a lot of wood and very comfortable seats
800001
24 Oct 2015
I highly doubt that is the final colour scheme, if it’s just a mock up it won’t have the colours that the operator has/will chosen?
WMT 196s and Greater Anglia FLIRTs. And they're (stupidly, given how tight the legroom is) being fitted to Voyagers. They were also slated for Northern 195s but plans were changed, presumably because the already tight airline seating would have been uselessly tight.
The 755 seats are pretty good
To sit on they are sort of OK. But the thick seat back means poorer legroom than necessary.
Akela
20 Jun 2021
Wales
Can’t really say that screams “first class” to me - very spartan design.
That looks considerably better, respecting that a central niche is not a good design because tall people are usually men, and the male anatomy doesn't lend itself to sitting with knees pressed together.
Transilien
10 Mar 2024
Ayrshire
I get the feeling that the HS2 trains will just be faster IETs really considering they are basically Hitachi trains built in a joint venture with Bombardier (now Alstom).
RUK
5 Aug 2009
East of England
They’re said to be based more on the Italian Frecciarossa (Red Arrow) / ETR 1000 / Zefiro 300, built by AnsaldoBreda (now Hitachi Rail Italy) and Bombardier (now Alstom): https://en.wikipedia.org/wiki/Zefiro_(train)
An evolution of the Zefiro 300 platform was also offered by a joint venture between Bombardier (later Alstom) and Hitachi Rail for the HS2 rolling stocktender for its first phase, for which it was awarded the contract for 54 trainsets.[26]
Goldfish62
14 Feb 2010
Which, to be fair, isn't a bad train but still think ICE interiors are hard to beat.
Have you been on the ICE3 Neo with the new interior look that was introduced part-way through production? They really are lovely.
196s, 745s and 755s
Refurbished 458/4s use the Fisa LEAN2 which is a considerable upgrade from the original and very comfy.
trebor79
8 Mar 2018
Still bad legroom due to the badly designed thick back. The niches need to be at the sides.
I quite like the Fisa Lean seats, at least they are alright for Norwich to London 2 hours. I find leg room issues are caused by the enormous support bar on the window seats rather than the seat back.
Goldfish62
14 Feb 2010
The ones in the 458/4s lean back so you're not sat bolt upright (a posture surely only loved by the DfT) and have softer cushions.
It's HS2. Why does every viaduct on the route have a different design, construction methodology and maintenance regime?
Judging by the comfort (lack of) of off-the-shelf designs over the past decade or so I think it has merit. Get the design right and it can be adopted as the standard long-distance seat design and rolled out for Class 80x refurbishment.
AJDesiro
10 May 2019
Rugby
The legroom on the 458/4s is incredible, to the point where the position of the niches doesn't matter, the legroom is more than you get at the carriage ends on a 350/1.
It's less than it would be with a better designed seat. It might be that they've been generous with spacing, but then you have the opposite issue - too few seats. A well designed seat back maximises both legroom and capacity, as evidenced by the extra 2" or so you get on the new Pendolino seats compared to the old ones with the high density layout completely unchanged.
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
I've been on one but was a shortish journey so didn't really take much notice. Will have to look out for one.
Always found ICE interiors to be about as good as it gets.
Skie
22 Dec 2008
Regarding the toilets. It would be good if the sink fatalities weren't hidden behind a panel making you have to guess where to put hand's
I second this. Nothing worse than playing a guessing game, or having sensors so bad you need to scrabble round with wet hands touching mysterious nozzles until you find the Goldilocks zone.
Or receiving a giant dollop of goopy soap which you can’t possibly get off your hands with the thimble of water allotted to you. Which the anemic dryer can’t even evaporate.
The 390s are actually good in this regard, Virgin got the sink setup spot on towards the end of their run.
greyman42
14 Aug 2017
It depends what you call bad legroom and what you are expecting. If you are expecting to stretch out like you might at home then you are probably going to be disappointed.
