HS2 route seen from space-ish
9 Jul 2011
Visible due to the wide swathe of earthworks along the route.
Once it's finished and the surrounding, disturbed land has been restored, or landscaped, I doubt it'll be visible in that view.
z
LLivery
13 Jul 2014
Southeastern land
Was looking at this the other day, though unfortunately when you zoom in, most is no longer visible for now. You can also see the Madrid–Lisbon route under construction
Basil Jet
23 Apr 2022
It looks like they started from Birmingham heading for Heathrow, but after getting through the Chilterns they changed course for London instead.
Horizon22
Jobs & Careers
8 Sep 2019
This is all about map resolution.
See these two images, the one showing the "earthworks" is the Landsat image.
Crithylum
21 May 2024
London Borough of Ealing
View attachment 165734View attachment 165735
I think it is more to do with the age of the imagery, with the zoomed in being older. Apparently the Northern line has been running into an empty concrete box for the past few years at Battersea Power Station station.
Horizon22
Jobs & Careers
8 Sep 2019
Yes the age will be the main factor, although both are reportedly 2024.
