HS2 Class 895s (Hitachi Alstom High-Speed)
Just to be clear, are you saying this in the case for the Frecciarossa or the 895s? In the case of the former it would make sense, but I'd be surprised if it were the case of the latter since I expected the 895s to have a reduced profile in order to fit within the loading/structure gauge requirements.
Pendolinos are like that. The intermediates are roughly 24m and the end vehicles roughly 25m. You can do that in UK loading gauge provided you taper the nose.
lachlan
11 Aug 2019
And you say we're in for a treat ? I agree with you, I love the Pendolinos, there's something so "solid" and "tactile" about the whole thing/experience, they just feel like a lovely quality train through and through, nothing cheap or rattly. Just love them, especially in the new Avanti livery, there's something so special about seeing them pull into the modernist Euston with their sleek lines and elegant colours and knowing you're going to be whizzing through the British countryside at 125mph on a magic tilting ride :)
I feel like every time I end up on one I can't see out the window as the pillars are so wide and I end up with a seat beside a pillar. Coupled with the small size of the windows they feel a bit claustrophobic to me.
Hopefully the HS2 stock will be better in this regard though I read previously it has already been decided not to align the seats with the windows for HS2 :frown:
Sorcerer
20 May 2022
Indeed, but interestingly one thing I've noticed in the artist rendering of the 895s is that there might be a subtle tapering at the end of each coach similar to what we see on the 80x trains. It's hard to tell though on a second glance, but ultimately I still expect them to be uniform coach lengths with the nose not quite as streamlined as it's Italian counterpart. Allegedly the Pendolino design was originally going to be tapered like a Shinkansen but had to be scaled back, a design choice that I actually think works for the better.
MrJeeves
28 Aug 2015
Burgess Hill
I was told this at the HS2 event in Derby relating to the 895s.
This was referenced as part of the reason for no platform-edge doors, as the doors at the end units would be either further apart or closer together than the plug doors across the rest of the train's coaches, so any platform door system would require additional complexity both in terms of ensuring stopping positions are accurate, and additional doors to account for different unit lengths, coupled units, etc.
Yes, the middle carriages also had tapering at the vestibule ends in the door mock-ups.
Sorcerer
20 May 2022
Thank you very much for clarifying!
With regards to platform-edge doors I don't really think they're as important to long-distance high-speed rail services compared to frequent high-capacity metros anyway, so not having them doesn't seem like too great a loss. In fact I don't think I've seen them be used anywhere other than Japan, and that's only at stations where Shinkansen trains pass the platforms at high-speed rather than a middle set of tracks (which I believe will be the case with HS2).
MrJeeves
28 Aug 2015
Burgess Hill
Yes, I agree. It's not that big of a deal not to have them, especially if it causes complexity like this.
It would have been nice, though, given HS2 will largely work off of automatic train operation with ETCS L2.
Doomotron
25 Jun 2018
Kent
USB C is currently capable of up to 240 watts and by the time these things are in service likely even more. Unless you’re planning on hovering the trains I can’t think of many devices where that’s not enough?
240W won't be on train USB ports, and even dedicated chargers rarely have that high of a wattage. 60W is the plausible maximum, but having used USB Type A ports on trains, I'd bet on 12W at most. The vast majority of the time you're better off using a proper plug socket, and that's not just limited to trains.
rmHawk765
8 Apr 2025
ECML South
and HS2 goes straight into the WCML on the congested Trent Valley.
Yes, it will be a right headache timetabling them to just about fit in without causing delays to WCML services. And I suspect any slight delay will cause a domino effect (like it already often has).
The interiors of these really are gash. Grey and white, totally insipid. Sunglasses required once again. Enjoy all the tunnels it’ll go through in the 200mph dental surgery.
Absolutely pathetic interiors.
TT-ONR-NRN
30 Dec 2016
Cambridge
Have you not seen where it’s been stated, many times, that they used bland colours for the mock up deliberately, to keep the focus on the design and not the colour scheme, which will be finalised at a later date?
You reckon the interiors will have anything other than brilliant white lighting?
I will bet fifty pounds the interior will be almost exactly as shown.
I emboldened grey and white, not the part about the lighting.
I will bet fifty pounds the final interior will not have any colour beyond any that is necessary for visual accessibility. The claim that the reason it’s grey and boring at its first public reveal is 4D chess is not worthy of belief by anyone who has been following the rapid decline of ambience in train interiors in Britain.
It really is a horrific, soulless project despite being absolutely necessary. It’s like watching a major sewer being built.
Sorcerer
20 May 2022
I sort of disagree because at the very least sewers aren't really supposed to be anything beyond functional and will be unpleasant by their very nature but are still crucial pieces of infrastrucutre. But a new flagship high-speed train is there for all to see and something we have a vested interest in actively encouraging people to use, therefore it should actually have a duty to be comfortable and pleasant to travel on as well as functional and accessible. I have rather fond memories of travelling on the Frecciarossa (sadly not alone in Executive like you did though) and I hope the 895s at least try to be that good, but I kind of share the dread that they'll end up feeling much too clinical and lifeless.
SynthD
4 Apr 2020
Also, it's not a walkthrough train.
With sufficient boarding area markers on platforms (including north of Crewe), this probably won't have a negative effect, but it still feels unnatural. Perhaps people already used to seat assignments won't have this feeling.
Doomotron
25 Jun 2018
Kent
Go on any modern vehicle and you'll see it's just how modern design is. The bold and colourful designs that were prevalent ten years ago now look horrifically dated - just go on the P&O Spirit of France and you'll see what I mean.
You don't have a problem with the trains themselves, you just don't like modern design. That's okay, I long for the return of the Aqua/Aero look myself, but it isn't a valid criticism of the train itself.
I actually quite like the colour scheme they have used. The grey around the windows adds a bit of class over beige or white (I think that works really well on the Lizzie 345s). Indeed the scheme seems rather close to that!
(Yes I know that it isn't necessarily finalised - but I'd be quite happy if it was!)
FWIW the Pioneer (the newish double ended ferry) has an interior scheme straight out of Ikea, but I really do like it, it's quite classy. Maybe more fake wood would help?
Any modern vehicle *where*? There isn’t a global standard for “boring interior”.
Well, it is - are you suggesting the interior isn’t part of the train?
Which components of the train actually count as part of it in your view? The brakes? Driver’s console? Overhead racks? Accessible toilet door?
You say boring, I say classy.
There is boring out there, the original GWR 800 interior was beyond drab with that horrible lime green which just reminds me of grab poles in 1990s buses. But the Class 345 interior to me is *classy*, and this is basically a near copy. It's also quite similar to the ICE interior but without the very 1990s chrome accents.
Sorcerer
20 May 2022
I disagree about grey looking classy. It works for the Class 345 interior but I feel like for a flagship high-speed train we need something a bit less industrial. Something like a bronze chrome colour. Not quite as expensive or extravagant as gold but also not so dull and common as grey, and something that still looks good with predominantly white interior panelling. I can't quite put a name on the colour so do excuse me if it's a bit hard to imagine.
I know exactly what you mean and it belongs in about 1995. Emirates have that sort of scheme in their premium classes and it looks hideous.
Sorcerer
20 May 2022
I wasn't thinking of the fake wooden panelling, I was thinking more metallic. On second thoughts I'm not too sure about the idea anyway, and seeing another Italian train interior actually warmed me up to darker colours on the window pillars, but the interior will definitely need the right carpet, seat and table colours to make it work.
Doomotron
25 Jun 2018
Kent
I've been on the Pioneer and Liberte very frequently and while the first impressions have been good, I actually really dislike them now. The interiors are very low-quality and P&O aren't very good at maintaining it. There are doors that don't open and close properly, collapsed seats, exposed wires, smashed screens, etcetera. The Spirit of Britain and France, while dated, were built to a much higher standard. And now that the Spirit of Britain is with Irish Ferries as the Oscar Wilde, their improved maintenance has really fixed up the mistreatment P&O gave it.
You misunderstood my post completely. I'm saying that the interior of the trains themselves isn't the issue; rather you don't like modern design trains that aren't just found in the 895s.
I dislike the ambience of some British modern train designs, yes. Not all “modern design” (I’m not sure what you mean by this or in what context - other types of design are available if you look more than 1000 miles from home!)
stuu
2 Sep 2011
I think the best solution for design would be to phone Siemens and ask if they could provide the same interior as the ICE 3 Neo, the wooden version
TRAX
2 Dec 2015
France
but why? What does it actually bring to the train and the service it provides to the fare paying passenger? Nothing.
A number has to be chosen anyway, so why not have some thinking behind it…
Copper ?
Sorcerer
20 May 2022
Copper ?
I was thinking of something along those lines, but also slightly leaning towards a lighter bronze tint. But for these kind of colours it'd probably be best kept for trimmings rather than the predominant panelling.
TRAX
2 Dec 2015
France
Yes, copper accents are usually pretty nice if done properly.
Starmill
18 May 2012
Bolton
Also, the demonstration 'buggy' area only had space for 1, or maybe 2, very small buggies. Not exactly ample provision.
Are you suggesting it's sensible to remove further seats on the off chance a third buggy user who can't fold the buggy boards that part of the train? While I'm sure your intentions are honourable I don't think the space would be used by buggies. Most people with them can fold them up or fit them in the available space.
Now if you were suggesting a dedicated children's section with something other than a bare carpet and a wall, plus seating / nursing area then maybe that'd make more sense.
