How long before a 'Sprinter' is preserved?
The popularity of steam would suggest that it is a factor.
I find, and have always found, the whole steam thing rather odd. People never seem particularly interested in steam - for example very few normals open windows to listen to the sound of the steam loco. Yet some people seem to feel cheated if their train isn’t steam.
I took a non-railway-enthusiast friend on the NYMR a few years ago, and he subsequently remarked that he actually found the diesel loco used on the Whitby section more interesting, yet we heard a few moans from others.
Anonymous10
19 Dec 2019
wales
I have been on a couple where the blind on the cab door was stuck up. Surprised heritage railways don't do that, or replace the later obscured glass with clear.
Steam doesn't equal interesting. Quieter yes pleasing smell yes (most would agree) more comfortable also yes but not interesting imo.
LowLevel
26 Oct 2013
I reckon somewhere will have a 153 very much sooner rather than later. They've got a bit of an odd cult following and the chances of more of the stored ones seeing use seems to be receding.
Anonymous10
19 Dec 2019
wales
Half a 2-car unit ceases to be a sprinter. How many (hundreds of) hours have you travelled on one? My opinion is sound as far as I am concerned.
I gather the drivers found out that one of the cabs was unacceptably cramped too - as it still is.
As a regular long distance passenger on a 153 I'll freely say I prefer them in double formation to a 150, and would count them as a sprinter as they are mechanically extremely similar.
I'd imagine unlikely for preserved railways, given that third gen BR rolling stock look out of place at a 1960s station. I'd imagine it'll be less likely for a mainline charter company to preserve a Sprinter unit in that regard.
Sprinters are second gen.
Iskra
11 Jun 2014
West Riding
Network Rail seem to be using a few already. By the time NR have finished with them they might have a bit more heritage appeal.
As flawed as they are in some ways, they are still a way better travelling experience than a Pacer, of which many are preserved, so I concur.
43096
23 Nov 2015
There is absolutely no logic to that whatsoever.
A 153 is still a Sprinter.
61653 HTAFC
18 Dec 2012
You also can't on a 143 unsure about 144s
Not on 144s either- they're basically identical to 143s apart from (i) being built by a different contractor; (ii) a difference in ride-height of around 5mm; (iii) ten of them having three cars; and (iv) being slightly less prone to bursting into flames.
I'm now trying to remember if 141s ever allowed a view out of the front. I've a vague memory of them having glazing in the cab back wall at least until they were refurbished, but can't rely on that recollection to be accurate. There doesn't seem to be any images available online which would confirm or deny this, unfortunately.
m79900
28 May 2023
North Derbyshire
This is probably worth nothing, but the group that owns 144003 at the Great Central are called the GCR 2nd generation DMU group. That might imply they have plans to acquire a Sprinter.
Anonymous10
19 Dec 2019
wales
Atw really did like them firy huh. Both 143s and 175s
Mikey C
11 Feb 2013
153s and indeed the 156s would be perfect for heritage railways, where seeing out is a major part of the experience, though the higher window line of the 153/155 is a negative. 150s, like their EMU Mk3 cousins and the earlier PEPs, have massive areas taken up by the doors and door pockets which block the view out. The aircon of the 158s is added cost and complication to maintain, maybe they'll be retrofitted with more opening windows if used by heritage railways?
Indeed that's one big advantage of the Pacers, their glassiness. Comfort is far less important on what is likely to be a short journey.
To be fair you could re-seat a 150 with a bay matching each window, though it would mean quite low capacity.
skyhigh
14 Sep 2014
The Aircon is only a relatively small part of the complex hydrostatic system on a 158 which requires a very expensive variable displacement pump. If that system isn't working you're going nowhere as the alternator won't be charging the batteries. They are a completely different kettle of fish to maintain than other 15x.
Mitchell Hurd
28 Oct 2017
I could see a 156 being sold as a panoramic unit, reseated to a much smaller number of seats aligned with the massive windows.
150s are harder to sell, the 20m Mk3 derived body just isn't interesting, even though it's been the workhorse of the commuter routes since the 80s. I'm sure someone will preserve one at least, but unlike Pacers they aren't interesting.
153/155 I could see going without any preserved. 158s probably have another 10-20 years before it needs worrying about, though will preserved lines want aircon stock? Similarly I could see 165s all being scrapped, particularly as they're hard to keep going with a lack of electronic spares.
Air-conditioned Mark 2's and Mark 3's are preserved so I can't see why 158's can't be preserved.
JKF
29 May 2019
I would have thought one of the original non-gangway fitted units would be destined for the national collection, as the introduction of sprinters was a big change, they replaced a lot of loco-hauled services more than they did first gen DMUs, running regional services rather than locals. Their appearance was quite exciting at the time, I remember the original unit appearing at Temple Meads on a test run back in the day.
it also appears that 150001 did some special runs on the Wirksworth branch, maybe this history would make it a good fit for the preserved group now running the line, which already has some excellently restored DMUs.
Sm5
21 Oct 2016
Class 141s like 142s had a drivers cab door, with a window in, but solid bulk heads, with advertising on.
I once saw a driver bouncing along happily at linespeed reading a novel through one of those windows, deeply engrossed, not a care in the world or even a glance at it passing by.
m79900
28 May 2023
North Derbyshire
It’d be great if the EVR got a 150, but I seriously doubt they’d be interested. They seem to have moved away from DMUs, most sat idle or loaned out, so I can’t see them getting a Sprinter.
43096
23 Nov 2015
Which preserved railway runs aircon Mk2/3 on service trains?
Midland Railway- Butterley does (1st/2nd July is next opportunity to sample them), GCRN did, Mid-Norfolk does.
The first two are/were not railway owned/maintained vehicles, but are maintained by 125 Group.
PacerTrain142
23 Aug 2016
Next to the Railway
Having commuted on them, they are most certainly not. Sprinters may be speedy, but a certain level of comfort is implied too!
Tbh, despite their name, I don't think sprinters (apart from maybe 158's) are particularly speedy, not by modern standards anyway. There top speed (75 mph, so motorway speeds) and acceleration is very similar to a pacer, and pacers aren't exactly rapid lol. They might be fast compared to 1st gen DMU's or loco hauled stock, but compared to most modern rolling stock they are quite sluggish. They might have been considered speedy when first introduced, but times have moved on.
150s are a curious one. The original facing seat layout is fine, but I’ve never been a fan of the 150/2 layout with 2+3 airline seating. GWR and TFL have refurbished theirs to a much better layout, to the point where they’re actually rather nice to travel in - indeed for the first time I’ve actually grown to like 150/2s. I certainly wouldn’t mind some being preserved.
I don't like facing seats on trains, hate having to look at other people sat opposite me, I feel so awkward. I much prefer trains with seats facing all the same way (like ex-merseyrail 142's for example...)
I much prefer this seating layout:
To this...
The refurbished version from TFW looks slightly better but hardly impressive:
Tbh the 150 is probably my least favourite DMU. It is still old and noisy but lacks the charm and nostalgia that the pacer has.
With first gen DMU you can see into the drivers cab and out the front. That makes the view much better than you are going to get in a sprinter.
I can't remember if you can see out the front of a pacer as a passenger?
No you cannot, but on the class 142 units with low back seating and plenty of windows, provides excellent visibility.
Interestingly, I was on a heritage railway recently where a Pacer was in use. The general public was either ambivalent or expressed pleasure at the ride (quote one elderly lady: "Oooh, this is much more modern!"). Maybe the forward view and old-fashioned-ness are not essential in the right circumstances.
Well I've never heard someone call a pacer "modern" before! :o I like pacers because they are old fashioned and feel old fashioned. They might have been considered modern when first introduced, with their bright interiors and automatic doors, but that novelty would have gone away very quickly. They are modern compared to a steam engine or a class 101 lol.
The driver was reading a book while driving the train??? :o
Tbh I think sprinters are still too modern for heritage railways. Some people even think pacers are too modern for heritage railways. While the 150's were built around the same time as the pacers, they still feel quite a bit more modern. They don't have that retro feel that the pacer has. What amazes me is that the class 158's were built only a few years after the pacers, but you would never think so, they feel so much more modern, you'd think they were built in the late 90's or early 2000's.
Pacers, while being widely hated, are an iconic and unique train, and in recent years they have got more attention after being on the media and have developed quite a few fans and followers (me being one of them). Class 150's however, while not hated to the same extent as pacers, are not really iconic or unique in any way and are generally not well liked by the public either. They don't have the same character as pacers and there aren't many "sprinter lovers" unlike pacers, which do have a sizable following and have become a kind of marmite train.
150249
13 Dec 2021
The better Devon city
I would've thought that the best purchase for a railway would be 2 GWR or TfW 150/2s. Decent reliable trains with a good seating arrangement and a gangway. 150249 better get preserved. :{:lol:
m79900
28 May 2023
North Derbyshire
But there weren't many Pacer lovers until they were withdrawn either. I think it's a case of you miss it when it's gone.
Fawkes Cat
8 May 2017
I'd imagine unlikely for preserved railways, given that third second gen BR rolling stock look out of place at a 1960s station. I'd imagine it'll be less likely for a mainline charter company to preserve a Sprinter unit in that regard.
I've sometimes wondered whether a leaf could be taken out of the Hastings DEMU people's book, and someone obtain a 150/1, a 150/2 and a 156. It seems to me that these could be marshalled as two car trains, four cars or six cars - with through corridors in the six car formation if the 150/1 was split to have the cabs at each end of the consist. Then this could do mainline stuff in much the same way as the Hastings does - as well as preserving two widespread (even if not iconic) unit types.
On the other hand....
So maybe my cunning plan wouldn't go down too well with the real railway if booked for a mainline excursion.
The exile
31 Mar 2010
Somerset
Their acceleration compared to a first generation power/trailer DMU or loco + a few Mk.Is was certainly a noticeable improvement (about the only one!)
It’s worth considering that pacers were probably no more hated by commuters than the “dirty, smelly old steam train” that Joe Public now goes on a day trip to ride on had been 40 years previously. Nostalgia always looks through rose tinted spectacles!
