How are speed limits set?
Irascible
21 Apr 2020
Dyfneint
Speed limits around bends are set for passenger comfort. Hence when BR resarch showed that it was possible for trains to go 40% faster round the bends without risk of derailment, they proposed the Advanced Passenger Train with tilt so that it could go 40% faster round the bends.
Technically that's cant deficiency ( the APT showed you don't want 0 cant deficiency because it made people a bit uncomfortable ). There's RSSB documents defining limits & discussing the matter, as usual.
ptreanor
2 May 2017
Exeter
How long the blocks are , are based on the speed/stopping distance are they not?
That's one of factors.
What comes first? Do we say "we want a 100mph railway, design the signals to cope with it" Or do we say "This is where the signals are, how fast can we go?"
Both of these factors are taken into account. The distance between the first caution (yellow) aspect and the associated stop signal should not be less than service (normal) braking distance.
Railsigns
15 Feb 2010
Not impossible to calculate. Just have two scales, one without cant and one with various degrees of cant to 4%.
That's great. Now all we need is an Ordnance Survey map that shows the cant of every curve.
Railsigns
15 Feb 2010
Being purile [sic] is unnecessary on this site. The cant levels would be on a gauge not the map.
I'm sorry, but your original question was about the viability of determining the maximum speed over a curve using only a gauge laid on an OS map. You can't determine the maximum speed of a curve without knowing both the radius and the cant.
… and various degrees of cant deficiency.
(Pedant alert - cant and cant deficiency on the NR network are measured in mm, or degrees, but not %)
snowball
4 Mar 2013
However, for standard gauge track, degrees of cant (or of CD) is almost the same thing as inches of cant (or of CD), because there are 57.3 degrees in a radian, which is almost the same as the gauge in inches.
CEN60
17 Dec 2018
I’ll save you all the OS Pain - it is not accurate enough to calculate an accurate speed (or even indicative speed) in fact the OS grid system is not accurate enough for long track alignments, hence the boffins at UCL created a thing called Snakegrid. Also for the cant pedants above 25mm of cant is approx 1 degree of rotation of the rails across the track gauge! NR do not have an OS Map with the cant of every curve. However NR in Scotland have programme of running trains with vehicle mounted laser scanners, from which the rails are digitised and strung into strings of Digital CAD points - these all can have radii and existing cant extracted for use in speed calculations.
mcmad
11 Mar 2015
You can determine the maximum theoretical speed of any curve by using maximum cant and deficiency values.
CEN60
17 Dec 2018
The max theoretical speed also depends on material type also (rail type / sleepers / ballast depth)
deltic08
26 Aug 2013
North
Yes I knew that. Why I said percentage I don't know.
Is It possible to determine a speed of curve from a map. I asked the original question because the overall linespeed from Leeds to Harrogate has been 60mph for ever even though heritage DMUs would exit out of the bottom of Bramhope tunnel doing 70mph and hold this speed before braking at Pannal for Crimple Jnc.
In the 1970s I rode in the cab of a late running Deltic+8 empty stock move from Neville Hill for a morning Harrogate-London train. We travelled up to Horsforth at over 70(then 45mph psr at Horsforth) and exited Bramhope at over 80mph. The ride was smooth and with no banging flanges
The Leeds-Harrogate line was resignalled in 2013 with more sections and better signal sighting for shorter headways and increased capacity. It was also claimed in the local media that it was signalled for a linespeed of 75mph. Still no hint of an increase in speed.
What I want to know is will the present curvature+cant allow 75mph regardless of past illegal speeds on the route?
CEN60
17 Dec 2018
After a recent change to the relevant NR Standard unless you know the type and age of rail, sleepers, sleeper spacing, clips etc - you cannot calculate the theoretical maximum speed a curve with a set amount of cant can achieve.
snowball
4 Mar 2013
However, all those are things that are far easier and cheaper to change than the radius of the curve. Changing the radius of the curve is likely to involve land purchase and statutory processes.
CEN60
17 Dec 2018
Correct - but the issue was calculating speed from a map - my statement still stands - ie a map does not give you all the info you need.
Lurcheroo
21 Sep 2021
Wales
We say the former (and we want this timetable with these trains so make sure it can accommodate that too please).
Out of curiosity, surely if a brand new rail line was being built and it was planned for a certain end to end running time then it would be determined what speeds would need to be achieved and therefore what sort of signal spacing you need to have ‘service breaking distance’, as well as some other factors like wether you have 3 or 4 aspect signalling and signal sighting.
But if you were just looking to improve journey times on an already built line with functional signalling then you use the “this is where the signals are, how fast can we go” method ?
Don’t work in signalling at all, just my electrical engineer brains way of thinking so apologies if it’s totally off!
CarrotPie
18 Mar 2021
Essentially, yes, unless there's unless money around to change that (or, more likely, remodel junctions and stations to achieve a similar effect).
Lurcheroo
21 Sep 2021
Wales
Ahh ok that’s cool ! Yeah of course, kind of forgot that it’s possible to re-signal an area if it’s needed as part of the improvements haha !
Thanks for the info :D
deltic08
26 Aug 2013
North
The majority of the line between Horsforth and Harrogate was relaid with cwr on concrete sleepers between 1970-1976 when I was a daily commuter. As Harrogate-London trains are no longer loco-hauled and other services predominantly DMU operated, I presume stress and wear on the rail is much less on curves than it was so curving speed could be higher on current track. Is that logical?
Annetts key
13 Feb 2021
West is best
In many cases, the documentation for the signalling system already has enough information for the maximum speed to be calculated.
For lines that existed before colour light signalling was installed, the speed is determined by money. As in the amount of investment that was used to build the line, the cost of on going maintenance and the type of trains using the line (no point designing, building and maintaining a line for 110MPH if the fastest trains normally using it are limited to 75MPH).
Lines with higher speeds cost more in both design of the permanent way and the cost of on going maintenance.
So for existing lines, the signalling is designed for the current requirements within the limits of the permanent way and taking certain other things into account (e.g. junctions, terminal or complex stations). The signal spacing and type (two aspect, three aspect, four aspect) is also determined by the type of train (stopping services, fast/express services, high speed services, freight) and how many trains per hour have been specified for that section of line.
There are solutions for signals that may have insufficient sighting distance (banner signals for example). Although an alternative signal position may also be considered, as there may be some "wiggle room".
For new lines, then yes, the requirements will be determined for what is required to meet the specification. Both the permanent way and the signalling will be designed to meet the specification.
Just as the cost of the permanent way is affected by the specified line speed, the cost of the signalling is also partly determined by the line speed. However, the required line capacity (trains per hour) has a bigger effect on costs. You can have a 125MPH line using two aspect signalling. You can't have an intensive commuter line with two aspect signalling if that line is also a high speed line or it has mixed traffic...
When a line or area is resignalled, again, cost is a major factor. A lower cost scheme will often reuse existing signals/structures/signal positions. A more expensive scheme may completely redesign the signal spacing and signal positions. Especially if work is being done to raise line speeds.
John Smith 19
13 Aug 2023
Newby here. One of the members has mentioned that 80 or more factors are used to set a speed limit and I just wondered is there anywhere they are actually listed?
Also does the list of factors consider lengthen as the speed rises? So I know over 100mph you have to move safety cabins further away from the line and IIRC anything over 125 requires in cab signalling. I'm wondering if there's a baseline list then a series of "contours" that lengthens it as the speed rises.
The other thing I wonder about is whether there is a formal system that reviews speed limits. With about 10 000 miles of track there's got to be a lot speed restrictions to track. It seems way to big a job for a spreadsheet. I read that the Birmingham/Manchester track distance is 80m65ch and the average journey time is 1:39. That's just under 49mph, yet all the trains that run it can hit 125mph. What's going on? High speed rail is nice, but why can't we have full speed rail in the meantime?
hexagon789
2 Sep 2016
Just because they can achieve 125mph doesn't mean they can run at 125mph though. The exit from Birmingham New Street and the line on to Wolverhampton in particular isn't very fast.
jfollows
26 Feb 2011
Wilmslow
HS2 is the solution, but Rishi didn't think it was necessary so he cancelled it.
More realistically, Birmingham-Manchester has too many station calls and too many speed restrictions along the route. And it's not sensitive to the time it takes - if you eliminate the station stops you get fewer passengers because they're well used and few people care about the end-to-end journey time, which still compares well with the road journey. Marginal improvements have been made over time, so it's no longer 85mph maximum Stafford-Cheadle Hulme as it was in the 1970s, but having some parts of that route capable of 100mph makes little difference.
There is a Railway Standard on the subject. It lists the factors,with the proviso ‘this is not an exclusive list’
Sort of, in that some issues only kick in at certain speeds, however you will still need to demonstrate that the risk is managed. For example, raising the speed through a platform you would need to demonstrate that any additional risk to waiting passengers is mitigated, and depending on what is on the platform you may need to do aerodynamic assessments. If it is on a curve, it would need gauging checks for the new kinematic envelope. If the proposed new linespeed is over 125mph, the platform can not be open to passengers while trains pass, and you would have to demonstarate how that would be achieved.
Each speed restriction is reviewed on a case by case basis as and when someone decides to look at it for a business reason.
John Smith 19
13 Aug 2023
My point exactly. Drivers I've spoken to at New Street say there's a different speed limit leaving every platform.
This seems to me to be a circular argument. "The line cannot support faster trains so we need faster trains running on a new line." New rolling stock can take years to get authorised and more years to get built. It's not like we don't know how to speed up a line.
I can't shake the feeling that there does not seem to be much "joined up" thinking going on.
Interesting. OK interesting to me. Do you have it's name or number? Could I find it on the RSSB website?
Thought that might be the case. 100mph seems to be the point at which all sorts of stuff has be re-considered. It's just that average line speed is so far below what the existing rolling stock can manage. Yes I know a lot of the network shares lines between freight and passengers. But various reports from Lithuania Railways and the Germans reckon a key parameter here is raising the speed of the slowest train on the line.
AIUI top speed on freight hasn't been reviewed since the late 60's, following a single train derailment when a freight with unsprung cars and caboose/locomotive braking only derailed. This is (AIUI) still common in the US but was phased by the mid 80's at the very latest. No UK freight has run like that in close to 40 years.
If that's right then a key reason for that top speed no longer exists, and hasn't for quite a while.
So hypothetically there could speed restrictions that have not been reviewed for decades, regardless of the improvements in brake technology over the decades?
We do, and (for example) Eastern Region knew how back in the 70s, but I'm not really sure what your point is.
If you're referring to Birmingham-Manchester again, by the time you've made 5 stops and got through the Birmingham-Wolverhampton section that's added 25mim to a theoretical nonstop time. Then there's awkward restrictions at Stafford, Stone, Congleton and Cheadle Hulme... there was another at Norton Bridge but NR spent a vast amount to improve the junction there.
Agreed - so a 75mph freight and a stopping passenger maintain similar times.
I think you have misunderstood. The 60s issues were about short-wheelbase 4-wheel wagons, which (among other things) didn't take kindly to continuous welded rail and to higher speeds. A great deal of work went into producing freight stock that would perform well at 75mph (leading BTW to the Pacer railbus!).
No UK freight has run like that in close to 40 years. If that's right then a key reason for that top speed no longer exists, and hasn't for quite a while.
And no (?) UK freight is timed for anything less than 60mph, while intermodals are 75mph typically.
Not sure brake technology is the issue so much as vehicle performance.
And the freight operators would be pushing for limits to be relaxed if there was an engineering and business case. And for better pathing so they didn't sit in loops for hours. But rebuilding junctions or whole sections of line for higher speed is expensive and disruptive - hence the idea of building new lines....
PS welcome to the forum!
The drivers you are speaking to are either winding you up, or not competent. The speed on departure from every platform at Birmingham New St is 10mph, and has been for over half a century.
If rolling stock with different braking characteristics is used on a line, and the operator has requested it, the linespeeds will have been reviewed.
Envoy
29 Aug 2014
West of Swansea, line speeds seem to be on the slow side - maximum of 75mph I think - even on straight sections such as Cockett to Llanelli and Carmarthen to Whitland.
