Help with route in Train Sim.
Class325Guy
14 Mar 2019
So one of my favorite routes to drive in TS is the WCML Northwest and Scotland Route from Alan Thomson. The only problem I have is that if I want to make a scenario, I cannot select Preston as the starting point and will have to start somewhere else and move the scenario marker manually, so the scenario will load up where I want.
So how can I add a place to the list, so I can select it as a starting point when I go to make a scenario.
Thanks
Darandio
24 Feb 2007
If you come across a similar situation on another route in the future, there is an easy way to place a scenario marker wherever you want so you don't need to move markers around from predefined locations.
  • Go the build menu, select your route and click edit.
  • Once the route has loaded, click the train (scenario tools) from the top left menu to open the scenario editor.
  • Press 9 on the keyboard to open the 2D map, zoom out using the scroll wheel and use the right mouse button to drag the map around.
  • Once you know which location you want to be at, press control and left click on that location to center the map.
  • Go to the top menu (compass and coordinates) and click the little go arrow button then right click the mouse to leave the map.
  • You should now be in the location you selected, if underground just use the controls to move around or press Ctrl, Shift & Home for ground level.
  • In the middle left menu select the scenario markers button. Select and place the scenario marker of your choice in the desired location.
