Have Lumo cut the right services in response to engineering work?
Lumo's full weekday timetable has departures from Kings Cross at 0545, 1045, 1218, 1436 and 2018 and from Edinburgh at 0614, 0911, 1114, 1612 and 1958. The timetable needs four units to work, two stabled at each end.
In response to engineering work that prevents the 2018 from Kings Cross running north of Newcastle, Lumo has had to start the 0614 at Newcastle.
Is this the right change?
It is difficult to see other options. They presumably can't be offered a different earlier path from Kings Cross as that isn't in their access rights. However, they could have axed the 1958 from Edinburgh and 2018 from Kings Cross throughout to enable the 0614 to run throughout but it would leave them as a morning / afternoon operator.
Should Lumo even be allowed to run any services just between London and Newcastle on weekdays if the pretence is that the services are targeting the air flight market between London and Edinburgh?
Are engineering possessions and inability to run the full service (as seen on weekends for most of the last five months) going to be the downfall for their operation?
I think it won't be their downfall, as single fare pricing in operation on the ECML means you can easily use them one way and LNER the other.
They do however need to stop opening trains for sale they don't know they can run.
Without knowing the details of their access rights, the engineering block presumably is large enough that a flex in their schedule doesn't solve it. I would be very surprised if their rights fix their paths to the degree they have no wriggle room.
The other question is why they can't get the unit stabling overnight in Newcastle through to Edinburgh empty to form the second 0911 departure. Presumably this comes down to there being no path from Newcastle to Edinburgh or just no desire as it adds more costs to the operation than simply starting the 0614 short.
EDIT - it does look like this Q path exists from the timetable change in May
