GWR Intercity EMU?
Clarence Yard
18 Dec 2014
They actually are the best of the voyager breed - you don’t have the stinky toilet smell in the coach and they don’t half motor, even with an engine out. Terrific acceleration too - the HT ones used to regularly get let out in front of the 91’s because they would always stay well away from them.
However, we are going a bit off-topic here.
Dan G
12 May 2021
Exeter
You are not going to need 9 car trains at all times of the day I don't suspect whether the trains are travelling London - Plymouth, London to Cardiff/Swansea or London - The Costwolds etc....
As there is not enough 9 car class 80X trains, then certainly for the time being you will have two five car class 80x units coupled together, which GWR last I check do seem to have a surplus of in their stock.
So far as I can tell, 5-car IETs spend their time working the Cotswolds line off-peak, London to South Wales, some Cardiff to Plymouth/Penzance, and Penzance-Plymouth. In the near future they'll do all Cardiff to Plymouth/Penzance work replacing the Castle class.
What's actually the problem with that?
RobShipway
20 Sep 2009
Nothing, but if you read before my post that you have quoted you will see that some where saying that 9-car trains where also needed on the Cotswolds line off-peak as well as all day to Bristol, Plymouth and Cardiff, yet when I have travelled along the Cotswold line previously when it was HST sets doing the route, barely 4 out of the 8 coaches where full. You also have to remember that if you have 9-car trains on the Cotwolds all day, then you will be needed to extend the platforms. That will only happen as per @Clarence Yard comment below:
Actually, it was 5 from Plymouth to Penzance, except in high summer, when 9 or 10 should have taken place on most of the trains because there would have been the equivalent of two extra 5 cars cycling between Plymouth and Penzance. But Hitachi fell short on that one.
Snow1964, the DfT plan was rubbish. Splitting and joining at Swindon to serve two destinations? What could possibly go wrong?! That was just one of the many errors that the “great cartographer” presided over.
The late Roger Watkins and I had fun getting the draft 2019 timetable right with the right stock on the right trains and it all meeting the cascade and maintenance requirements in the contract. It was executed well, by GWR at least.
When Hitachi can only put out 67% of their fleet, to meet 83% of their contracted requirement, you are going to get short forms.
Getting back to the subject of this thread, you will need a lot more wiring to make a GWR 9 car intercity EMU a viable proposition.
There is also the point that GWR do have spare 5-car IET units which can be replacing the HST castles as of now anyway.
The only way that I can see the platforms on the Cotswold line being extended, if there is space to is if the line is electrified. Once you have this and electrification down to Plymouth/Penzance, then you are more likely to be having some 5 car units that are currently doing London - to Plymouth/Penzance either singularly or in multiple extended to be 9 cars.
Energy
29 Dec 2018
They already run 9 car peak on those platforms. You'd only need to extend for 10 car services.
It isn't dependant on electrification.
London to Plymouth/Penzance is mostly 9 car already. In short, excess+freed 5 car 800s run half the services to Swansea (the ones which extend to Carmathen). The freed up 9 car 800 sets can now run in place of the 9 car peak extra 802s which can now run instead of 10 car 802s on most of Plymouth/Penzance.
As such out of the 802s, 14 5 cars run Cardiff-Penzance and the remaining 8 run as 4 10 car sets alongside the 14 9 car units on London to Plymouth/Penzance.
This isn't exact as 9 car 800s also run to Plymouth/Penzance but will be closer to the true operations when the 802s are more permanently based at Laira.
Dan G
12 May 2021
Exeter
So the only awkward limitation for the 5-cars seems to be their inability to run as 2x5 10-cars on the Cotswolds line.
Doctor Fegg
9 Nov 2010
Charlbury
The platform lengthening a few years ago was ostensibly to allow 2x5 IETs to run among other reasons. What remains to be done?
Clarence Yard
18 Dec 2014
Tracks and track circuits. The 10 cars are too long for several operational reasons - hence why the extra 9 cars were ordered rather than extra 5’s.
Stuart Baker didn’t “do” track and signalling. He assumed that if you could fit a train or the accessible parts of a train onto the platform, it was job solved!
Rhydgaled
25 Nov 2010
You’ve mentioned class 803’s quite a lot as some kind of bi-mode solution due to their battery pack. Forgive me if I’m wrong but I thought that this battery pack under one coach was purely for hotel power in the event of a train being stranded and can be used in last mile limp home mode. I’m not sure an 803 would make it far off the wires as you keep suggesting.
Sorry if I gave that impression (re. using a class 803 away from the wires), it was not my intent. What I am trying to do (as far as 803s are concerned) is argue for the following:
  1. completion of the delayed elements of GWEP (ie. electrification to Bristol (via both routes) and Oxford
  2. reinstatement of electrification between Cardiff and Swansea
  3. the conversion of some of GWR's 5-car bi-mode IETs (class 800 and/or class 802) to 9-car IET EMUs (class 803s) to take advantage of the extended electrification
The class 803s would therefore only be used under the wires.
An easy way to estimate is round trip in hours x tph. Then divide by 0.8 to assume 80% availability in sets. This will give a rough estimation, in the real world there is inter working between routes and some fairly inefficient diagrams.
Thanks. So, assuming the additional (compared to today) electrification in points 1 and 2 above, the basic hourly pattern could look a bit like this (the 'base units' are the round trip time x tph, rounded up to the nearest integer):
FrequencyPaddington To/FromTraction TypeNotesBase Travel TimeBase Units
1tphSwanseaEMU (class 803)2hrs 50 (2.8333)6
1tphCardiffEMU (class 803)2hrs4
1.5tphBristol Temple MeadsEMU (class 803)1hr 35 (1.5833)5
1tphOxfordEMU (class 803)55mins (0.9166)2
1tphCheltenham SpaBi-Mode (class 800/802)2hrs4
0.5tphWeston-Super-MareBi-Mode (class 800/802)Some continue to Exeter etc.2hrs 12 (2.2)3
1tphGreat MalvernBi-Mode (class 800/802)Some short workings to Worcester, extensions to Hereford etc.2hrs 25 (2.4166)5
0.5tphExeter (semi-fast)Bi-Mode (class 800/802)Some continue to Paignton etc.2hrs 30 (2.5)3
0.5tphPlymouthBi-Mode (class 800/802)3hrs 12 (3.2)4
0.5tphPenzanceBi-Mode (class 800/802)5hrs 20 (5.3333)6
These are very rough figures of course, partly because of the various extension and short workings from the basic pattern, but they add up to 17 electric diagrams and 25 bi-mode diagrams. Divide by 0.8 and I get 21.25 for the EMUs and 31.25 for the bi-modes. If I add those together and round up the total is a fleet of 53 units. If GWR were to couple all their 5-car IETs into pairs, they would have 29 ten-car and 35 nine-car trains, a total of 64 units.
The IEP contract has a mechanism to convert 800s to 801s.
What about converting 800s to 803s, to release all the gensets under any given 800 so that they can all be used under bi-modes elsewhere? The way I see it:
  • class 800s are potentially useful bi-modes
  • class 801s are useless bi-modes or impure electrics
  • class 802s are potentially useful bi-modes
  • class 803s are pure EMUs
  • class 805s are presumably the same as 802s (but, if so why the different class number?)
  • the traction capabilities of class 807s are a mystery
  • class 810s are potentially useful bi-modes, with higher off-wire performance
Agreed. I'm thinking from a contract standpoint. Removing engines form the 800s is within the IEP contracts, lengthening units however is easier with the 802 lease.
A further complication is that, to make good use of many electric units, would need wires to Swansea and the Hitachi/Agility (whoever it is) depot there would mainly see only electric units (class 803) there in my scenario. Anyway, take either the 22 five-car class 802s or the 36 five-car class 800s, lengthen them all (half to nine-cars for GWR and the other half to 8 (if possible) or nine for XC) and stick all the gensets under the units for XC* leaving the newly-lengthened GWR nine-car sets as class 803s with no diesel gensets. The XC sets would have rather more gensets than the GWR/LNER class 800s/802s, but I'm assuming that XC (like EMR with the 810s) require higher off-wire performance.
Some ten car (5+5) IET set’s actually run in service with the rear half (five cars) empty. That’s the reality annoying thing. You get on at Paddington (all ten cars available for use), but have to get out and get back in at Bristol T.M. to continue your journey to Weston-super-Mare or any of the intermediate stations because they take the rear five cars out of service.
This is one of the reasons I'm a bit keen to cut Carmarthen back to one train a day to/from Paddington. Having non-gangwayed units coupled together which divide on-route (or, potentially, call at certain short platforms) means some passengers effectively have an unadvertised and unplanned change of train somewhere in order to move to the correct part of the train before it splits. It's not so bad in the other direction (where the units join rather than spliting) as no passenger should need to move (except perhaps for a short platform) but really I think the aim should be for almost all trains to be gangwayed throughout. That means it's ok for a TOC to order something like a 377 with only 3 coaches because they can work in multiple but streamlined intercity stock doesn't have gangwayed cabs so please don't order them with portion working in mind.
I don’t have enough information to give a detailed reply, but based on the satellite view and the photos that can be found, moving the signal nearer to the points may be possible along with moving the points for the single line loco spur further away from the station. Either one or a combination should give the extra distance required, along with, ideally a platform extension.
Moving the loco-release line at Carmarthen back to allow a 9-car IET in would also increase the walking distance for passengers between the platforms since there is no footbridge anymore and passengers have to use a barrow crossing to move between platforms. More importantly, Carmarthen is much further back in the electrification queue so, even if the platform were sorted, I think I would still be suggesting cutting it back to one GWR train per day (increasing to 3 at weekends, including the summer SAT Pembroke Dock workings) so that more use could be made of 9-car class 803s between Swansea and Paddington.
As we are learning, the whole IET thing is turning out to be full of awkward limitations. And because of the contracts, the railway is now rather stuck.
If it were possible and practical (which it’s sadly not), I would like to see the whole IET contract cancelled. Even if it means “scrapping” all the GW 80X trains. But in the real world we are now stuck with it.
It's not just IET - the railway (and indeed other transport matters) does indeed get rather stuck from time to time. Eg. when the Welsh Government froze their road-building programme for the review to be carried out they said that schemes which had 'diggers in the ground' would continue - however the contract had been 'signed' on at least one project just a few days before, there were no diggers anywhere near the ground at the time but the contract was there so work continued. Why would you scrap the GWR trains though? Yes they have issues but you'd have to buy out the 27.5yr (or whatever it was) IEP contract to anyway and we have them already so let's make the most of them - just buy out the contract (or use variations) to get the fleet we need. With a bit of luck there may be clauses in the contract for in-service refurbishments to at least allow replacement of the awful seats anyway.
RobShipway
20 Sep 2009
@Rhydgaled why would you convert the Class 800 and 802 to be class 803 units?
As far as I am aware the original idea for the class 800 and 802 units was that until electrification is completed throughout the GWR network, that they would be bi-mode trains. Once electrification is complete, the diesel engines within the class 800 and 802 would be removed. There is no suggestion in any details I have seen about the bi-mode IET units being renumbered, once the diesel engines have been removed.
The reasoning that the Class 805 units are not designated as Class 802, is that they are a different order to the class 802 units and also I believe have more diesel power generators in the class 805 units than in the class 802 units. There is also things like wireless inductive charging for electronic devices going to be made available on the class 805 units, which if my memory serves me correctly is not available on the class 802 units? Before you say well just add it to the class 802 units, they would have to be taken out of service and totally re - wired to have inductive charging for electronic devices to be added to the class 802 units I believe if they do not have it already.
Rhydgaled
25 Nov 2010
To take full advantage of additional electrification (to Bristol, Oxford and Swansea in the first instance) rather than GWR continuing to run class 800/802 bi-modes on the same routes but 'under the wires' following additional electrification.
I would have thought any bi-mode units converted to EMU would need to be renumbered. After all, when the order for 21 class 801s (strange units that kindof are trying to be EMUs and bi-modes at the same time and fail to achieve either) for GWR became an order for 21 bi-modes instead they were delivered as class 800s. I don't work in the rail industry so don't know for sure, but I get the impression that class (and/or subclass) designations are used for diagraming. For example, when a temporary hybrid unit was made up with a 153 and half a 150 it was numbered as a 153 because if it had been numbered as a 150 it could have been sent somewhere where the 153 was out-of-gauge. Similarly, you would need to be able to tell the difference between an EMU and a bi-mode so that the EMU allocated to a service to Penzance before the wires get anywhere near there. You can't just have a common pool of class 802s if the diesel engines have been removed from some of them - you need to renumber the electric-only units into a different class.
You don't need a different class number for interior changes - for example Arriva Trains Wales didn't renumber their class 158s when they refurbished the fleet and replaced the seats. Similarly, you could presumably have inductive charging on some class 802s and not others - I don't think the Pendolinos are even getting a different subclass when they go through Avanti's refurbishment. As for having more diesel generators on a class 805, that is very interesting if true since I believe the 5-car class 800 and 802 units already have the maximum number of gensets (three) for a 5-car set from that design (I believe the driving cars have a lower floor with no room for a diesel generator underneath). The class 810s I think are planned to have four gensets, but they have a new bodyshell design (shorter vehicles) so there was an opportunity to make room for the additional genset while redesigning the bodyshell.
Dan G
12 May 2021
Exeter
803s are 801s with batteries instead of a genset for emergency power, that's all. (A consequence being they can't move without external power, whereas 801s can, slowly.)
The 805s (and 807s) are numbered for marketing; there have been multiple orders for 802s and I've seen nothing to suggest that the 805s have different generator units or numbers of them (unlike the 810s).
The interior fit-out is entirely independent of the vehicle (a feature of the AT300) and doesn't influence the class numbering.
Neptune
29 May 2018
You seem confused about what an 801 is. It is an EMU with a single gen set which allows the train to limp out of the way if it fails or the wires are down. It also provides hotel power to the train in this situation to keep things like lighting, air con and toilets in use (useful when stranded). This genset is only used when absolutely needed.
An 803 is almost the same however it uses a battery rather than a genset. The downside of this is that the battery doesn’t enable the train to clear the mainline/limp into a station like the genset on the 801 does.
Now I know you have a real focus on not using any diesel whatsoever full stop but you also have to look at most of the population want in reality, and that reality for humans is, whether you like it or not, what is happening right now.
What is better, being stranded somewhere inaccessible due to the lack of power to move with flattening batteries (making the train dark, stuffy and losing the use of toilet facilities) or having a single low emission genset/donkey engine/whatever you want to call it, able to move people to at least a point of access to make either alternative arrangements or at least into a position to be rescued.
An 805 is effectively 5 car 802 and an 807 is effectively an 7 car 801. I believe AWC went for 805 (5 car) and 807 (7 car) for no other reason than they could.
It’s certainly nothing to do with the interiors as each company has their own say on this. The class 800 for instance, LNER has a buffet unlike GWR. Class 802, 3 very different seating layouts for GWR, TPE and HT.
Energy
29 Dec 2018
Hitachi charge a lot if the emergency engine is used. If IEP was done 5 years later it probably would have been a large battery rather than an engine.
805s are the same gensets but reduced to the normal 750hp IIRC to reduce wear, they don't need the extra performance.
The 800s have both engine ratings depending on the subclass so it is just marketing. In the original renders the 805s had 802 numbering.
Downside with converting to EMUs is without significant electrification you'd limit operations. GWR has imperfect fleet lengths, changing to EMUs would commit to these lengths long term.
However much you'd like it I doubt the government would be willing to chop Carmathen services.
Dan G
12 May 2021
Exeter
Do you know why the 810s changed to MTU engines in the generator units, @Energy ? Must have been expensive to re-engineer the rafts for a different engine.
Wasn't it consolidation in the manufacturers
MTU is owned by Rolls Royce, their brochure has pictures of GWR units built by Hitachi, series 1600 engines of 700Kw (939HP)
Annetts key
13 Feb 2021
West is best
There is a reason I put scrap in quotation marks. I don’t mean turn the trains into bean tins. I mean reuse them, but in a more sensible manner free of the current limitations, problems and restrictions.
Energy
29 Dec 2018
Always been MTU. The 810s have 4 of them, each the uprated 986hp, to match the class 222 timings. The
Dan G
12 May 2021
Exeter
Inexplicably I got it into my head that the 800s and 802s had Deutz engines! They have, of course, MTUs, and it's the same raft (different tune) on the 810s.
Rhydgaled
25 Nov 2010
Just as I thought.
I don't think I'm confused - you have described 801s and 803s to be exactly as I understand them. The only difference is that I refuse to call an 801 an EMU, because it does have the ability to limp along if the some scumbag steals the OHLE or there is a serious power cut in the power grid that supplies the OHLE. From an operational planning viewpoint an 801 might as well be an EMU, but from a technical/maintainance viewpoint there is a diesel engine to maintain and a fuel tank to fill up so technically it is a bi-mode but not useful as such because it is so slow in diesel mode.
The diesel engine will run out of fuel too at some point, and presumably 'hotel power' includes the toilets etc. so the batteries on the 803 will keep the passengers just as comfortable while stranded as the passengers on the 801. As far as I know the 801 is the only nominally 'electric' train (on the British network at least) which is able to move itself if the OHLE / 3rd rail is out of action. Anything similar like a class 73 or 88 is designed to run at least a little way on non-electrified routes. Therefore, in the event of an OHLE fault you will probably be stuck behind a 387 or something anyway.
There is therefore no advantage to being on a 801 vs an 803 in the vast majority of suituations - either would beat being stranded on a 387 though which I guess is the point. Thus, it seems to me that an 803 gives you 99% of the benefit of an 801 and the diesel engines under the 801s would be far more useful combined onto a smaller number of units to make more 800s/802s without increasing the total number of genset vehicles.
Does that mean they have a single diesel genset to allow them to 'limp' along if the wires are gone?
I suspect the 800s and 802s being different classes may have something to do with the different contractrual arrangements (ie. the IEP train service provision deal for the 800s). Also, I understand the 800s were originally supposed to have smaller fuel tanks and the lower engine ratings etc. but the GWR ones had to be upgraded to class 802 spec (and I think there is still a difference - perhaps brake resistors?) due to the delayed electrification.
Which is why I propose dealing with both issues: increase electrification (Oxford, Bristol and Swansea (or equivalent) as a bare minimum before the first batch of conversions to EMU) and lengthen units (carrying out the lengthening and moving of gensets/genset-vehicles (whichever is easier) between sets at the same time so each unit only needs to be taken out of service once to do the job).
A pair of 5-car bi-modes (and a number of new vehicles, not including any gensets or driving cars) would go into the works. A 9-car EMU* and an 8-or-9-car bi-mode unit (the latter for XC) would come out.
* with batteries to keep the lights, toilets etc. working in the event of no power from the OHLE gensets at all, but zero diesel gensets.
Until Swansea was dropped from the electrification programme, the Government at the time seemed happy to chop the Pembroke Dock services (which presumably would have resulted in Carmarthen-Paddington running just one per day Mon-Sat for the all year round). I assume the recent increase in GWR's weekday services to Carmarthen is a GWR initiative (as a response to Grand Union's open access plans, which I have not supported since they decided to run beyond the wires and order new 125mph bi-mode stock) and is not in GWR's contract with the Government. I certainly don't remember any comments regarding anything more than 1 train per day Mon-Sat (3 on Sundays) to Carmarthen being in the GWR franchise agreement last time it was re-franchised (obviously, when the wires to Swansea were cut, the Government finally committed to running the summer Saturday GWR trains to Pembroke Dock, which had previously been left out of IEP and provide an additional 2 calls each way at Carmarthen).
Neptune
29 May 2018
Feel free to call it what you like. Officially it is designated as an EMU.
They will be dead unless it’s switched off in which case no electric trains would be running
Extremely useful if it is used to get stranded passengers to an access point such as a station or do you think passengers should just have to sit and wait patiently for hours.
The batteries will run flat long before the fuel runs out. You don’t seem to like the fact that the 801 could potentially get passengers rescued a lot quicker than those sat on an 803 with flattening batteries.
There is always that risk so are you saying that trains shouldn’t be built with a self rescue mechanism because of that low percentage risk? Also an 801 could indeed be used to rescue those 387 passengers by ramping them across thanks to its self recovery mechanism or do you think they should just be left on a potentially dark train with no working air con or toilets?
So you admit that there is an advantage to the 801 with rescue genset but also speculate that there is no advantage in the vast majority of situations without facts to back that up (London - Peterborough is 76 miles). Indeed north of there 801’s mainly work on sections of the mainline where they only really interact with fellow 80x fleets along with various diesel classes all of which aren’t affected by the OHLE suffering a switch off.
To sum up you don’t believe that passengers travelling on an 801 should have the luxury of being able to limp out of a stranding situation because they ‘might’ be thwarted by a 387 which is in the first/final 76 route miles that they work. Interesting.
Rhydgaled
25 Nov 2010
A phrase that I've seen used several times (mostly in 'Modern Railways' magazine I think) by supporters of rail electrification is "an electric railway is a better railway, however you define better". The benefits of EMUs are generally considered to include reduced weight and reduced financial costs at most stages of the train's lifecycle (design, build, maintainance and fuel). It seems to me that these benefits are diminished if the unit is carrying one or more diesel engines, as is the case with a bi-mode or an 801. If we are going to say that a class 800 is an electric train then suddenly claims of 'EMUs are lighter and easier to maintain than equivalent DMUs' have to be qualified with 'EMUs, except class 801s, are lighter and easier to maintain than equivalent DMUs'.
Of course, the diesel engine provides its own, different, set of benefits - but by having it you have already made design and maintainance more complex. A 5-car class 801 is so close to being a bi-mode that I'm struggling to see what advantages it has over a class 800. Presumably the 801 is a bit lighter, but not as light as a straight EMU would be, and the diesel genset on the 801 is used much less often than those on 800s so I guess the maintainance intervals are longer.
Yes, I admit there is an advantage. Of course self-rescue is a nice-to-have; I guess my question is does it justify the reduced benefits of electric traction? As I said above, I'm not aware of any other rolling stock where this was seen to be worthwhile. Assuming that continues and, as I hope, electrification is rolled out then several of the 'various diesel classes' you mention will eventually be replaced by EMUs.
I don't think passengers should have to wait for hours; I just strongly suspect that in the event of disruption they will have to wait, regardless of whether the unit has a self-rescue capability or not. I'm just struggling to think of a suituation where self-rescue could actually be used:
  • dewirement: there is probably a pantograph tangled in the OHLE meaning that train (and any behind it, which will be a red signals) cannot go anywhere
  • national grid power blackout: even if there are only 801s and diesel trains on the line, no pure EMUs or electric locos, there's a good chance the blackout will have taken out the signalling power feeds too
  • pantograph damage: switch to the other pantograph
Sure, a self-rescue capability probably would be useful occasionally, but far less often than the ability to keep HVAC, lighting, toilets etc. working while there is no 3rd rail or OHLE power available (which itself will hopefully not be needed very often).
It's not the self-rescue capability that I don't like, but the cost of it - I must admit I am going on gut feelings here but it feels like an 801 has 80%-99% of the drawbacks of a more-capable bi-mode (class 800/802) yet the 801 is useful in fewer suituations.
As for the fuel running out / batteries running flat, which one runs out first is only relevant if one (or both) would run out before the passengers are rescued. If the battery lasts 30 hours* it doesn't really matter if the diesel lasts 50 hours* or 500 hours* since there is something very wrong if it takes more than 3 or 4 hours (on a bad day) to resuce the passengers. I would be interested to know the actual figures (particularly for the batteries) if anyone has them. If 379013 could run for 60 miles in battery mode during the IPEMU trial, surely modern battery tech isn't far off being able to hold a charge for at least 4 hours when it doesn't have to move the train?
* I've no idea how long either would last, I'm just pulling figures out of the air to illustrate the point
On an electric railway, which we should be moving towards, that feels like a big 'might' to me. Given the topic title includes 'GWR' you could have an electrified 'MetroWest' with EMUs. It doesn't necessarily have to be a 387 - could be an 803 or IC225, a class 92 on freight. I'm not sure how much of the ECML is 4-tracked - towards the north end you probably have ScotRail EMUs such as 380s or 385 too. Even an 801, depending on the nature of the issue, may be unable to move leaving following units held at danger.
Mark J
12 May 2018
I say that BREL should be re-established. Then there would be none of these stupid contracts with Hitachi et al, and more rolling stock built when it is desperately needed.
Irascible
21 Apr 2020
Dyfneint
We don't need BREL - BR used to buy in stock all the time anyway, from Met-Cammel et al - what we need is the equivalent of the procurement process that was BRR and the CM & EE departments. Give the RSSB some teeth & you're halfway there, it's their job to set standards, then you just need someone other than the DfT to work out what a good train is made of because they demonstrably can't, and vendors can't be trusted to offer something that will work with anything else.
Procurement at minimum cost has to stop too, it's only minimum cost until it needs avoidable expensive remedial attention.
Annetts key
13 Feb 2021
West is best
I would say that we need an operational railway organisation that can set the detailed standards for the whole mainland British railway network. In all engineering areas. Maybe we could call it British Railways…
Let various other organisations paint the stations and rolling stock. And operate them. But mot under the direct control of DafT.
Civil servants working to instructions from politicians and hence telling TOCs what they can and cannot do at a macro level is just a disaster that gets worst every minute.
Rhydgaled
25 Nov 2010
Who set the standards prior to nationalisation? The 'Big Four' were already history when I was born, so I am quite probably mistaken, but when Britain's railways were nationalised wasn't the newly-formed British Railways able to run trains formed of a mix of coaches from each of the 'Big Four' from day one? Yes, some stock would have been air-braked, others vaccum braked and many wagons had only hand-operated brakes (some were effectively without brakes while moving) but wasn't the mechanical coupling already standardised across all stock? And could any air braked vehicle work with any other air braked vehicle (and similar between vaccum braked stock)?
RobShipway
20 Sep 2009
I think that you will find that since the days of British Rail the RSSB has set out standards of how trains should be operated. Such as the Rolling Stock standards https://www.rssb.co.uk/standards/where-do-we-use-standards/rolling-stock
Rhydgaled
25 Nov 2010
Annetts key
13 Feb 2021
West is best
After nationalisation, although the whole lot was called British Railways, the former big four in a lot of areas (including engineering) continued to operate separately. However, increasingly, BRB did take account of the different standards from the former big four, to form the national BR engineering standards. Further, often the new standards incorporated any new lessons learned, or changes in technology.
Also, long before nationalisation, the private railway companies, having discovered problems during the various amalgamations that had taken place, likely cooperated in some areas.
Yeah, the trouble with the RSSB is that it’s seen more as a jobs for the boys continuously reworking, rewriting and reissuing the documents. Including moving information from one document to another. Network Rail does the same with their documents and standards. I often find myself wading through ‘withdrawn’ documents because I cannot find the information I want in current documents…
For example, I’ve completely lost track of where the engineering AWS fault code table has gone. I know where the signallers and drivers version is, that’s in the rule book.
The railway rule book being another example. The BR rule book was not particularly good, but although it was improved in some areas, mostly it’s a lot worse. And every time they change it, it gets larger. Yes you now can use the web site and app, but my employer insists on still issuing a physical rule book with all those awful booklets.
For a document to be useful, you need practical feedback from the primary users - the staff. I’m not sure the RSSB in its current state is an example of the best way forward.
Which bit of the ORR do you mean? The safety side/regulator or the other bit? And I don’t mean the roads bit either…
Clarence Yard
18 Dec 2014
Before BR? The Railway Clearing House had a role in setting some standards but it was done more on a collaborative and facilitating approach rather than by pure “top down” imposition.
Irascible
21 Apr 2020
Dyfneint
I don't know how the RCH got into setting standards for goods stock - I guess it's *vaguely* an extension of their job of distributing money to the right people - but them having the job might have done more harm than good, given we were still building unbraked short-wheelbase wagons in the 1950s, pretty much the same as 100 years before. Who decided to standardise on vacuum brakes? there were a fair number of pre-grouping companies using air brakes - was that a govt "recommendation" or just the various head engineers meeting up in the club a couple of afternoons & collectively deciding?
The RSSB do set many standards, but they haven't done things like defining TMS interoperability standards - maybe that's seen as stepping on vendors or maybe there's just not the expertise & funding, but they *ought* to be doing it. It's just as much an interface as a pair of brake pipe connectors. Definitely isn't their job to spec and design complete rolling stock, but if they set enough standards ( I seem to remember they were looking at passenger comfort at some point? ) it shouldn't matter provided vendors are properly compliant & don't fudge it.
