GWR Class 800
BestWestern
6 Feb 2011
No idea whether they are better in poorer weather as such but the programme certainly seemed to imply that the HSTs were failing left, right and centre so to speak.
The HST fleet performed as normal. The 800s were largely removed from service, due to frozen horns and problems with the TMS taking a dislike to the snow brakes. One would assume those issues will have been duly rectified.
Typhoon_93
29 Oct 2012
Newton Aycliffe
are you sure? the body is white (ish) and the doors are darker - wouldn't vinyl/paint get applied before fitting parts to the body shell?
The first batch 800001-036 are painted white and have been vinyled at Doncaster after delivery from Aycliffe. The next batch 800301-321 and all the class 802’s for GWR are painted green.
hexagon789
2 Sep 2016
Hopefully they will be seeing as we'r stuck with the 800s. Also, what is the snow brake, I've seen reference to these being fitted to the Pendolinos but no explanation of what it is?
DidcotDickie
12 Mar 2017
Oxfordshire
Yes - Typhoon_93's post above explains.
I see that Hitachi are still turning out 5 cars instead of 10 on some diagrams. 1A11 9:30 Temple Meads to Padd passed me near Uffington today as '5 vice 10'. Must have been cosy by the time it got to Reading.
BestWestern
6 Feb 2011
My understanding - which may or may not be complete tosh! - is that the brakes are held very lightly applied, enough to cause heat which in turn prevents the brake rigging from freezing and becoming inoperable. This appears in some cases to have confused the TMS into thinking there is a dragging brake. Which, in essence, I suppose there is, but intentionally!
hexagon789
2 Sep 2016
Applied while the train is under power?
superkev
1 Mar 2015
west yorkshire
I thought sending prototype trains to the Czech republic for freezing conditions testing was supposed to sort out such things.
K
BestWestern
6 Feb 2011
I believe so, yes. The idea is to prevent a major braking defect resulting from the brakes freezing solid whilst not being used. Obviously this can, and has in the past, led to serious operating incidents (SPAD with an HST in snow comes to mind). Ordinarily, the potential effects of snow are mitigated through performing running brake tests at frequent intervals, however this of course can slow progress quite significantly on a long journey.
Domh245
6 Apr 2013
nowhere
K
I think you are thinking of the Vienna climatic wind tunnel (aka vienna arsenal) located in Vienna (unsurprisingly). It can only do static tests AFAIK so something like snow brakes can't be tested really
hexagon789
2 Sep 2016
The 158s have very severe snowy weather brake test requirements.
IanXC
Emeritus Moderator
18 Dec 2009
Has anyone heard anymore on the 802’s working there was across Europe..
See attached for an 802 already here and testing, pictured yesterday (07/04/18) as the crew seemed to be changing ends just outside Paddington in the reinstated (I forget what they are called) sidings.
JN114
28 Jun 2005
Royal Oak Sidings
800001
24 Oct 2015
802001 and 802002, been here for several months.
33Hz
2 Dec 2010
Finally got a go on these, but my first high-speed electric run on the GWR will have to wait. For some reason it ran on diesel all the way from Didcot to Paddington, despite the pantograph on the unit (800016) being up on arrival.
Pros:
- it's not a Voyager.
- acceleration was decent.
Cons:
- the engines are only marginally less noisy than a Voyager. At higher constant speed it was drowned out by track noise though.
- seat was hard as nails. No way would I want to go down to Truro on that.
- standard interior is garish.
- interior is already showing signs of wear and developing rattles.
- automated announcement was muffled, like the speaker was damaged.
All in all a far more inferior experience to the HST I went to Didcot on this morning.
Basically my view as well - an utterly mediocre train with an utterly mediocre interior at an utterly outrageous price.
Just look at what TPE are getting (interior wise) if you want quality. Or Stadler. Or for a more traditional 125mph bi-mode I think Bombardier's product will knock spots off them.
I would not be at all upset if Hitachi got no further orders of any kind for the UK with the third-rate products they appear to be offering.
cactustwirly
10 Apr 2013
Hmm, it's a lot better than the stuff that Bombardier churn out (like voyagers) the only major problem with them is the seats, and that's down the the DfTs spec.
The build quality may not be as good as Siemens but it's better than Bombardier IMO.
Regarding quality Voyagers are now over 15 years old, a more useful Bombardier comparison is recent Electrostars and Aventras which are pretty good - not Desiro-perfect but certainly up there.
387star
Pros:
Cons:
I thought the engines were vastly quieter than the Voyagers from what most people have been saying....
I understand the seats are being recovered with an improved material? I wonder with these hard seats whether it is the shape of the seats themselves or the material placed on them that is more to blame.
Wilts Wanderer
21 Nov 2016
I might be wrong but the last couple of 800 seats I’ve sat in (Standard Class) seemed to be marginally more supportive and ‘stuffed’. Are Hitachi fitting improved cushions or has my backside just got flabbier? (Quite possible )
TEW
16 May 2008
In my opinion the new material actually makes the seats worse. I couldn't notice any real difference in the padding, but the covering used is now very rough and scratchy rather than smooth.
HowardGWR
30 Jan 2013
Assuming the electrification projects complete, what do we think will happen to the 9 car sets. Will they be changed back to all-electric to save weight? Or will they be palmed off onto such as the MML TOC? Same question about the 5 car sets.
