Guess the Station...
I think he was just using the initials of the station rather than using the station code
Yes, I guessed that however we ask that people use full names if possible. If abbreviations are to be used, then the correct 3-letter code should be used, and preferably the station name should be mentioned the first time it is used, with the correct code in brackets. Otherwise it can cause confusion, especially if someone said to take a train to "LLS" from somewhere like Audley End, you know they don't mean the actual LLS but you have no idea if they mean a north or south bound train!
IanPooleTrains
21 Nov 2010
Brereton, Rugeley, Staffordshire
With the greatest of respect sir, I have always called it RTV regardless of what some websites say i should call it and I will always call it RTV until the day I die
As for the station, guess at Johnston
Lampshade
3 Sep 2009
South London
It really does scream 'seaside', somewhere like Lytham, except it isn't.
I can imagine it's a 142/143 operated line.
MikeWh
15 Jun 2010
Crayford
I guess in the quiz forum it's not quite such an issue, but with the greatest respect, IPT, if you use the wrong code in the fares and routing section then you will be rightly admonished.
You may call it that but on here please use the name, rather than a 3-letter code. If appropriate, feel free to use an abbreviation as long as it's not a 3-letter acronym. E.g. For Birmingham, BNS (Barnes!) would not be acceptable, but "Brum" would be fine. Sorry if that sounds pedantic, and I know it doesn't really matter much in the Quiz forum, but people reading this may not have a clue where "RTV" is (all it means to me is rail travel vouchers!) and if they tried to look it up, they'd not be able to figure it out.
Anyway, back to guess the station, I am ruling out the Whitby line!
OK, figured it out, it is Bempton
Well, I have actually got off a train at Bempton! (A time killer as had time to kill at Scarborough, and didn't want to risk the connection at Bridlington) however I'd be lying if I said I remembered it well enough to instantly get it! It's very difficult from that angle, as you can't see the building easily, but I see you got that pic from Wikipedia ;)
Fair enough your doing better than me, I've only been through it! I actually nabbed the photo from NRE rather than Wikipedia but they are nearly identical ;)
I must admit I enjoyed watching people guessing stations in Wales on the opposite side of the country! :lol:
Give this one a go! It will probably be a very quick one this, as it's probably quite unique.
Lampshade
3 Sep 2009
South London
Hmm, it's obviously where a GNER HST has been that's not on the electrified ECML...
That's all I've got :shock:
MCR247
7 Nov 2008
I think I know the line this is on but I can't think which station!
