Well yes, but do it the Scotrail way, not the LNER way.On the basis of that argument, your logic means that you could equally be arguing for off-peak tickets to go because they cause so much confusion.
There is no such thing as a blanket "peak" or "off-peak" service; the trains you can take with an Off-Peak ticket depend entirely on the ticket held.Have had similar fun on Merseyrail when travelling to Lime Street for the off peak 09:43 Avanti.
Definitely requires the use of a peak Merseyrail service, but with an off-peak ticket. Barriers won’t let you out at Liverpool Central and only the lax attitude of staff (orange coloured card shape = okay) means I’ve never had too much bother.
And some have more severe restrictions for the connecting service than for the main service.There is no such thing as a blanket "peak" or "off-peak" service; the trains you can take with an Off-Peak ticket depend entirely on the ticket held.
Some Off-Peak tickets have no time restrictions at all, others have significant time restrictions, most are somewhere in between those two extremes.
In that case it might be easier changing at Moorfields for a Wirral line train and using the lift exit at Lime Street. Might be longer but unless merseyrail are having a revenue block an easier journey, especially if you run into a poorly trained RPI.Have had similar fun on Merseyrail when travelling to Lime Street for the off peak 09:43 Avanti.
It's a sorry state of affairs when passengers with valid tickets will sometimes prefer to avoid RPIs where possible, even going slightly out of their way to avoid them, but that would appear to be where we are.In that case it might be easier changing at Moorfields for a Wirral line train and using the lift exit at Lime Street. Might be longer but unless merseyrail are having a revenue block an easier journey, especially if you run into a poorly trained RPI.
The debate has not disputed that a ticket purchased in conjunction with an itinerary is entirely valid. That doesn't alter the fact that the validity is highly debatable for someone travelling other than with an itinerary.The SWR app shows the off peak return to be valid on the OP's train.
So no debate. OP correct. Guard wrong.
Agreed. In fact, I would go as far as saying the ticket is clearly not valid for the train used but for the purchase in conjunction with that itinerary.The debate has not disputed that a ticket purchased in conjunction with an itinerary is entirely valid. That doesn't alter the fact that the validity is highly debatable for someone travelling other than with an itinerary.
Yes, very possible.If the guard had taken details of the ticket and forwarded it onto the revenue team at SWR would they investigate it further as a matter of course and fix the issue whichever way they think it needs to be fixed?
Yes, also very possible.If they don't price it, would they get in contact with GWR to look into thr matter?
So it might be worth keeping an eye on the restriction code in case the wording of it gets changed to be more "simple" for passengers to understandIf the guard had taken details of the ticket and forwarded it onto the revenue team at SWR would they investigate it further as a matter of course and fix the issue whichever way they think it needs to be fixed? If they don't price it, would they get in contact with GWR to look into thr matter?
And to be simpler for staff to understand.So it might be worth keeping an eye on the restriction code in case the wording of it gets changed to be more "simple" for passengers to understand
Of course, if you're more interested in the logic and the principle than this case - there's a logical question here with this restriction code.The debate has not disputed that a ticket purchased in conjunction with an itinerary is entirely valid. That doesn't alter the fact that the validity is highly debatable for someone travelling other than with an itinerary.
This brings me to another question. If one part of the restrictions says "off peak tickets are valid for connections..." and another says "not valid for trains timed to depart from..." which takes precedence if both apply?Agreed. In fact, I would go as far as saying the ticket is clearly not valid for the train used but for the purchase in conjunction with that itinerary.
Yes. Or, alternatively, no. Or...Is that ticket valid for that service?
That is a good question, point, and, I wager, guess.This brings me to another question. If one part of the restrictions says "off peak tickets are valid for connections..." and another says "not valid for trains timed to depart from..." which takes precedence if both apply?
My guess is that the people who wrote this restriction code never even had it enter their heads there could be a situation where both things apply simultaneously.
My advice would be to obtain an itinerary (if practicable, and you didn't already), which could be shown if anyone inspecting your ticket queries it. Then there is no need to get into any debate about validity; if you are following an itinerary issued in conjunction with your ticket, then your ticket is automatically valid (as per contract and consumer law).Ticket was Chandlers Ford - Swindon via Melksham, return. I bought via Uber App, putting in 0755 from CFR. £30.50, but I used a Senior Railcard, so £20.15.
The guard on Chandlers Ford-Romsey leg was quite animated when he inspected my ticket, acting like he'd won the lottery. 'This is an Off Peak ticket and it's not valid...' He offered me to buy a full fare ticket to Romsey but I stood my ground, showed him the 'i' bit of the e-ticket which showed that I'd booked choosing the 0755 so it's not my fault that my ticket, clearly labelled 'Off Peak' wasn't valid.
Thankfully, the journey is only 8 mins and we arrived at Romsey before he could extract ££ from me or fine me.
I went to the ticket office at Romsey to ask what I'd done wrong, but after a few minutes I was told 'no idea, it's all so complex these days' and not to worry as my next train 0825 to Westbury was definitely off-peak.
Can anyone enlighten me? National Rail journey planner comes up with the same fare, so I don't get what the issue is. I assume that as I put my Senior Railcard in the booking that it can't be anything to do with that (times allowed?), or is it?
thanks!
(although this is under a heading relating to the route you may take, clearly same principle applies regarding time restrictions)When you book your journey online, any ticket offered at that time in connection with the journey planner results will be accepted as a permitted route...
Something that the retailer gives you with your ticket that indicates exactly what you searched (train number, times etc...) and got tickets forWhat exactly is meant by an itinerary?
Yup. It's what you get after you pay, when it shows you specific services in your basket.So for example just screenshots from the Trainline app would count as one, if they showed the trains to be taken etc?
