Guard has drawn all over my ticket
jacksonbang
2 Nov 2016
I travelled on the return portion of a Esher to Rye ticket this morning. I got checked on the Clapham Junction to Hastings leg - on the second check the guard took my ticket and punched it with a train-shaped hole, additionally crossed out the return date expiry of August 16th and then filled the ticket with an large criss-cross. When I got to Hastings I decided to get the bus due to the timings. It occured to me that, although I have a Hastings-Rye part of my ticket still unused, my ticket has basically been defaced beyond use. Techincally can I still use this ticket later in the month?
The ridiculous thing about crossing out the date and not writing anything about when it was checked is that it doesn't give any information to the next inspector about when and where it was checked.
Neatly writing the date and location of the ticket check is a much more effective mark to prevent invalid further use (and allow valid further use).
jacksonbang
2 Nov 2016
Never seen it before - I've been hole-punched, date written - but not a massive cross and obscuring of the expiration date (it was green marker so you can still just see the date)
gray1404
3 Mar 2014
Merseyside
It doesn't after the validity remaining however I totally understand that you may fear it will lead to questioning. It does seem a bit over the job. Out of interest would you be able to post a copy of the ticket?
TheTallOne
2 Jan 2024
Assuming break of journey was allowed on that particular return ticket (guess fairly likely), then I’d suggest contacting customer services.
Tell them what has been done and that you are concerned about being able to continue your journey hassle free.
If you did get stopped you could possibly refer to that discussion with customer services, plus perhaps if it isn’t the right way to mark the ticket they can learn from the error/complaint!
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
There isn’t a right or wrong way to mark a ticket. That being said, I can see why the OP is concerned.
jacksonbang
2 Nov 2016
It just got me thinking - it's all very well saying to the guard that I'm only going as far as "X" today but I didn't know that at the time - and, in any event even if he did mark it, I would not think twice about breaking my journey and continuing another day with said mark (because they don't ever seem to mean anything) but it was as if the ticket had been fully cancelled.
TheTallOne
2 Jan 2024
Some might argue that if there was a right way to mark the ticket it would make people less anxious.
Some autistic people can be quite worried about things like this for example.
redreni
24 Sep 2010
Slade Green
It's normally been my experience that if I'm on a train that doesn't serve the destination station on the ticket (meaning the guard knows I'll have to change), they confirm with me which station I'm going to on this particular train and then mark the ticket accordingly.
The behaviour you've described seems very odd, as you were always going to have to change in order to get to Rye. It doesn't matter if you were going to continue your journey straight away or in a fortnight's time - your ticket might have been checked by somebody else at Hastings or Rye or at some point between the two, and they would obviously want to see the expiry date. And if there were any holes or marks on the ticket, then presumably they'd ideally want to satisfy themselves that those were made at an earlier point on your route and so do not indicate that you're trying to re-use the ticket. So it would have helped if the markings were legible and didn't obscure anything printed on the ticket.
I'm still not looking forward to being compelled to use e-tickets or bogroll tickets for this sort of journey, particularly if I wish to break my journey at a station that doesn't have ticket barriers.
I fear the act of the guard scanning the ticket before the break of journey will be interpreted by the machines (and even some of the people) that scan the ticket subsequently, when I come to use the remaining validity (particularly if it's on a different day), as tantamount to the guard having drawn all over it and deleted the expiry date as you've described. At best.
At worst I worry it could be treated as tantamount to the guard having ripped the ticket in half.
Tazi Hupefi
1 Apr 2018
Nottinghamshire
I find it helps some to understand that it's not really YOUR ticket, and what a ticket actually is - first they belong to the railway at all times and ultimately they can do what they want to them (nothing for you to worry about).
Second, it's ultimately just evidence that you've entered into a contract , normally on payment of a particular fare - anything written on it doesn't change that situation.
The worst case in these sorts of scenarios would be that you end up with a complaint to a TOC requesting reimbursement of an additional fare, if one has been charged incorrectly - it's really not something people need to fret about, as often a simple explanation (if indeed, one is even necessary) resolves the matter instantly.
Your experience in these sorts of instances can generally be affected by your attitude - most rail staff can spot the repeat abusers of open tickets a mile off, compared to the occasional honest customer who simply explains they broke their journey and who doesn't have any issues at all.
Paper tickets with barcodes (bog roll style) are absolutely ideal if you worry about this sort of thing - if you make a point of scanning in and out at your various points along the journey, staff can see where you have (or haven't!) been.
That's no longer the case, since the National Rail Conditions of Carriage became the National Rail Conditions of Travel. This clause was removed.
Tazi Hupefi
1 Apr 2018
Nottinghamshire
The clause was removed because it wasn't necessary to explicitly define that- it doesn't change the underlying position.
Why was it in there in the first place, then? Why is anything in there?
redreni
24 Sep 2010
Slade Green
Sound advice, though only helpful if the intermediate station has barcode scanners. I use e-tickets sometimes on the Southeastern network, where barcode scanners seem to exist only at gated stations, not at ungated stations.
In fairness, I'm sure this fact would be taken into account if a passenger said they'd broken their journey at such a station. Hopefully not by somebody who has already prejudged the situation because they believe they can spot things a mile off.
zero
3 Apr 2011
I had a GWR guard almost deface a rover on the last afternoon of travel. You could still see that it was a rover though and it wasn't checked the rest of that evening anyway
jacksonbang
2 Nov 2016
It's this attitude that there is only the "occasional honest customer" and we can be somehow prejudged by Southeastern.How is this repeat abuse spotted ?
pelli
15 Sep 2016
Esteemed forum member AdamWW has previously reported similar experiences in October 2022, March 2023 and (tangentially related) June 2023:
I also found related discussions from 2012, 2015 and 2018:
blueberry11
19 Aug 2023
Norwich
Maybe the ticket shouldn't have be written/scanned at all. Remember that it may be the passenger or someone else that wrote on the ticket, not the guard. This is so that passengers can enjoy a break of journey so they may wish. Any markings on the ticket shouldn't preclude a BOJ/change of validity. I'm fine with doing it on advance tickets because you have to use the specific train, and the same start and destination stations and a BOJ is not permitted.
The exile
31 Mar 2010
Somerset
Historically (very historically...) collected ticket stubs were essential for the proper apportioning of revenue between different companies (they were dutifully returned to the Railway Clearing House). The idea of surrendering your used ticket is fairly normal to us - but wasn't to early travellers. It also permitted officials of the railway to confiscate your ticket if misused (or indeed if a passenger needed to be removed from a train for "creating a nuisance". An analogy would be "your" passport. You pay however much it is for one, but strictly speaking it remains the property of HM Government.
