GTR - Assistant Salesperson
Leogilbert007
1 Nov 2024
Born under the Brixton sun
Hi all,
A bit worried as my disability (issues with fine motor skills and processing, not to mention a difficult-to-understand format)meant I ran out of time on the assessment linked after I submitted my application to GTR. I emailed the relevant person straight-away explaining the situation, but do you know if this will vastly prejudice my application? Thanks
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Hi all,
GTR are not allowed to discriminate based on disability - did you speak with GTR prior to sitting any assessments to discuss possible reasonable adjustments?
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
No, not prior that's the thing...
Were you given opportunity to declare any disability and ask for adjustments at application stage?
I’d probably suggest there would need to be some ownership on your part to ask for help if it would have been reasonably foreseeable that you’d have needed some form of reasonable adjustment.
If the assessment was directly after the application was submitted, I guess there may be an argument that you wouldn’t have had a chance to ask.
It’s a tricky one - I wouldn’t know what the way forward should be. Legally, morally, or in reality.
Leogilbert007
1 Nov 2024
For clarity purposes, I *did* tell them about how my disability affects me prior to completing the assessment, but I didn't tell them about my disability *in relation to the assessment*
Thanks for your help!
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Genuinely, see what they come back with. You may be pleasantly surprised. As noted above, I’m not sure what should happen here.
Horizon22
Jobs & Careers
8 Sep 2019
Normally there is a box or a few questions in the application to state any disabilities and any impact they may have on you. Then GTR might then consider "reasonable adjustments" which in your case may have excluded extra time to complete an assessment. At this point, wait and see if you have any response.
Sussex
9 Feb 2026
Sussex
Hi all,
How did you get on?
