GN Class 717
Fred26
5 Mar 2010
It was dealt with quickly and the train left under its own steam (!).
There are actually quite a few reports of fire/smoke at Moorgate, and sometimes I wonder if it's down to a spark from the third rail lighting rubbish, or someone thinking they saw smoke which was actually someone vaping at the end of the platform. Many reports of smoke turn out to be false alarms, which gives credence to my theory.
If you saw it yourself you'd know it wasn't the latter.
It's usually down to oil/rubbish sparking. Flames aren't common, usually just smouldering and a lot of smoke.
jon0844
1 Feb 2009
Fair enough. I just assumed that as people have no issues vaping on public transport that it could lead to false alarms. As you say, I'm not there often.
717001
4 Aug 2018
Am hoping these will come into service on schedule but haven't seen any signs on realtraintimes of test runs into Moorgate happening this week or scheduled for next. Wondering if anyone knows whether things are on hold or if they are running elsewhere?
BowesRanger
16 Jul 2018
Yes! Hoping to make it to the UK one day but still in Germany for now (I think!)
Two of the units are in the sidings at hornsey. A third is in the train care facility, and has been since the fire I think... You can see them all from the train as you pass.
Agent_Squash
22 Jul 2016
I think the member is referring to 717001, which is still in Germany.
jon0844
1 Feb 2009
Odd that these will have charging sockets for such short journeys
More odd that the 700s didn't get them throughout. I think any new train should have them, although I wonder how it will work if TfL takes over the service?
Domh245
6 Apr 2013
nowhere
The new 710s are going to have USB sockets (36 per vehicle) so TfL aren't opposed to the idea of them
jon0844
1 Feb 2009
That's good then. Personally, I think the 717s could have done with simple USB-A ports and not a 3 pin socket. Make it USB-PD compliant and it would be fine for charging phones and modern laptops and tablets.
jellybaby
27 Dec 2012
I think any low voltage thing you put in today will be out dated and useless in 40 years time, or even 20 assuming they get a mid-life refurb.
jon0844
1 Feb 2009
Perhaps, but I don't see USB-A ports going anywhere soon. USB-C may be the new standard, but USB-A to USB-C (and then of course anything else, like micro-USB, Lightning etc) cables are plentiful and small enough for anyone to carry, especially if they have their own power bank and use that cable.
Will they need higher voltages or amperages as time goes on? If anything, technology will go the other way and we'll be fine with less.
jon0844
1 Feb 2009
You can't charge most (any?) laptops with a USB-A port either.
As I said, it would need to be USB-PD compliant (which I am sure it would be, as it is for charging not data). I can ONLY charge my laptop this way. Likewise the new MacBooks are USB-C, and other high-end laptops.
If USB-A can't do that, then have a USB-C port instead (or both). Still a lot smaller than 240V sockets.
jellybaby
27 Dec 2012
Your laptop didn't come with a mains adaptor in the box?
The sockets tucked under the seat seem out of the way where they could be many times bigger and it still not be a problem. I suppose it is more bulk for people to carry as they need a charger rather than just a cable.
jon0844
1 Feb 2009
It came with a phone style power adapter, with a USB cable. I can charge my phone with it, or my Nintendo Switch or anything else with USB-C. Likewise I can use other chargers to charge it (albeit slowly if not USB-PD).
The MacBook only has a USB-C port!
GW43125
8 Dec 2014
717005 was visible in Hornsey depot this afternoon. Assuming it's been parked since delivery?
Fred26
5 Mar 2010
As was 717007.
Have any 313's gone off lease yet?
Last I head the 717s aren't even under GTR management until October, when testing is expect to be completed on the first unit(s), so I would doubt it.
Aictos
28 Apr 2009
Seeing as they were meant to enter passenger service this year, I wager that they're likely to be delayed entering said service and it won't be until 2019 that they will see passenger services and the last 313 service won't be until May 2019.
This takes into account the training and conversion training of the drivers as well.
That's how much confidence I have in the GTR leadership.
Mikey C
11 Feb 2013
Agreed, during rush hours with people crammed in and lots of standees, it does feel like a bit of an irrelevance
jon0844
1 Feb 2009
It takes two weeks to train each driver so I don't think that's as big an issue as the signal sighting problems and other work that is down to Network Rail.
If there are fires starting then questions must be asked about what is happening to keeping the lineside areas clear. If it is down to a train fault then that will obviously cause delays.
I am not sure GTR can be blamed just yet. Give it time!
choochoochoo
6 Aug 2013
Anybody have any thoughts why they decided one pantograph would be enough for 6 cars ? I know 3/4 cars run around with one pan, but surely 2 pans would offer some redundancy, especially for 6 cars. And then there is always gapping to think about too.
sprunt
22 Jul 2017
Isn't all the seating in these longitudinal? Given that, where will the power sockets be located?
Mikey C
11 Feb 2013
The seating on the 717s is conventional 2+2 transverse.
A bit inconsistent really if new trains from Moorgate have transverse seats, whereas the TfL new trains from Liverpool Street have longitudinal ones. Especially when for the last 40 years they've operated with near identical stock (313s and 315s)
16 Dec 2017
This came up on the 710 thread and I had a stab at trying to understand (not justify, mind) why transverse might have happened: https://www.railforums.co.uk/threads/class-710-lo.145774/page-15#post-3519847
Also, two different manufacturers (Bombardier vs Siemens), and two different clients (GTR vs TfL), so, yes, unfortunately seemingly inconsistent from a passenger perspective, but the deals are completely unrelated at the order level, and GTR being the client, seem to have thought that transverse would be better for their product than longitudinal.
