Okay, got confused there. But yeah - still quite a fair distance away from 455sI thought you were in Milton Keynes, mparsonz?
Okay, got confused there. But yeah - still quite a fair distance away from 455s![]()
Dunno - you tell me. You seem to be the expertWhich is good right?
You're lucky down there. You don't get *shudder* 320shock:
I have the right to. I've been on their older brothers (320s) and they're all bad.
I am. It's only about 40 Miles away
which are going soon
Before you start ranting about rubbish left by the passengers its hardly the train's fault...
322s might be better becasue they're longer and have toilets, so I would imagine a potentially better journey on them.
Are you feeling ok Loader?
He said they have toilets as well as having toilets and thus a better journey. Where did your little rant come from? Tho you are right if a little random.
What is the longest Class 455 working - can't be much more than an hour tops? If you can't go that long without the assistance of a lavatory then perhaps you might want to see your doctor? They're designed as commuter trains to fit as many as possible in - not long distance leisure trips.
You could say the same about a bus or coach journey.Though what if you board the 455 needing the loo but couldn't go before hand for some reason or another...?
As do long-distance trains.....Long distance coaches do have toilets fitted i think.
All about purpose, if trains are only for short distance hops then why fit them with toilets when seats can be provided?
Because the incontinent, naked shower man said they should just a couple of posts above this, of course.All about purpose, if trains are only for short distance hops then why fit them with toilets when seats can be provided?
Because Tom Loader said they should.
.Get off at the next station and use the facilities there.
