SuspectUsual
- Joined
- 11 Jul 2018
- Messages
- 6,709
Which football team have Mick Hucknall and Shakin Stevens both played for?
Fulchester?
Alf TupperWho was The Tough of the Track?
Alf Tupper
Thank you.You have correctly breasted the winning tape.
For you to fire the next starter’s pistol.
No, that's not it.Calorimetry?
I had a feeling you would know. Yes, they are used to maintain a constant temperature for quartz crystal oscillators used in timing, signal generation, frequency measurement etc. Your turn...I think that this basically a controlled temperature (and humidity iirc?) environment not necessarily an oven but could be a room/chamber. ( I have one at work for controlled curing of resins, coatings, concrete and grouts and paints) . It is for crystals ( used for frequency generation applications ) where a very precise frequency with almost zero variation is required.
correct but that has already been givenU for Uranium (92)
CorrectS is Sulfur / Sulphur. Atomic number 16.
B - Boron
P - Phosphorous
Fantastic.V - Vanadium
Y - Yttrium
Correct. One of the newer elements. Over to you.Darmstadtium?
I read it on the side of my periodic table mug, so for the sake of fairness open floor pleaseCorrect. One of the newer elements. Over to you.
No wasn't that.Was it this?
