General Knowledge Quiz
D1511
29 Jul 2023
WCML N
They are a sort of light brown colour, and I am informed they are the Latvian equivalent of Brussel sprouts (served up at Christmas)
D1511
29 Jul 2023
WCML N
Correct ! They are also a Black Country delicacy.
[I would have accepted Maroon as well as the colour range does vary]
Your turn to serve up some pizagi / pizadzini.
As a Hearts fan, I should have known they are sometimes maroon!
What is SCOOT and what is it used for?
GusB
Elginshire
I'm probably wrong here because you specifically say "is" rather than "was", but Scoot was the name of a classified directory service that competed against Talking Pages. I had to give out the number several times a day when I worked at directory enquiries!
AndyPJG
29 Jun 2012
Was, not sure if still, a computer program used to set/control road traffic signal timings. (least was back in 1970/80s)
D1511
29 Jul 2023
WCML N
Ah, I wasn't aware of that, so we may have two correct answers here.......but if it no longer exists, then I think the below is strictly correct
This was the answer I was looking for......it is software to optimise the operation of a traffic signal controller using live traffic data, or in more recent versions, a network of traffic signal controllers. Generically referred to as Urban Traffic Management & Control (UTMC) systems, SCOOT is a world leading UK product, and for all you geeks out there, it is an acronym of Split Cycle Offset Optimisation Technique!
Subject to @Gus acceding, over to @AndyPJ to calculate the next question, based on real-time data :D
AndyPJG
29 Jun 2012
Took me back a few years though!
As I'm about to go out,will set a Green Light for Open Floor
MotCO
25 Aug 2014
If India is 13 steps behind Vic, and 6 steps in front of Charles, where is her father?
Gloster
4 Sep 2020
Up the creek
No. What is your reasoning?
Phonetic alphabet. I for India, C for Charlie, V for Victor and G for George. Unfortunately, as I realised after posting, the first is the current international alphabet and the others the old RAF one, where I started. Also not sure if George was Victoria’s father.
MotCO
25 Aug 2014
You're on the right lines, but
Seven steps in front of her.
is the right answer; her father is Papa.
Your return to set the next question.
GRALISTAIR
11 Apr 2012
Preston Lancs
It ain’t bismuth vanadate which is a bright yellow pigment I use regularly because it also has fabulous heat resistance but it is the antimonate salt. Extremely rare but naturally occurring but only a few grams has ever been found.
DaleCooper
2 Mar 2015
Mulholland Drive
You are correct except that the only sample in captivity weighs just 0.3g, your turn...
GRALISTAIR
11 Apr 2012
Preston Lancs
A well known show from quite a few years(decades) ago was “The Golden Shot”. Presenter Bob Monkhouse and the man who loaded the crossbow as Bernie - hence “Bernie-the bolt” . However, when the show started, it was not Bernie but another guy. What was the name of the guy?
DaleCooper
2 Mar 2015
Mulholland Drive
Usain
GRALISTAIR
11 Apr 2012
Preston Lancs
24 hours and no answer. A huge clue and then as I am right in the middle of moving back to England, I will declare open floor if nobody gets it.
Name sounds German and sounds very like a brand of baked beans.
