Mcr Warrior
- Joined
- 8 Jan 2009
- Messages
- 17,336
Not 46 miles (or mikes) but you're certainly closing in.My pseudo-random generating brain is going to make a wild guess of 46 mikes
Close, but just short.I'll have to try 38 miles.
Quite precise that. Unfortunately, not correct.28.372
That's good enough. Most sources have the distance as being around 41 miles.Since my first guess was too long, I will hazard a guess at 40 miles.
Indeed. Ballpark 35 nautical miles if that had been the unit of measurement being used.Incidentally, is it not the case that as a sea crossing will be involved, that nautical miles are of different lengths to land-based miles.
Quagga?Which was the sub-species of the genus Equus that became extinct for over 100 years in recent times, that scientists have been using modern methodology to reintroduce? Only one known photographic image exists of a living animal when in a zoo.
Przewalski's horseWhich was the sub-species of the genus Equus that became extinct for over 100 years in recent times, that scientists have been using modern methodology to reintroduce? Only one known photographic image exists of a living animal when in a zoo.
Most correct. Please set the next question.Quagga?
They did not become extinct.Przewalski's horse
It's essentially a grassy, sandy, strip, and you'd probably find it somewhere like Benbecula / the Western Isles.What is Machair and where would you find it?
I've got four around matable.What is Machair and where would you find it?
Keep 'em coming! I love it!I've got four around matable.
Pretty much spot on. Your turn to set the question.It's essentially a grassy, sandy, strip, and you'd probably find it somewhere like Benbecula / the Western isles
Technically correct, the best kind of correct.I've got four around matable.
1,000Staying with Benbecula in the Outer Hebrides, what's the island's current population, plus or minus a thousand?
Good enough. Population of Benbecula was apparently 1,300 in 2021, so your turn to pose the next question.1,000
I nearly said 0, as you gave us a 1,000 each way!Good enough. Population of Benbecula was apparently 1,300 in 2021, so your turn to pose the next question.
The atlantic is bigger than that15 metres?
But not that big! A smidge too big there!A guess of 24 metres
The answer is 22m, so you are within the 1m buffer.So less than 24 but bigger than 15, split the difference or notice the word smidge and weight towards 24. Let me see, I will try 21 metres.
