GBRf Class 99 - 30 locomotives now ordered
northernbelle
10 Oct 2018
GWR do not have the final say. If DfT say “contract out Night Riviera operation” then that’s what will happen.
In any case, I’m sure those Cardiff-Taunton replacements a few years ago with assorted 57s, 66s and 66s were driven by FOC staff.
They don't have the final say, but they do have a say which will be influenced by factors including industrial relations.
The Cardiff-Taunton loco hauled services were driven by FOC staff but on a temporary basis. It was understood that those services would return to the FGW roster when appropriate traction was available.
GB
16 Nov 2008
Somewhere
For a UK size loco, I think only Stadler would know, but the European size version has been built in the past with a 2800kW/3750hp CAT C175 engine fitted (same as used in the cl. 68). However that was before the latest emissions rules came in, so that might be more difficult to fit in now.
Thanks. Was trying to see what might be available to maintain performance and timetable on the Felixstowe branch.
ac6000cw
10 May 2014
Cambridge, UK
The Railway Gazette article suggested Felixstowe port to Ipswich timings within 2 min of class 66 timings, which suggests to me the diesel engine would be a less powerful than the 3300hp in a 66, compensated to some degree by the better performance of a modern AC-drive traction system (better acceleration at lower speeds, but losing out at higher speeds due to less engine power).
Waving a wet finger, I'd hazard a guess at 1800 - 2500hp maybe?
GB
16 Nov 2008
Somewhere
This is what the European spec. Stadler 6-axle EuroDual looks like in action - https://railcolornews.com/2020/05/0...x-axles-the-hvle-eurodual-in-regular-service/
It's hard to find weight and length information, but it's probably about 23m long and about 123 tonnes. So around 1.5m longer than a 59/66/70 and a bit lighter.
Thanks for the extra info!
hwl
5 Feb 2012
Provided the engine is vaguely sensibly sized there will be very little or no difference below 20mph as everything is limited by weight on the axles (unless the engine is very puny.) but 3 phase traction equipment should improve on this.
Which 66 timings -e.g. how heavy/ long is the train? Easier to get near existing timings with shorter trains...
As speeds on the branch don't get that high you might not need that large an engine especially with more efficient traction electronics. the 88s/93s use a CAT c27s (950hp) but the sensible (and Stage V certified) choice from CAT for the 99 is probably the 3516E at 2100hp
GB
16 Nov 2008
Somewhere
Speeds not high but the branch is very stop/start so smaller engine would affect acceleration. Plus the bank climbing up from Ipswich to Westerfield and out of the terminals.
ac6000cw
10 May 2014
Cambridge, UK
You could solve that one by electrifying from Ipswich to probably just beyond Westerfield (so the electric to diesel changeover happens on the level) - maybe just do the 'uphill' track if money is really tight.
Wyrleybart
29 Mar 2020
South Staffordshire
But surely the Felixstowe branch has to be one of the busiest and therefore most profitable routes for Network Rail. Ergo it should be electrified soon - towards the top of NR's plans. The passenger trains are already able to run under 25kV, and FL, GBRf and DBC all have AC locos which could work through to the port. In this instance it is crazy to even think about battery Bimode locos and Felixstowe in the same sentence. There needs to be an East-West spine as follows
Felixstowe-Ipswich / Bacon Factory
Haughley Junction-Ely Dock Jn
Ely-Peterborough.
Peterborough-Syston Jns
Wigston-Nuneaton
Nuneaton-Grand Jn / Proof House Jn
In conjunction with the MML electrification this would provide through electric traction for anything out of Felixstowe towards London, but also to the ECML north, the MML north and south, the WCML at Nuneaton, inland container ports at Hams Hall, Lawley St, Cannock etc etc
It would also allow the Birmingham - Leicester - Ely - Stansted Airport passenger service to be turned over to EMUs and probably BEMUs for the Nottingham - Norwich service too - assuming Nottingham-Grantham and Ely-Norwich is achievable with batteries. It would allow some Bimode class 755s to be replaced by straight EMUs and released to other lines where Bimode is useful.
The "stones throw" Manton Jn - Corby should also be wired to allow both freight and passenger services.
hwl
5 Feb 2012
Ely-Peterborough.
Wigston-Nuneaton
That is actually part of the plan, just GBRf want to make something happen sooner. I'd expect to see London Gateway service as first use for 99's.
gg1
2 Jun 2011
Why are they giving it a ship classification when 94-96 & 98 aren't taken? Also, if they are just going to be Stadler EuroDuals, why not use the 93 classification? It feels like they're using new classifications for the sake of it, and soon, we'll run out.
Indeed.
I know that ultimately it doesn't really matter and many people don't care one way or the other but it does irritate me when unused class numbers are skipped in favour of something snappier.
Cowley
15 Apr 2016
Devon
I’ve moved a couple of the TOPS discussion posts into this thread to keep this one on topic:
Playing devil’s advocate here... if it is a profitable line, then why spend money electrifying it when that doesn’t result in extra profit?
(FWIW, I think th3 line should be an early candidate for electrification. Can’t see it happening though, especially with bi mode electro diesel locos).
norbitonflyer
24 Mar 2020
SW London
It is difficult to consider the profitability of any line in isolation. Certainly it would carry much less traffic if it wasn't connected to anything at Ipswich. If electrifying it would allow simpler, more reliable locomotives to be used on the entire journey, it would be worth doing even if the cost of electrification outweighs the savings in costs attributed to that line alone.
To take an example - electrifying the short spur between Acton Yard and Acton Wells junction would allow conversion to electric traction of freight trains over a wide swathe of the Western Region, as it would give electric trains from the GWML access to the Great Eastern and East Coast Main lines
Which trains? There’s not that many that this alone would trigger electric traction.
westcoaster
4 Dec 2006
DTOS A or B
There is a trial going on at Wellingborough on the MML for a retractable OHLE (rigid conductor bar), over a stone unloading siding. To allow electric locomotives to operate stone trains.
GB
16 Nov 2008
Somewhere
Can't see that being shoe-horned into an existing container terminal.
Wyrleybart
29 Mar 2020
South Staffordshire
Sorry. There is no comparison. Everything that runs along the Felixstowe line needs to be electrically powered, and could be if NR / GBR installed to catenary.
There is very very little, or actually nothing at all through Acton Wells which could currently be converted to electric traction and save the planet. If the Berks & Hants were electrified, and FLHH were so minded then the jumbo trains from the Westbury quarries could run under AC traction to Acton for diesels forward, but that would involve using diesels to trip the wagons into Westbury, and would require access to Acton yard to forward the traffic from there.
There are, or should be, shovel-ready electrification projects which NR could get on with, if only it had a budget. The completion of Filton - Chippenham for a start, but the reason I mentioned the Felixstowe branch is because it is a fairly simple standalone route, which, although tricky to arrange possessions etc is relatively simple to be done, partly because it is single line.
hwl
5 Feb 2012
The bigger container terminals with decent number of train per day are ideal for a decent battery spec battery shunter e.g. Clayton Class 18.
Wyrleybart
29 Mar 2020
South Staffordshire
Especially if they can stand under the 25kV or over a charging rail between shunts and keep topping the batteries up. .
They won’t need to. Their battery capacity covers over an hour at full power. They also regen back into the battery. 2-3 hours a day plugged into the equivalent of a Tesla supercharger will be enough.
Doomotron
25 Jun 2018
Kent
All main line-registered steam locos are class 98 in TOPs. The 92s are already rated at 87mph (140kph) - would a re-gearing allow 100mph?
Well, they're certainly powerful enough for 100mph or even more.
XCTurbostar
13 Sep 2014
Following the success of the EURODUAL, Stadler is delighted to announce the introduction of 6-axle dual-mode locomotives in the UK. Stadler, Beacon Rail and GB Railfreight (GBRF) have signed an agreement for the supply of 30 Class 99 locomotives including spare parts.
Able to reach speeds of up to 120 km/h, the powerful machines can run on 25 kV AC electrified lines with a power of 6,000 kW at wheel. In addition, they feature a high-power low-emissions Stage-V engine allowing operations on non-electrified lines. In line with our commitment to decarbonising rail transport, the Class 99 represents a new generation of locomotives that offers rail operators many economic and environmental benefits facilitating the modal shift from road to rail.
From the Stadler Facebook Page
Roast Veg
28 Oct 2016
Well they certainly carry that Albuixech heritage, and no odubt Co-Co will be welcome on what I assume is a longer and heavier build.
