GBRf Class 99 - 30 locomotives now ordered
92002
27 Mar 2014
Clydebank
99008 without 99009 doing :-
Mossend
- 0Z01 07:10 to Perth
- 0Z02 09:25 to Mossend
- 0Z03 12:45 to Stirling
- 0Z04 13:50 to Mossend.
Currently should be on 0Z03 BUT either running late or not going to happen !.
(the first two ran).
Action showing at Mssend Loco Holding Sidings :-
0Z03 now shown as cancelled.
Peter Sarf
Croydon
99009
4 Apr 2025
Chesterfield
After 2 weeks away after being extremely busy, I'm back and attempting to catch up on everything. It's going to take all day!
A couple of things so far I've noticed. I apologise if this is already known, I'll slowly be working my way through this thread today.
99002 did work 4M01 on 02/09/26 and 99005 did work 4M47 on 02/09/26 despite RTT having them swapped.
99006 almost certainly went to Whitemoor on 0E06 23:15 Peterborough - Whitemoor.
The first big question I have is this. 99003 worked 4L68 on 03/09/26 (Thursday) and got heavily delayed. 4M68/4L68 on 04/09/26 (Friday) was then cancelled. The next working I have for 99003 is Peterborough - Leicester on 11/09/26! So does anyone know please how 99003 got from London Gateway to Peterborough and when, as I haven't been able to find anything!
Adrian Barr
2 Jul 2020
Doncaster
There's a mention in TRUST of the already late 4L68 on 03/09 getting a plastic bag wrapped around the pantograph between Grays and Tilbury (changed to diesel mode and lost 5 minutes).
Looking in TRUST for a direct service from London Gateway to Peterborough Yard, the only regular weekday move that comes up is 4E00 which is booked to recess there for an hour (4E08 and 4E19 are just crew relief in the station).
I think 99003 most likely moved to Peterborough either on Friday's 4E00 (04/09), or possibly remained at London Gateway for a couple of days and moved to Peterborough on Sunday evening's 4E08 (which terminates there). Either move would have occured either too early or too late in the day to have a good chance of being photographed.
Given the relatively short time between 4L68/03 arriving and 4E00/04 departing, plus the possibility of plastic wrapped around the pantograph, I think a movement on Sunday's evening's 4E08 might have been more likely, as it may have taken a little while for a decision to be made as to what to do with the loco and where it needed moving to.
TOPS isn't very helpful because it shows 99003 being retrospectively teleported to Peterborough on 4L39 from Wakefield on 10/09.
Tobytrain10
2 Feb 2026
Lincoln
It arrived on 4E00 on the 10/09/2026
Railcam confirms it aswell as i remember seeing 99003 and 66717 allocated togethor last week on RTT but its vanished now
Also im going to add
This ran on 15/09/2026 aa 99013, but the headcode was misinputted at OD32 so never picked up on any signal section and was auto cancelled
800001
24 Oct 2015
Been told that 99012/013 will work Donny-Millerhill on Tuesday next week to get RHTTs up there, then up to Inverness.
Tony2
7 Apr 2019
Allocations have appeared for 0Z98 this morning, 99009 and 99008 as expected.
6Z98 to Inverness is 99009 leading 99008 double headed on 5 RHTT wagons (if I counted correctly!).
47286Dan
27 Dec 2018
This is a TOPS list of the 99s as of 14:36
It has 99005 on 4M47 but we all now that TOPS has been incorrect with these allocations
99001 GBNX BIRCHCPGB 664L681M18 8 * THLG GBRF N
99002 GBNX GRSTNCTGB 366L48CQ18 2 * DGNHMDKGB N
99003 GBNX PBONYGBRF PBONYGBRF F N
99004 GBNX THLG GBRF 514M011H18 8 * EMGGBRF N
99005 GBNX THLG GBRF 514M47CJ18 8 * HAMSHALGB N
99006 GBNX LESTER SD LESTER SD F N
99007 GBNX GOOLEGWGB 206X221F18 4 OLD DALBY N
99008 GBNX MILHIL YD 046Z982I18 C * INVRNSSCR N
99009 GBNX MILHIL YD 046Z982I18 C * INVRNSSCR N
99010 GBNX PBONYGBRF PBONYGBRF D N
99011 GBNX PBONYGBRF PBONYGBRF D N
99012 MBEL GOOLEGWGB GOOLEGWGB F N
99013 MBEL LESTER SD LESTER SD F N
Its definitely not on 4M52, its on 4M01
I think you have mistaken them because they are currently very close togethor
Dan
Tobytrain10
2 Feb 2026
Lincoln
Yeah, railcam has 99005 on 4M01 with a note saying RTT is wrong, and the fact that @D1511 has said 99005 is on 4M52, which is wrong, and 4M01 being roughly 3 minutes behind it currently suggests that 4M01 is 99005
Also im pressuming 99012 is also on 6X22 but is not in system, probably because its on the back and someone forgot to input it
D1511
29 Jul 2023
WCML N
Thanks, corrected that now.....and it's a FLT service anyway! 9E at Hanslope confused me for a minute there!
Yes, 99005 deffo on 4M01......just overtook it again
Trainman40083
29 Jan 2024
Derby
6X22 had 99012 on the front, 99007 on the back when I saw it just after noon.
mm3309219x
17 Mar 2025
Is this the first time a 99 has worked a London Underground stock move? Definitely caught me by surprise, is it a one-off or are they expected to appear on this diagram more frequently in the future?
Tobytrain10
2 Feb 2026
Lincoln
First time, and looks like it may have been a last minute decision, the move from leicester to doncaster was put as an 0E57 which suggested it would be 57s
JohnMcL7
18 Apr 2018
It was 99008 and 99009 that came up to Inverness which unfortunately I missed today, wondering when/where they will be moving to next?
800001
24 Oct 2015
008 and 009 took two rhtt sets up today so no extra sets needed?
They are certainly booked to bring another set next week up to Millerhill.
And what I was told is that 012/013 would then continue into Inverness.
99009
4 Apr 2025
Chesterfield
Thank you to everyone who replied about my previous question.
99001 and 99002 are complete on my records. 99001 worked 0Z08 and 4L08 on 04/09/26, 4M68 on 05/09/26, 0D72 and 4L72 on 07/09/26 and then the 4M68/4L68 diagram up to 11/09/26 with the exception of 09/09/26. It then worked 4M68 on 12/09/26, 0L72 throughout on 14/09/26 (photo on Trainlogger at Walsall) and is now still on the 4M68/4L68 diagram. 99002 worked 0Z26 Leicester - Garston on 08/09/26 and unless anyone knows otherwise has remained on the 6L48/6X41 Garston cars diagram ever since.
Now for the next question which I suspect TOPS won't have any clue about.
What worked 0Z98 Peterborough - Leicester and 0E99 Leicester - Peterborough on 09/09/26 please and was it 99013 on its own both ways?
If I've got everything right, when 0Z98 and 0E99 were on the move on 09/09/26, 99008+99010 were on 4H31/4D32 while 99012 was on 0Z07 Doncaster Decoy - Peterborough. 99012 definitely worked Peterborough - Toton via Doncaster and Chesterfield on 09/09/26 on its own. There was an 0Z64 Peterborough - Doncaster Decoy earlier that morning which I believe was also 99012 on its own and not with 99013 as the data systems suggested. 99011 was supposedly at Whitemoor on 09/09/26. By process of elimination, that means it was surely either 99013 or another class of GBRF loco. Does anyone know for certain or can provide further info please? If it was, 0Z98 was 99013's first ever solo working.
92002
27 Mar 2014
Clydebank
Reports elsewhere that it could be the snow train for Inverness next week.
So maybe not RHTT related.
Tobytrain10
2 Feb 2026
Lincoln
So, railcam supplys 0 knowledge of the actual paths (both unallocated), and its too late to use rail record so by using process of elimination that you have already done and i have checked over, i think the only 2 options for it is
1: 99013 both ways solo.
2: 99013 solo going, 99013 and 47739 return
It all depends whether
A: 57306 actually ran to peterborough at all on the 10th, leaving 47739 to have worked 0E12 alone
B: 47739 ran togethor with 57306, and stayed unallocated.
Or
C: If they sent 47739 on 0E99 on the 9th
I think it might be worth trying to find pictures of 47739 and 57306 to try and find what happened
