Future of 22x Units
Sad Sprinter
5 Jun 2017
Way on down South London town
When will they electrify Sheffield to Birmingham? Couldn't XC then use IETs? The Voyagers could then be scrapped or replaced what little HSTs remain, and the class 222s I suppose could go to long distance regional services.
greatvoyager
15 Aug 2019
Exeter
Is Birmingham to Sheffield due to be electrified?
greatvoyager
15 Aug 2019
Exeter
I mean, it was at some stage. I have a Rail mag from admittedly 2011 that showed Bedford to Sheffield electrification and a possible Birmingham to Derby electrification. But those were sweet, sweet naive days..
I see, if that had happened the future of 22x units would be bleak.
greatvoyager
15 Aug 2019
Exeter
I think 222s could be good for the Liverpool-Nottingham service, seeing as they are sometimes used on that route.
sprinterguy
4 Mar 2010
Macclesfield
TPE, if it is indeed they who take on that service as strongly rumoured, probably wouldn't want another type of stock for crews to have to learn.
class 9
18 Nov 2010
Whoever ends up running the Liverpool -Nottinghams, I would imagine that some staff would be TUPEd over from EMR and they will sign 222s.
43096
23 Nov 2015
Will they sign 222s, though? Not all the EMR "local" links sign 222s AFAIAA.
greatvoyager
15 Aug 2019
Exeter
Hypothetically speaking if they were ever given electric pantograph cars, would 1 or 2 carriages be added?
adamedwards
4 Apr 2016
A far more likely scenario is a the temporary use of the 221s from Avanti WC and the 222s as a quick fix for over crowding and then a new franchise getting rid of all of them replaced by something bimode, as the fuel savings Doncaster to Edinburgh and Machester to Birmingham will be worth it and the diesels will be much more efficient. Some 220s, 221s and 222s might then go to replace the Castles and Inter7City trains, but given the poor seating layouts, far more likely they get scrapped.
greatvoyager
15 Aug 2019
Exeter
Most people seem to think that, I think all 22x units will end up at XC, and then be replaced when they are life expired.
greatvoyager
15 Aug 2019
Exeter
So replacement with bi modes is highly likely, so the 220/221/222 units will probably be retired after that. Thinking about it they would be surplus to requirements.
The Ham
6 Jul 2012
It would appear that you need a transformer for every 5 coaches, so a 5 coach train needs 1 whilst a 6 coach train needs 2. 9 coach trains are fine with 2, whilst 12 need 3.
Therefore to lengthen a 4 coach train means the creation of a 5th coach.
However a 5 coach train would need 2 extra coaches to hold the two transformers.
That could get fairly expensive fairly quickly (what with ~40 X 5 coach units).
As such it could be cheaper to create 9 coach units by removing 1 existing coach from the 5 coach units to the replace with a transform. That releases 20 coaches from the existing fleet, these could be added to the upgraded units and a second transform be added to create 9 coach units.
They would be
5 coaches existing
2 coaches transformer
2 coaches from the rest of the fleet
That would give XC (if my maths is right) a single length of "short" trains (69*5 coaches) and some 9 coach units (7*9 coaches).
The 9 coach units would be of a comparable capacity to a pair of units. The problem would be that just for their fleet XC would have an order of 87 coaches, which isn't quite 100. 100 coaches is the approximate level where the cost per train falls to a fairly reasonable price per coach.
Repeat for the VWCT fleet, with the removed coaches moving to XC and XC could gain another 7*9 coach units (total of 14) at the cost of 7*5 coach units (total of 62). This would get us to 114 coaches.
This would compare with 126 new coaches but a mix of 5 and 7 coach units.
class 9
18 Nov 2010
Is NOT-LIV classed as ‘local’ though?
Are the Intercity and regional links separate? Thought they did a mixture of work.
gingertom
19 Jun 2017
Kilsyth
They would be
5 coaches existing
the other thing to throw into the mix is, would the transformer car(s) be equipped with a diesel genset? If it isn't, the others will have the dead weight of another coach to haul, reducing the performance on diesel. If it is equipped with a diesel, would it have grandfather rights and be allowed to be a 750bhp Cummins 19QSK like the rest of the rake, or, if it is classed as a new build, would it have to be different conform to the latest emission regs? I can't see maintenance staff being happy with a mix of engine types in same rake.
There would be a good case for replacing all the engines with more modern ones.
43096
23 Nov 2015
The split is essentially on the lines of the old Midland Mainline and Central Trains parts of the franchise (or InterCity and Regional Railways if you go further back!) though obviously there has been some cross-training (e.g. some “local” crews sign 222s and HSTs).
43096
23 Nov 2015
It’s doubtful that you could fit an engine, alternator, cooler group etc and fit a transformer as well underneath.
Are you going to build a new depot to maintain these hypothetical 9-coach trains?
gingertom
19 Jun 2017
Kilsyth
agreed, otherwise it would have been done long ago. There's good reasons project Thor was too expensive to proceed.
gingertom
19 Jun 2017
Kilsyth
if the rest of the rake was upgraded with, say, the MTU as fitted to the 80x then you'd possibly get away with being "one short" especially in a 5car extended to 6. However you would probably need to retraction with uprated motors to take the higher power, larger cooler group needed, higher fuel consumption therefore reduced range etc etc. Am expensive nightmare. Best leave as is.
greatvoyager
15 Aug 2019
Exeter
The 22x is overpowered anyway. They can run with an engine out and keep time.
