Four trains in one platform at the same time
Tester
5 Jul 2020
Watford
This morning in platform 11 at Glasgow Central I found no less than four trains - from front to back:
2A36 0654 to Barrhead (2×156)
1L79 0707 to Carlisle (1×156)
1A08 0725 to Kilmarnock (2×156)
2P08 0757 to Newton (1×380)
Total 13 carriages
Is this a record?!
dk1
2 Oct 2009
East Anglia
Total 13 carriages
Is this a record?!
These things frequently happen in the morning around the country after overnight set up of units for the following mornings start of service.
Mcr Warrior
8 Jan 2009
Presume platform 11 at Glasgow Central is the lengthiest at the station which makes this possible in the first place (and so also limits the number of other possible locations around the network where a similar arrangement might be do-able / practicable).
Taunton
1 Aug 2013
Leeds used to regularly do this for westerly departures, with 2-car Modernisation Plan dmus/Pacers.
Sheridan
11 Jan 2012
Holyhead platform 2 regularly sees 4 trains in it ready for the start of service, and very occasionally 5 trains, if they’re all single units.
dk1
2 Oct 2009
East Anglia
Norwich often had the likes of…
Platform 3
05:33 Cambridge
05:36 Lowestoft
05:49 Liverpool Lime St
06:51 Liverpool Lime St
Platform 1
05:10 Sheringham
05:30 London Liverpool St (12-car)
If you want the earliest departures then you need to be there in good time as you have quite a hike ahead :D
Stan63
20 Apr 2014
Paisley
I have seen the sleeper at platform 11 in the morning when it can't get into it's usual stance at platform 1. It's quite a lengthy platform and if you look on google earth you can see it extends over the river Clyde.
Stan
Roast Veg
28 Oct 2016
Fairly confident that I've seen 4 DMUs stabled overnight at Leicester on the same platform - 2 XC and 2 EMT (as was), ready to head in opposite directions.
ValleyLines142
25 Jul 2011
Gloucester
Total 13 carriages
Is this a record?!
Apparently the 0700 to Ayr departed from platform 11 as well! (pair of 380s).
Wilts Wanderer
21 Nov 2016
Most unusual instance I've seen was 5 northbound Valley Lines services in Cardiff Central platform 6 during a Millennium Stadium post event plan. Trains to Treherbert, Rhymney, Merthyr, Coryton and Aberdare, something like that. They had not detached from one convoy, it was just being coordinated between signalling panel and platform staff to keep the service moving. Probably less likely now with ARS as you only have a certain number of 'berths' in each platform.
Tester
5 Jul 2020
Watford
I noticed that in RTT after the event and can confirm that it was definitely incorrect!
2A36 left, then mine (1L79) - neither sign of, nor room for, the Ayr train!
Peter0124
20 Nov 2016
I believe RTT can get platform 10/11 mixed up, so the Ayr train used Platform 10 I think.
Tomnick
10 Jun 2005
It's quite common to have the units for five, if not six, services stabled at Nottingham in each of (usually) platforms 1 and 3 at the start of the day, e.g. first two passenger services to Worksop at one end, first Skegness leading at the other end, Lincoln behind that and finally a set of empties to Newark.
During the day, certainly pre-Covid, it wouldn't have taken much disruption to end up with five trains in a through platform. Leicester - Lincoln in first, followed by a Liverpool - Norwich to detach a portion at the rear, with an XC unit coming in behind that and finally an arrival from Mansfield dropping in on top for a short turnaround before going back out to Worksop. The first couple were booked to have left before the last couple arrived, but everything still had to be drawn right down to make room, and it would only have taken a 10-15 minute delay to the Lincoln going to end up with them all stacked up.
