Forth Bridge Experience
Hadders
27 Apr 2011
I did the 'Up at the O2' a few years ago where you get to walk over the top of the O2 in North Greenwich. IIRC we had to hand in cameras and any other 'loose possessions' but we were allowed to take a phone, on the understanding that it was kept inside the pocket of the protective suit we had to wear, until we reached the summit when we were allowed to take photos.
Suspect something similar would operate at the Forth Experience.
24 Sep 2020
Midlothian
Time will tell of course, but personally I'd have thought that the Forth Bridge Experience will have more in common with the Sydney bridge one than the O2, whose shape presumably doesn't entail any potential long vertical drops onto passing trains, boats, staff, etc? No doubt there'll be a significant amount of effort put into safety management, but there doesn't seem to be much spelled out in the planning documentation linked earlier, other than confirmation that all participants will be harnessed to a continuous safety rail (as with both other experiences).
That would be a reasonable way to operate - being allowed to bring something small enough to fit into the pocket and you can take it out when you're on the viewing platform which, one would presume, would have both a solid floor (or one with small holes to allow drainage) and a net around the outer edge.
After all, as they say: Pictures, or it didn't happen!
alxndr
3 Apr 2015
That does make a degree of sense, but I'd personally feel I'm more likely to drop a small untethered phone than a camera that's ergonomically designed and secured to a strap around my neck. When I'm working at height anything that could fall gets tethered to me after all.
RSimons
15 Dec 2016
Alberta
Well I suppose this is one advantage of an almost comically overbuilt bridge.
My understanding is that another engineer expressed a similar opinion before designing the Quebec railway bridge which collapsed during construction.
Strathclyder
12 Jun 2013
Clydebank
Indeed, although in the second collapse it appears not to have been the design of the bridge that was at fault: https://en.wikipedia.org/wiki/Quebec_Bridge.
Aye, it was the abrupt failure of the machinery being used to raise the centre span into position that was deemed to be the cause of the second collapse, although German sabotage was initially suspected. That such a line of thought was seriously considered is not a surprise considering it occurred at the height of World War I and Canada was a major player in the Allied side of the conflict.
swaldman
19 Jan 2013
Oh, excellent! I did the Sydney Harbour one twenty years ago, and hopefully will be able to do this one soon :)
VauxhallandI
26 Dec 2012
Cheshunt
I did the bridge experience in Lisbon and it was pretty good, it even goes over a railway.
Everyone else went to a Banksy exhibition half a mile up the road; I still tell them I made the best decision
