Foreshortened Termini
montyburns56
5 Oct 2015
I didn't realise until recently that Morecambe station was another one of those where BR abandoned the original station and built a new one further up the line, so I wonder which other ones are there?
The ones that I know of are...
Bradford Exchange to Bradford Interchange 1971
Fort William 1975
Morecambe Promenade 1994
Also is it only a recent phenomena or was it ever done in the olden days?
Springs Branch
7 Nov 2013
A couple which spring to mind are:
  • Blackpool North - current station was rebuilt in the 1970s at what were previously the excursion platforms and located slightly further away from the seafront than the original North station.
  • Balloch - current station is further from Loch Lomond and was relocated there to avoid the level crossing when Balloch Central and Balloch Pier stations closed in mid-1980s.
  • Sheringham - BR station was relocated east of the level crossing to allow elimination of the crossing in the 1960s. Original Sheringham station was to the west where North Norfolk Railway is now.
[Edit] I think Windermere, Southport and Windsor & Eton Central can be added in a "somewhat truncated to allow shops to be built in front" category.
superjohn
11 Mar 2011
Felixstowe, 1970 - The original station was closed and converted into shops. The new station was a single platform halt formed of the extremities of one of the original platforms.
Sheringham, 1967 - The original station was closed and is now home to the North Norfolk Railway. A completely new single platform halt was built on the Cromer side of the level crossing.
Uckfield, 1991 - Also replaced by a new, simpler station on the other side of a level crossing, closing the crossing in the process.
I guess King’s Cross Thameslink and Angel Road sort of count as well.
Sir Felix Pole
21 Oct 2012
Wilmslow
St. Ives, Cornwall - new platform further from town (subsequently extended), to create car park on old site.
Gunnislake, Cornwall - other side of A390 road to eliminate low-bridge.
Dave W
27 Sep 2019
North London
Stourbridge Town - the original was on the site of the bus station. The old bus station still had the retaining wall, I think, but all swept away with the new one.
Image from Wiki here: https://en.wikipedia.org/wiki/Stour...ge_Town_Station,_Michael_Westley,_1645368.jpg
Interesting in that shot where the old freight branch's bridge has been removed. As the description reads, it wasn't long after this that a unit went through the wall!
steamybrian
26 Nov 2010
Kent
Epsom Downs - new single platform station built about 400 yards short of original 8 platform station.
Looe- new station 110 yards short of original.
A slight point of order, however both Sheringham and Uckfield weren’t foreshortened as such, as both were through stations where the line was closed in one direction and the station completely re-sited to dispense with a level crossing.
This differentiates from places like St Ives or Marlow where the station was cut back to allow alternative use of the land.
GNERman
8 Oct 2008
North Yorkshire
As well as Bradford Interchange (mentioned above), wasn't Bradford Forster Square altered quite a lot in the early-90's?
I seem to think that the current station is about 50-100m to the north and slightly to the side of the original station.
Dr Hoo
10 Nov 2015
Hope Valley
Ardrossan Harbour
Windsor & Eton Central is just hanging on at the extremity of one original platform (a bit like Felixstowe)
Paddington saw the concourse enlarged by shortening some of the platforms in front of 'the lawn'
Victoria (Central side) has seen platforms shortened to create a larger concourse
Exmouth
New Holland was moved from a triangular/reversing 'terminus' to the 'avoiding line when the Pier closed
On preserved lines Wallingford has 'retreated'
On metros South Shields has been truncated twice
delt1c
4 Apr 2008
North Berwick, dont have the date original was demolished but new station had to be extended
Ianno87
3 May 2015
Was Glossop shortened slightly as the effect of when the single track switched sides of the island platform to make way for adjacent the Co-op supermarket?
Ianno87
3 May 2015
Also Paddington; the tracks used to extend back into what is now The Lawn area; so the "Zero" for the GWML is actually 0m 5ch, IIRC.
PeterC
29 Sep 2014
London Liverpool Street when rebuilt.
IIRC only partially. I know four longer platforms were cut back to form a single gateline on the West Side. I thought the other 16 were unchanged.
Nobody seems to have mentioned St Pancras (MML)
adamedwards
4 Apr 2016
Windermere counts as the trainshed is now Booths supermarket with the trains stopping at the same platform, but closer to Oxenholme.
The National Library of Scotland side by side maps show this reasonably well:
https://maps.nls.uk/geo/explore/sid...4.37962&lon=-2.90334&layers=168&right=BingHyb
Kings Cross has shorter platforms (a coach length reduction for nos 5-8 I think) to create more circulating space.
Going the other way, the honourable mention is Glasgow Queen St which has taken concourse space to allow for 8 car trains. There's another thread needed there I think!
Port Victoria station on the isle of Grain branch used to be on a wooden pier, but was moved onto dry land when the pier was declared unsafe in 1931.
Cowley
15 Apr 2016
Devon
Broad Street was cut back for a short while before closure. Also Looe station was shortened.
Brooke
13 Jan 2020
Switzerland
Ilkley I believe is also in the « slightly truncated to allow a supermarket » category, by about 50m or so.
Is Derry in a category of its own by extending to a new terminus past the original station to allow it to be taken from use? (I’m thinking of the 1980s station, before they reverted back again recently)
Jona26
2 Jan 2013
West Sussex
As was I think the single remaining open platform at Liverpool Central High Level before the station closed entirely.
theblackwatch
15 Feb 2006
Yes, Bradford FS was moved and the old station demolished around 1990.
Revilo
13 Jan 2018
Falmouth (Docks) was foreshortened for passengers in 1970 to a new station at Falmouth Town (aka as The Dell). But because of the gradient at Falmouth Town the DMUs still had to travel down to Docks to change ends, so the old line and station reopened to passengers in 1975.
