Does anyone know if Flying Scotsman is going to be repainted into its 4472 Apple Green LNER Livery at any point in the future? I don't mind the BR Brunswick Green 60103 look, but I hoped it'd come back in its most famous colours.
That’s right, although I’m not sure if any other A3s with German style smoke deflectors and double chimney may have carried Apple Green with ‘British Railways’ lettering possibly? Does anyone else know this?Is it not the case that it never carried Apple Green in its current condition?
Ah fair enough. They can’t have run for long in that specificition before withdrawal then?The German-style smoke deflectors didn't begin to be fitted to the A3s until 1960 which would have been long after any ran in apple green livery of had 'British Railways' in full on the tender.
I’d love to have experienced one on the Great Central working hard when they worked that route.The fitting with double chimneys (the reason for smoke deflectors being found necessary) by all accounts did improve their performance tremendously.
Bear in mind 2751 Humorist ran with the Kylchap double chimney and exhaust pre WW2, so an L.N.E.R. A3 in apple green isn't unusual and I personally wouldn't/don't with Flying Scotsman running as 4472 with the current chimney/exhaust. May be an idea to fit Tornado/Blue Peter style Blinkers as happened to Humorist in 1947 at some point........
I was wondering how much work would be involved to put a single chimney back on 4472? Is it basically a new smokebox, chimney and pipe work at the front end? Or is there much more to it than that?I doubt the NRM would consider fitting either type of Humorist's deflectors to Scotsman. As the NRM have stated they won't be running it in apple green with smoke deflectors I think the best chance of Scotsman appearing in LNER livery is if it spends an extended period off the main line (at least for railtours) and returns to it's single chimney state. The performance difference between a single and double chimney'd A3 is enough to make running railtours on many routes impractical due to imposing lower loadings or extending journey times to the extent of being off-putting to passengers.
Yes and no. It never ran in actual service as 4472 as an A3 with left hand drive, double chimney and smoke deflectors. Whilst it did briefly run for the LNER as an A3, this was for one year only (it was converted to an A3 during its winter 1946 general overhaul). It first received the conversion to double chimney format in 1959 and the German style deflectors in 1961 - by then it was running as 60103, not 4472.Is it not the case that it never carried Apple Green in its current condition?
That would certainly be interesting applied to some old kettle!What's wrong with large-logo rail blue?
Whatever people think of their appearance, there is no doubt the German deflectors did their job of maintaining crew visibility of oncoming signals extremely well, and that remains supremely important, along with the loco's improved performance with the double Kylchap, on today's busy railway. If Flying Scotsman is eventually retired to the museum or a more sedate existence only on low speed heritage railways, then recreation of a more original appearance would be both practical and appropriate.
So did I - thank you.What an excellent post MarkyT. Really enjoyed reading that.
Ironically MarkT the patent expired not long after Gresley. Gresley unexpectedly dying in April '41 only 2 months shy of his 65th birthday [in June '41] and the Kylchap patent expiring in around September '41....... I'd also heard/read that Gresley had want to fit the Kylchap arrangement to all new built Pacifics and retro fitted to the existing pacifics as they passed through the works for overhaul. After all as well as the 4 Blu'uns [the A4s] Gresley also had Humourist an A3 fitted too, so had experience of both style of pacific with the devise, hence his wanting it fitted to all the pacifics at least.
From The LNER Encyclopedia:Am I correct to think that Humorist was the test bed for a number of innovations being tried out on the LNER Pacific fleet?
Searching for details of what the earlier smoke lifting experiments entailed I found this from Wikipedia:The first fitting of the Kylchap double blastpipe arrangement was in 1937 to No. 2751 Humorist. Humorist had been used extensively in a series of unsuccessful smoke-lifting experiments during 1932-3. This time, the double blastpipe was fitted with a lipped double chimney, but no smoke deflectors. The softer blast from the Kylchap arrangement required the use of smoke deflectors. Small wing deflectors on either side of the chimney were fitted in January 1938. These deflectors were on the small size, but the results could be accepted. They were eventually replaced with the larger deflectors used on the new Peppercorn A2s, in 1947.
A3s 2747 Coronach and 2751 Humorist were subjected to smoke deflection trials following an accident on the London, Midland and Scottish Railway (LMS) due to poor visibility; this included the modification of the upper smokebox area surrounding the chimney. Originally the whole smokebox wrapper was retained in order to form an air duct, with the exit behind the chimney, but this was found ineffective. The next stage, at least with 2751, was to cut off the top part of the wrapper, but retaining the sloping plate that directed air flow upwards, and therefore lifting the smoke above the locomotive. The original chimney was replaced by a double stove-pipe variety, and miniature deflector plates were added on either side, angled to concentrate the air flow when the locomotive was on the move.
As the work drew to a close in late 1998, thoughts turned to what livery would be selected. It was believed at the time that it would resume running as 60103 in BR Green, however Marchington wanted it in Apple Green, as he believed that to be the better livery from a marketing and PR viewpoint.
You could’ve tinkered with the shade of Apple Green bspahh...I was working for Oxford Molecular back then, when Tony Marchington was the CEO. My desk was next to the colour laser printer. Although the printer was massive, in its own little room, it only had a small tray for the acetates, so I was always having to refill it, mostly for presentations about the Flying Scotsman.
