Flexible return - change of outbound train?
isdoo
29 Mar 2015
Purchased a flexible return today on GWR (via LNER).
This is a first class open return.
All outbound were the same after 09.30
As the journey is today can one get an earlier train or must I stick with the booked train?
Or can it be changed at the station?
I am assuming what you have is a First Off Peak Return ticket (if it was 0930 that changed the fare). If so you can use any train within its time restrictions.
If you can post a photo of the ticket with any personal details/reference numbers obscured we can confirm for certain.
isdoo
29 Mar 2015
Thanks.
The pdf version says the specific train but the eticket doesn't.
isdoo
29 Mar 2015
You can use that on any train via a permitted route within the restriction it links to.
Thanks.
Was nervous about the ticket person saying that the ticket wasn't valid and pay again.
Not really used to the various tickets
Mcr Warrior
8 Jan 2009
For the avoidance of doubt, what are the midweek travel time restrictions for the outward and return legs, for this particular ticket type, between Taunton and London?
Outward: any train from 08:16 from Taunton; also valid on the 07:23 service via Bath Spa
Return:
Not valid on trains timed to depart:
  • London Paddington after 04:29 and before 09:17 and after 16:38 until 18:36*
isdoo
29 Mar 2015
Thanks. Have a great day
Thanks again.
Final question.
Got the earlier train which is over 15 minutes late. So entitled to a partial refund via GWR
Not really sure how I prove that I was on the train as no tickets have been checked.
Or if I scan out at Paddington will that suffice?
Apologies for the questions.
Thanks again.
Final question.
There is no need to prove anything. Claims are essentially taken on trust; scan history would trip up a fraudster quickly enough.
Thanks again.
Final question.
Just to be clear technically it is a Delay Repay claim to GWR (as the operator).
Refunds are slightly different and don't apply in this case; refund requests go to the retailer rather than the company travelled with.
Thanks.
If you travel on a train that is not valid by the time restrictions, you can be asked to pay the difference between the price paid and the lowest priced fare that would have been valid.
The time restrictions applicable to the ticket aren't the only thing to consider in the case of a Two Together Railcard though as you also need to consider the T&Cs of the Railcard itself.
