Robertj21a
- Joined
- 22 Sep 2013
- Messages
- 7,691
One wonders about some of the other vulnerable outposts; I can think of two in the South West that I've mentioned before.
I never for one min, expected further depot closures, nor did I expect three at one once.
Musselburgh?
Musselburgh?
It didn't need much 'reading between the lines' in the last Group statement from First to guess that some more tough decisions would be needed if they are to ever get out of the mess Lockhead left behind. It might be pertinent to also recognise that these 3 depot closures, sad as they are, will still only make a very small contribution to the piggy bank. Much more still needs to be done.
I don't know if that's the issue so much as adding to the piggy bank. They won't make off NuL. Hereford will provide a property benefit as will Bracknell (plus selling the 90). They will also be able to redeploy DDA fleet to see off some of the non compliant tat as well.
It's something that all the groups are doing. Stagecoach are closing three depots (all beginning with C, strangely). Fewer council contracts mean lower PVRs, and more competition for what remains is higher.
It comes as passengers have been warned to expect even more changes to First's timetables later this year.
The move has been blamed on Government funding cuts, the current economic situation, and a lack of passengers using the network.
The maths behind the Hereford and Newcastle closures are as follows:
Potteries has a 50-vehicle DDA problem looming. Close Newcastle, take about 25 out of the PVR and transfer the 20-odd DDA compliant buses from Hereford to the Potteries, plus the four 'nearly new' ones mentioned by the local media, and there's your problem solved.
It's just a very, very shabby way of dealing with something that years of chronic under-investment in the Potteries operation has created.
Agreed. I was only trying to emphasise that the task ahead of First Group is still massive - and this is miniscule. Even so, they have to start somewhere and under-performing depots is as good a place as anywhere. Ironically, as you mentioned, Hereford had only recently gained some extra work.
Robertj21a; Completely agree,
I wonder if what is happening is that Giles Fearnleys efforts at reviving the Firstbus business have worked in the 'Good' areas but the bean-counters and realists are now saying "Times - Up" for some of the consistently under performing territories. It looks as if 'Return on Capital employed' is the major factor here, a business has to be more than just in the black, it has to show a decent rate of return.
Other parts of the First bus business I would watch are;-
* FSE
* Yeovil
* Plymouth
* Cymru
But are we sure there are cutting 25 buses out of the network? There are a few other places with soon to be spare stock, which could also help bring that number down a wee bit.
I've been asking about this for years, yes you need time to overhaul bad areas. I fully understand what many people have said and postaged on this subject, of course some of the araes have managed to be improved. But I did say " someone going to get fed up and wonder why are we -as in First; continual wasting more money?
Ie lets just cut and run and save lots of money instead.
Any money that has been spent in the bad area at least went on new stock. To be fair Wales and FSE got a piece of the action. Mind you FSE have also made cuts of greater than what's being suggested for the Potteries area, but I'm hopeful FSE two sperate accounts for upto April 2015 will at least break even.
"Times - Up" was always going to be on the cards unless someone was more optimistic about turning some of these areas around, I never believe that was possible.
Does Arriva do alright in the Potteries area? Could we see Yeovil being transferred to the buses of Somerset? When it comes to FSE, its only the East Lothian area which is the problem, and there is a rumour going around LCB are planning improvements in November![]()
FSE
Yeovil
Plymouth
Cymru
There are plenty of new buses coming to more than eliminate the non DDA single deckers. First have said that there will be just a small number of non DDA double deckers to replace next year.
They're going to have to, as there simply isn't the room at Adderley Green to take in all of Newcastle's work, in terms of both vehicle and driver car parking.But are we sure there are cutting 25 buses out of the network? There are a few other places with soon to be spare stock, which could also help bring that number down a wee bit.
Isn't there supposed to be a decent number of new deckers on order for 2016? That's what I kept on hearing.
Is therw any spare land at the other depot around stoke on Trent.
There has long been a shed which is used for withdrawn buses, which certainly recently was full of old Scanias awaiting the inevitable trip to the scrapyard. This can accommodate about 15 buses. There is also one corner of the yard which was occupied by similarly decrepit Scanias received from Northampton when the depot there was finally cleared, and while these have gone this is regularly used for withdrawn kit.Just for ref, how much junk is sitting in the depot? What routes in the Potteries area are poor?
Expect for No38 which is one bus, and No43 which is two buses.
I doubt they have even got to the stage where manufacturers are even tendering for 2016's orders. A lot can happen between now and then in terms of fuel-saving technology and First will no doubt be keeping their powder dry for a while before pulling the trigger.Isn't there supposed to be a decent number of new deckers on order for 2016? That's what I kept on hearing.
There must be about 160 (?) buses in the Potteries fleet at present.
There are currently 106 buses allocated to Adderley Green, and 68 buses allocated to Newcastle-under-Lyme, making a total 174 buses.
Quick note: when Badgerline bought PMT (albeit that it had Pennine and the Crosville/Red Rider ops, it had about 500 vehicles. The Potteries area probably had 300?
Appreciate it suffers deprivation and economic woes but it should be good bus territory.
Thanks for that. So if they now want to use only the one depot at Adderley Green (after clearing out 'junk') it looks like it will need quite a reduction in fleet size of at least, say, 25-30 vehicles.????
It will be interesting to see their revised route registrations.
