Trnsprt4Sctlnd
A relatively cheap way to “try” and advertise your services.Yes I don’t think the Geminis or Eclipses have ever received a proper refresh. It’s the same interior from when I was younger.
One thing I don’t like on the Eclipses are those hideous blue adverts all over the saloon.
This is true, it has been found that the flat strip that lays at the bottom of the side windows facing towards the interior has became loose through the bus hitting ruts & potholes, the fitment being poor on the single decker EV’s.Being a regular user of the EVs on the 9s there's still issues even with new buses such as panels not screwed in properly after maintenance
I’ll apologise in advance, The words of enthusiasts…The cooling fans on the B7TL and fan belt screech are just noises the bus makes that you’ll hear on the same vehicle makes right across the country, they’re nothing to do with poor maintenance by First Glasgow
The OP mentioned it was one of the old Eclipses not an EV
Any B7TL, given there age, the screeching belts are due to either the belt itself becoming “stretched” due to age not to mention a belt pulley or tensioner becoming seized or just weak.
An engine belt screeching is not normal & can be sorted.
