First Greater Glasgow
lastbus
9 Sep 2018
I believe that is their intended route but they won’t be branded so they can be used on other routes.
I wish the 2 were getting new EVs. Hopefully if the 77 gets new EVs the deckers from there can cascade on to the 2.
They will be branded ones already arrived with a green front similar to that of kings coaches.
EMU303
24 Aug 2016
Have Caley depot stopped operating their half of the 2?
According to the Glasgow Bus Website there are 23 buses branded for the 2 and all are at Scotstoun
I know I just mean in the near future.
I read in Buses magazine recently F Glasgow MD saying the costs of getting additional depots hooked up to the grid are "eye watering" and I think he mentioned something about having a site or sites identified but set up costs were a challenge. It wasn't clear if he was talking about upgrading existing depots or identifying new sites. He did mention that overnight charging of buses enables the charging points to be used during the day by other users (although it wasn't clear who those users may be) but that Caley had the space to do so. And that if they could rent some of that space during the day it would help influence the cost effectiveness of adding charging points to other depots.
JumpinTrainz
30 Jul 2018
It’ll be interesting to see what they do as eventually all routes will have to go electric as time goes on. You have longer routes like the 1, 2 and Lanarkshire routes which may be a challenge with charge range. Not an easy task to achieve.
I have seen a photo of one with a green front, which looks like the 7/7A colour.
Do you have a link?
EMU303
24 Aug 2016
Yes, perhaps they might need to install charging points at some termini points but not sure how much of a "boost" that would give with relatively short lay over times. Would a ~15 minute boost be enough at each end? But if a bus is running late then that compromises things, with a higher risk of delays on longer routes.
31 Dec 2021
What they need is at least 5-6minutes using high power Pantographs installed.
Glasgowbusguy
21 Feb 2019
I wonder if SPT would install charge points at Buchanan bus station. Maybe in the central reservation or the tour stands where there is shore power already; it could allow drivers to swap buses by placing one on charge and taking one off charge.
JumpinTrainz
30 Jul 2018
It looks like a similar colour to the Overground 88 colour. I wonder if we have more routes to be done. There’s not been a light pink, dark orange or purple yet but they’ve explored most shades of blue and green.
31 Dec 2021
That green looks decent on those EV's, glad it's darker than the lime green livery for the 2 or there would be confusion for passengers - and that's definently the 7/7A livery because on the network map that route has the same colour
If these are for the 7, by God its gonna look like a cram packed sardine tin on wheels!!
Busman84
9 Sep 2019
East Kilbride
The 7 should really be deckers. I think all the core routes should be double deckers. There are more routes that are now decker routes however all these routes have seen service levels reduced over the years. Singles create longer journeys when busy as people standing, so does mean it’s longer to board and get off.. The 2 and 3 are other services that should have deckers although you do see the 2 on a Sunday being mainly deckers.
JumpinTrainz
30 Jul 2018
Since the start of the pandemic the 2 has been mainly deckers. It’s always confused me as to why First have always been determined to make this a single deck route. The 2 has been virtually unchanged over the years and sees very good passenger numbers. It would really benefit from deckers.
If the 77 does go to Caley and get electric stock it would be nice if the current branded 77 E400MMCs went on the 2 and even had a mixture of E300s and E400MMCs. The 2 hasn’t had new buses in a while now for such a core route.
computerSaysNo
14 Dec 2018
Do deckers cost much more to operate than single-deck vehicles? Obviously they cost more to purchase but I wouldn't think they would cost much more to run on relatively low-speed city routes?
scosutsut
1 Jan 2019
scosutsut
I would assume higher fuel consumption (or charge usage) but you could run the same route capacity with less vehicles and right now - critically -less drivers.
JumpinTrainz
30 Jul 2018
Routes like the 46 and 19 can run half empty with B7TLs which I think rules that out. The 2 is a busy route which would actually require the extra capacity. This route used to have a mixture of deckers and singles and also bendy buses at one time.
Jarcoed
25 Jun 2021
Glasgow, Scotland
The 46 is usually more popular in the evening, I find. I usually catch the 16.15 from Easterhouse and it tends to get busy around the Parkhead area of the journey, though doesn't need deckers.
Stan Drews
5 Jun 2013
The average fuel consumption is lower, probably around 5-6 mpg on intensive urban work, when some single decks may be in the region of 7-8 mpg. That might not sound significant, but is around a 25-30% increase in fuel cost.
I don’t have equivalent figures for electric buses, but they will certainly use more juice than single deckers, and I wouldn’t be surprised if the % was similar to that for diesel buses.
31 Dec 2021
Of course diesel DD vehicles cost more to run. Their driveline and engine layout is usually transverse through an angle drive into the gearbox; extra mechanicals alone lead to lower fuel economy.
Single deckers generally use an inline layout without the need for such extra equipment.
Keep in mind that the likes of an E200MMC is 8 tons is using a 4 cylinder vs an E400MMC being around 10-11tons driven via a 6 cylinder.
Comparing DDs against heavy weight singles like a Volvo B8RLE or Scania's new Fencer is harder to justify on your question, given that they can be almost as heavy as Doubles.
LT02 NVV
12 Nov 2019
The route still has loads of B7s & B9 Deckers, as well as E400MMCs because of how busy it is again.
Also, back when it was the 62, even more buses were needed as the route was extended to Airdre & at peak times, to Maximum Park. This continued into the early 2 days, until 2017/18, when they decided to scrap the extension services for some reason, and replaced that extension service with the 202 (I mistakenly said the 242).
TheGrandWazoo
18 Feb 2013
All very true
As well as purchase costs, the fuel costs are a significant on-cost though some heavyweight single decks were remarkably bad on fuel (i.e. B7Ls). There are other hidden costs such as vandalism being more prevalent and also, dwell time at stops as being ascend/descend to/from the top deck. Hence why operators don't naturally default to deckers, despite that being the preferred choice of the enthusiast!
However, it may well be that with ongoing staff shortages, there may be a widening of headways and a greater reliance on deckers.
lastbus
9 Sep 2018
Also, back when it was the 62, even more buses were needed as the route was extended to Airdre & at peak times, to Maximum Park. This continued into the early 2 days, until 2017/18, when they decided to scrap the extension services for some reason, and replaced that extension service with the 242.
The 2 extension was replaced by the 202 not the 242.
PaulMc7
9 Jul 2019
Going by my 2 this morning there definitely needs to be more double deckers. One late because of the 20 min gap to the one infront and another caught up instantly but both ended up full at Scotstoun. Yes there were school kids on both but even by Thornwood the buses were both still pretty busy.
