TheGrandWazoo
Don't be rude and it's the first thing you do is be rude. You don't get that they've done nothing to the X1 at all and you fail to understand what I've said about bad press etc. It does stick a lot longer than you think and it shows which one of us is Glasgow based that you think it doesn't. You've assumed that I don't think it's a loss maker when I've also said that constantly. If you don't try and change a service ever ofcourse nothing will change but I've said my piece so if you can't get that then that's not on me as I've explained it enough. Most people use passes and longer tickets too anyway so the way forward for First and increasing passenger numbers is by making them even more value for money than they already are and reducing singles slightly
I wasn't being rude just that we're still going over things that have been explained to you. For example, reducing the singles cost has been explained. Given that concessionary fare reimbursement is based on the cost of a single fare, that is why they have gone up. If you reduce them, then you reduce your revenue. This is not confined to First - it is industry wide.
Think about it. If the buses are well loaded at peak so the capacity to sell is limited. If you reduce fares, peak buses are full. Only works if you can improve off peak usage but most of that is concessionary pass use anyway so it's not price sensitive. Can you understand that?
I appreciate that they haven't done enough in terms of marketing in the past but sadly, that's gone. It's in the past. The options now are
- Reduce off peak - barely a saving as the majority of costs are fixed
- Reduce frequency in full to hourly - well, that won't satisfy the peak volumes where most of the volume sits
- Increase fares - that won't be popular as you have said
- Decrease fares - I've explained above
- Reroute via Fort - increases costs and will that generate the additional revenue to not only cover the additional costs AND the current losses
