"Fill-in" electrification ideas.
py_megapixel
5 Nov 2018
Northern England
By "fill-in" I mean those little bits which seem daft that they aren't electrified, because they could reduce diesel running elsewhere, or make a fleet far more homgeneous etc etc.
In a nutshell - I'm not talking about huge new routes being electrified, rather little bits which would really benefit.
High on my list would be:
  • Coventry-Reading - would allow the XC Manchester to Bournemouth service - surely one of the worst offenders for running diesels on electrified lines - to go electric, assuming suitable dual-voltage EMUs could be procured
  • Manchester-Warrington-Liverpool - a diesel island in a sea of electricity; it's madness that the wires aren't already up.
PTR 444
22 Aug 2019
Wimborne
Some no-brainers here:
  • Reading - Basingstoke
  • Chippenham/Bristol Parkway - Temple Meads
  • Windermere branch
  • Felixstowe branch
These really all ought to be done before the end of this decade
  • Coventry-Reading - would allow the XC Manchester to Bournemouth service - surely one of the worst offenders for running diesels on electrified lines - to go electric, assuming suitable dual-voltage EMUs could be procured...
You’ve unfortunately forgotten the gap between Reading and Basingstoke. I don’t think many people would describe Coventry to Didcot as a little bit of infill, but Reading to Basingstoke possibly could be.
NoMorePacers
18 Feb 2016
Humberside
Manchester - Liverpool via Warrington - although I'm not sure if that would fit in as being "little".
High Dyke
1 Jan 2013
Yellabelly Country
Ah, so the need for dual voltage stock for the Reading - Basingstoke part. AC at one end, DC at the other.
CW2
7 May 2020
Crewe
Wokingham - Guildford - Reigate (3rd rail).
Stockport - Stalybridge (to joint Transpennine electrification with WCML for through freight operation)
Crewe - Chester
Chester - Warrington
GRALISTAIR
11 Apr 2012
Preston Lancs
Oxenholme to Windermere. All Manchester Airport to Windermere trains could be entirely electric- at the moment huge amount of running diesel under the wires.
Then down Filton Bank from Parkway to Bristol Temple Meads
David Goddard
8 Aug 2011
Ely
Leeds - Church Fenton
Nuneaton - Coventry
Ely - Peterborough
Wokingham - Ash
Guildford - Reigate
Didcot - Oxford
Hunts Cross - Deansgate
Wigan - Kirkby
Preston - Ormskirk
bluenoxid
9 Feb 2008
Lancaster-Morecambe
It is a short run with shuttle service whose electrification could enable the replacement of one diesel unit. The electrification of Blackpool removes the excuse of no nearby local EMU operator. It’s electrification would be ideal practice for a rolling electrification programme and enable evidence of northern investment.
SE Manchester commuter lines (Marple)
I think this is just over 20 route miles. The problem is the various ideas suggesting Metrolink conversion. I am probably wrong but my understanding is that Tram Trains can be dual voltage so I would just suggest getting on with a design programme. It might be beneficial to use the lower light rail voltage due to existing structures but it is not my patch.
43096
23 Nov 2015
  • Windermere branch
  • Felixstowe branch
Windermere should have been done back in 1974 with the northern West Coast scheme.
Likewise Felixstowe should have been done with Great Eastern/North London Line wiring in the 80s. There’s even less excuse now, as the local service is now worked by FLIRTs that have electric capability.
Not sure I would call Cov to Didcot "little" !
Agree entirely. Its about the same distance from Market Harborough to Clay Cross!
What freight is that?
We’ve done this thread before. Most have been mentioned, but I will chip in with the freigh5 only curves around Acton (but not the Dudding Hill Line), and the London Gateway branch.
py_megapixel
5 Nov 2018
Northern England
But it's little compared to the length of the services on it as a whole!
I'd forgotten that Basingstoke to Reading wasn't electrified... maybe that would be better served by an extension of the third rail, though I'm aware that ORR shudders at the mere thought of anything other than OHLE so maybe not...
SeanG
4 May 2013
Is there any point in these given that BMUs are being used to Felixstowe and given that Northern have ordered batteries for some 331s for Windermere?
Whilst it would be great to see this electrification, would the money be better spent elsewhere for the greater good?
py_megapixel
5 Nov 2018
Northern England
How many services on the line would convert to pure electric if Didcot - Coventry was electrified?
The main one is CrossCountry. It is absolutely ludicrous the amount that this service runs on diesel under the wires or over a third rail - all the way from Manchester to Coventry, then from Didcot to Reading, then all the way from Basingstoke to Bournemouth.
That said a homogeneous fleet of bi-modes might serve them better, but I think we should ultimately be aiming to remove diesel from the rails altogether.
It's a short single track branch which is already connected to an electrified line and causes hundreds of miles each day for diesel running under the wires. The cost to electrify it would surely be peanuts compared to one of the big headline projects like the MML.
I think Northern's new management decided that batteries weren't such a good idea after all, so I'm not sure the order has actually been placed.
23 Nov 2015
For Felixstowe the big win is enabling electric traction for freight. Decarbonisation of local services on the back of it is a bonus.
For Windermere have battery 331s actually been ordered? Last I saw the new Northern management were distinctly cold on the idea. Assuming no new grid feed is necessary it ought to be a relatively straight-forward fill-in and eliminates diesel or whatever bionic duckweed micro-fleet is flavour of the month as an alternative.
But Didcot to Coventry doesn’t help with XC, unless you do some other gaps.
Why not? I can't see anything else that would need doing, other than the comparatively short hop to Basingstoke.
There’s your answer!
And buying a new fleet of dual voltage trains of course, and a D.C. power upgrade south of Basingstoke. And after all that, you’ve only electrified half the cross country service on the corridor (in normal times).
The answer you are looking for is 1tph and only as far as Reading.
Fawkes Cat
8 May 2017
If this can be justified, then what about something at the London end to connect the GWML and WCML? That way, Paddington and Euston could provide some cover for each other.
Railwaysceptic
6 Nov 2017
There is of course a railway line in London running from the GWML to the WCML but the junctions face the wrong way for Paddington to be able to cover for Euston.
popeter45
7 Dec 2019
london
Bromsgrove - Cheltenham - Gloucester - Bristol Parkway - Bristol Temple Meads
as well as letting some XC services to go full electric would enable more freight services to use Electric Locos for the Lickey Incline
would then provide impetus for fill-ins on on the Gloucester–Newport line and Golden Valley line
Both are full. It would seem silly to try and divert trains to an a terminus that can’t take them.
MarlowDonkey
4 Apr 2013
Oxford services could be operated by 387s rather than 802s and 165s shuttling from Didcot. There's also the local service from Leamington to Coventry.
Correction, Leamington to Nuneaton, so you would have to split the service again.
Again, 1tph XC and next to no use for freight as the Camp Hill line northwards isn't electrified.
backontrack
2 Feb 2014
The UK
I think it'd make sense to get wires up on Leeds-Colton. Also, electrifying a diversionary route from Wakefield/Sandal & Agbrigg to Leeds via Methley could come in useful.
