Farringdon now a London Terminal
mattdickinson
14 Nov 2010
Uxbridge
There are posters up at Farringdon advising that it is now a London Terminal.
but only for tickets marked "Plus High Speed"....
maniacmartin
Fares Advisor
15 May 2012
Croydon
What is the exact wording of the posters? Is it possible to get a picture
Needless to say, Farringdon is not listed as part of the London Group in the Routeing Guide. However, many season between Kent and London Terminals are priced identically to a ticket from the same station to City Thameslink, which would be valid through Farringdon, so this might be there way of avoiding to do zero-fare season ticket changeovers
RJ
25 Jun 2005
Back office
There was some drama a while ago because these tickets had the unusual feature of being valid to both the London SR Terminals and St Pancras International, but not between them. I wonder if it is related?
That said, National Rail Enquiries advertises that an Ashford International to London Terminals Not Valid on HS1 routed ticket is valid to get to St Pancras via London Bridge and Farringdon, so it's already valid anyway.
Haywain
3 Feb 2013
The Manual says this:
Tickets issued to or from ‘LONDON TERMINALS’ are only valid as described above (click here) Customers with London Terminals tickets routed “Plus High Speed” are also permitted to travel in either direction on First Capital Connect services between London St Pancras International and Farringdon, City Thameslink, London Blackfriars, Elephant & Castle, London Bridge.
So, presumably, travel on Southeastern services over the same metals is not permitted! :D
hairyhandedfool
14 Apr 2008
I'm sure a simpler answer would have been changing the destination of 'Plus High Speed' tickets from London Terminals to London Thameslink.
maniacmartin
Fares Advisor
15 May 2012
Croydon
It might make the tickets harder to find in some TIS and TVMs though, as you wouldn't be able to search for a member station and easily find a ticket for the group?
MikeWh
15 Jun 2010
Crayford
Plus, aren't +HS tickets also valid via classic routes to Victoria, Waterloo, Charing Cross, etc?
hairyhandedfool
14 Apr 2008
Not sure how, my Tis at work can tell me if Manchester Piccadilly (or even just 'Manchester') is Manchester Stns or Manchester Ctlz depending on the origin. It can do similar for St Pancras, Farringdon, City Thameslink, London Blackfriars, London Bridge and Elephant & Castle.
Online journey planners can do the same.
True, but telling people Farringdon is only London Terminals for 'Plus High Speed' tickets is like telling people Advance tickets to Manchester aren't valid for stopping short at Stockport. "It doesn't make any sense!":lol:
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
However, there are no Southeastern services north of Blackfriars. The Sevenoaks to Kentish Town services switch operators at Blackfriars (even though they don't switch staff).
sheff1
24 Dec 2009
Sheffield
If some staff at London Bridge won't accept tickets to London Thameslink destinations, imagine what might happen if you presented one at Victoria or Charing Cross !
Tetchytyke
12 Sep 2013
Isle of Man
Yes, but Farringdon is only a London Terminal for +HS to allow transfer between the "classic" stations and St Pancras International. They've allowed entry and exit there to specifically allow stopping short!
tractakid
12 Nov 2012
Milton Keynes
Forgive me for thinking otherwise!
MikeWh
15 Jun 2010
Crayford
Journey planners can't show a service belonging to more than one operator, hence all northbound services are operated by SE while all southbound services are operated by FCC. In reality, responsibility switches at City Thameslink in both directions.
Eagle
20 Feb 2011
That's because the timetable data doesn't allow for a change of TOC en-route. Similarly you'll find that the journey planner will tell you that a journey from Kilmarnock to Glasgow Central is operated by Northern (if that train started from Newcastle).
Officially, everything north of Blackfriars is FCC. (And from December 2014 everything south of it will be too.)
tractakid
12 Nov 2012
Milton Keynes
But, if I book a ticket with that itinerary and it being a Southeastern train would somehow benefit me, wouldn't that be a good piece of supporting evidence?
Eagle
20 Feb 2011
Probably, although I can't think of a situation where that would apply (other than you having a Southeastern staff pass).
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
It does sort of though. Change-en-route records in the timetable data always show when there is a change of train service code, and any change in operator can be deduced from this (in fact, I believe the operator code in the timetable data is always derived from the train service code anyway and simply copied in from a look-up table).
Thus BRtimes.com correctly shows the change of operator, e.g. for Sevenoaks to Bedford or Newcastle to Glasgow.
cyclebytrain
11 Jul 2009
Setting the cat amongst the pigeons here: maybe they should just do away with "London Terminals" and have tickets to either U1 or named station only... <D
bb21
Emeritus Moderator
4 Feb 2010
What about Reading to London Terminals, as an example?
Eagle
20 Feb 2011
An what about the other London terminals that you can validly get to from Reading, such as Victoria (change at Clapham Junction) or Charing Cross (change at Waterloo)?
bb21
Emeritus Moderator
4 Feb 2010
Reading to U1 I guess.
Then you will be paying more than what you are paying now, and you have ignored the fact that a Zone U1 ticket is not valid for National Rail destinations (exceptions apply).
cyclebytrain
11 Jul 2009
I don't think making passengers pay more would concern the TOCs much. They'd probably label it as an improvement by setting the cost of a ticket to a named station lower than the London Terminals ticket it replaced.
If you were going to make the change to get rid of London Terminals, then you'd probably make U1 valid for National Rail destinations at the same time. You could call it a "simplification"
davetheguard
10 Apr 2013
Reading to Paddington, Reading to Waterloo, Reading to U1. Simple...
And what exactly, would be the benefit to the passenger of this suggested change?
Sometimes it is convenient (or pleasant) to go out one route and back by another........
H
hungoverdrawn
Guest
Confirmed. I travel to St Pancras via HS1 and work in Farringdon and had just bought a one month season ticket from St Pancras to Farringdon when I found this out. Helpful of the member of First Capital Connect to sell me a ticket that I didn't need, n'est-ce pas? I have now filled out a refund form and am getting £20 back.
Interestingly while my Southeastern ticket gets me into and out of the St Pancras FCC platforms, it does not let me in to or out of Farringdon station (either the tube or the overground entrances). I have to show my ticket to a member of staff who then lets me through. I queried this and the explanation given was that although due to this rule change my ticket is valid to Farringdon, it is not valid to any other London station.
