Ex LNER (and Grand Central) Mark 4 sets for TfW
BillStampy
6 Jan 2024
Llanharan
HD06, which is on exam, has been taken into service instead of HD02.
Seems there was confusion as 67022 was showing as attached to HD02 but i reality is attached to HD06.
That's a pretty hard mistake to make.. unsure how you mix the two up! They're both very different looking sets!!
Lurcheroo
21 Sep 2021
Wales
Well maybe for someone who knows what set looks like what. Most drivers are not into trains to that level.
I’m quite enthusiastic about them (hence why I’m here) and I wouldn’t know what colour what set is in truth.
If they’re told there’re taking HD02 + 67022 and they see two rakes of coaches, one has 67022 and the other has 67020 on the front then I can very much see how they’ve taken the one with 67022 attached even if it is the wrong rake behind it.
I do not know if there is a process they’re expected to follow to check both the loco and the coaches as I don’t go anywhere near them.
37052 xb mr
6 Dec 2023
Stockport
67022 & set HD06 have been on Canton since Friday, seems strange if it was on exam it wasn’t marked with
Do not move boards ?
67020 & set HD02 had worked 1W11 & 1V37 yesterday morning.
Should the locos have been
Changed on the sets ?
Lurcheroo
21 Sep 2021
Wales
I thought 'Not to be moved' discs were designed to mark trains not in service.
Sort of, but not quite.
No to be moved boards are places on trains that are not to be moved.
I don’t sign canton or know much about it. But there would have been a shunter involved too.
It’s possible part of the exam has been done, it’s been moved out of the shed to allow something else to go in there, so it doesn’t need not to be moved boards on it, with a plan to live it back in again to complete the exam.
Very hard to say what’s happened exactly.
sleepy_hollow
9 Jan 2018
Indeed, there are a whole host of questions relating to the physical marking of trains not ready for service, authority to do so and to release, identification of trains to be taken, assembling trains...
AndrewE
9 Nov 2015
no, just trains not to be moved - for any reason at all. One example: when water tanks were refilled at stations (even on long distance trains through Birmingham New St) from a pipe at ballast level whoever was doing it would put a 'Not to be moved' board on the platform side of the train before getting down and connecting the hoses. Obviously to prevent the hoses being ripped off by a move before the job had been completed.
sd0733
7 Nov 2012
No was nothing planned to swap, 67022+HD06 was planned on exam until today.
Seems to have started with a paperwork error and snowballed from that. Getting the set prepped and ready was one thing but allowing it to leave off a different road to the "real" rake and enter service will be a concern and I'm sure this rather bizarre incident will lead to some extra safeguards going in so whatever went wrong can't take place again.
This morning 67025 failed at Crewe with a sander fault, that locos now gone onto HD01 on exam, swapping with 67015 on HD03.
Tomorrow HD05 is needed to finish in Crewe for an exam so the 16:49 and 17:14 departures from Cardiff will swap sets.
sd0733
7 Nov 2012
Heavy or light exam? Also, may I recieve the diagrams for tomorrow? Would be much appreciated.
Only a light, should be back by Sunday/Monday.
Tomorrow should have:
67020+HD02 1V33 1W19 1V50
67015+HD03 1V31 1W55 1V42 1W96
67008+HD05 1W11 1V37 1W23 1V66
67014+HD07 1V91 1W57 1V46 1W65 1J76
HD01 is with 67025 on heavy exam at Crewe
HD04 has finished exam but locoless at Crewe
HD06 now finished exam but losing 67022 so isn't available.
Jacob Porrett
28 Jan 2022
Telford
DB Cargo were called to fix the issue with 67025 but got called off and somebody else fixed it instead which resulted in finding another fault which meant calling DB back in again
37052 xb mr
6 Dec 2023
Stockport
Thanks
Is there an issue with 022 please
And isn’t 017 at Canton ?
Thanks
sd0733
7 Nov 2012
Cheers for the info. Hopefully DB have got it sorted properly now.
Thanks
Thanks
Not sure why it's showing as coming off in all honesty.
Yes 017 is also at Canton as the recovery loco
37052 xb mr
6 Dec 2023
Stockport
Thank you
sd0733
7 Nov 2012
67017 and 022 are heading back light engine to DB for attention due to fuel leaks.
As loco availability is so bad, 67010/012/017/020/029 are all under attention at Crewe IEMD for various faults and 67013 also there on exam that 67027 from Colas is back on hire to act as the Rescue and recovery loco.
67010 is due back to go onto HD04 to keep 4 takes in service tomorrow.
Philip
27 May 2007
Manchester
Are there any plans for using a set on a Manchester-North Wales diagram, once they start running to Bangor & Holyhead, instead of Llandudno?
BillStampy
6 Jan 2024
Llanharan
Hopefully it lasts tomorrow, after that all 7 sets are able to take a break and give time for exams and for the 67s to all be looked at, hopefully it'll last into next week. How is 029 doing?
sd0733
7 Nov 2012
Definitely, the poor performance/availability has gone for long enough, especially after the good month before.
029 is on newly overhauled bogies/wheelsets and is now receiving further attention to the engine.
BillStampy
6 Jan 2024
Llanharan
Good to see it has it's long awaited wheelset. Any clues to how long it'll still be out? I personally want to see her back out dragging some sets! :)
sd0733
7 Nov 2012
Not sure on that one I'm afraid. It's currently being worked on so hopefully won't be too much longer.
BillStampy
6 Jan 2024
Llanharan
Thanks as always, hoping for a quick return with the 67s in their current state...
Could I also have tomorrow's diagrams? Very helpful. Saw HD02 not too long ago. Might spot another tomorrow. Would be well appreciated.
sd0733
7 Nov 2012
Tomorrow should be:
67020+HD02 1W11 1V37 1W96
67015+HD03 1V91 1W57 1V46 1W65 1J76
67010+HD04 1V33 1W19 1V50
67014+HD07 1V31 1W55 1V42 1W23 1V66
67025+HD01 Major exam at Crewe
67008+HD05 Minor exam at Crewe
No 67 with HD06 at Canton
Tonight's move of 67017+67022 is planned overnight https://www.realtimetrains.co.uk/service/gb-nr:07421/2024-09-12/detailed
23 Nov 2015
Tomorrow should be:
67014+HD07 1V31 1W55 1V42 1W96
What I do not understand with this fleet is that even minor exams appear to be done in the daytime, rather than overnight like virtually every other fleet. Major exams are different of course.
