Euston to Glasgow needs to go half-hourly
amahy
9 Dec 2024
West Dunbartonshire
This certainly needs doing. There should be a requirement that any train operating on the ECML, WCML, GWML etc should be able to maintain linespeed or its own locomotive/stock's maximum speed (whichever is lower, obviously) throughout its journey aside from where signalling or other safety matters would not permit that. The waste of paths on the north WCML that exists just because freight operators can't be bothered to haul their trains with sufficient power because it might cost them money is nothing short of a disgrace. It is, in effect, subsidising private pockets at the expense of the passenger service.
I agree with this. The number of times I go past a freight TOC’s depot and it’s full of trains doing nothing, yet passenger TOCs are forced to ration rolling stock to the bare minimum. If freight TOCs are going to have a surplus of locomotives, at least use them to accelerate freight services to avoid taking up multiple passenger train paths!
35B
19 Dec 2011
Might that be a matter of when "peak" running is? I could draw the same conclusion going past a depot off peak, or at the weekend, for a passenger operator.
That's without wondering what good bunging another 66 on the front of a freight over Shap would actually do for the journey times - or the economics of the working in the first place.
Nottingham59
10 Dec 2019
When I looked at what traction was being used over Shap, I was surprised by how much freight already uses electric traction (88, 2x90 etc.) Most 66 hauled trains seem to pass late evening or overnight.
An extra Euston-Scotland means 4tph north of Preston.
How will this work with the current flighting policy?
Currently the fast Glasgow goes first from Preston, then the Birmingham and lastly the TPE, with slightly different stopping patterns.
The Birmingham and TPE go alternately to Glasgow and Edinburgh, giving 2tph to Glasgow and 1tph to Edinburgh.
It would appear Edinburgh needs a bigger capacity increase than Glasgow.
You surely wouldn't want 3tph to Glasgow, all leaving within 20 minutes of each other (leaving the rest for freight and some local Northern services).
Network Rail has previously said it can't manage more than the present 3tph.
There's ETCS coming, of course.
amahy
9 Dec 2024
West Dunbartonshire
Until fairly recently, I passed Newton Heath TMD pretty much every day at varying times (and had done for several years) - the depot was always empty, off peak or peak times, yet services were still short formed. Compare that with DRS Crewe, there has never been an occasion I've passed there and seen less than 10 class 68s doing nothing lined up next the mainline!
Freight TOCs shouldn't be running diesel locomotives over Shap, as the line is fully electrified. The only train that needs to be diesel hauled is the Hardendale Quarry run.
5tph in the hours where there is a service from Liverpool to Glasgow, although I guess that would have to give way. That would be getting to the levels of duplication once seen between York and Newcastle.
Sorcerer
20 May 2022
Do freight/diesel locos also not have lower speed limits on Shap Summit compared to electric and multiple units? Or have I mixed that up with something else? If it is the case though than that kind of difference in speed limit uses up capacity on the route as well which could play a part in limiting the number of services over the WCML north of Lancaster. Even fixing that though there is capacity restraints at Glasgow Central to deal with as well.
cle
17 Nov 2010
Could that go hourly, instead of a freight path? Or if that was possible, would the path be better used from somewhere else?
It at least would cover connectivity from Wigan and north - and might enable some other services to speed up (like the Euston-Brum-Scot) ?
MatthewHutton
17 Aug 2024
Oxford
You run the services out of London as a flighted pair, then you stop the slower one at Milton Keynes, Warrington Bank Quay and Wigan and slot the Manchester train in the gap between the two London services at Preston.
The Birmingham one can then follow the slower London service with the Liverpool one going in the gap between that and the slower London service caused by stops at Stafford and Crewe. Then the slower London and Manchester trains make all stops north of Preston except Lockabie with perhaps the Birmingham and Liverpool ones providing service there.
Is that not enough?
You basically have to do this. Edinburgh has two trains arriving from london very close together.
lrbvoyager
2 Jan 2025
I would have thought Avanti needs to up Edinburgh services to 2tph as they are almost always packed. Recently mine was cancelled and I had 2 hours to wait for the next one in Edinburgh and it was utter chaos. Maybe an every 2 hours service from Chester-Edinburgh? Issue with that being there isn’t enough 805s spare. As someone has already said extending the 397s to 7 coaches would help ease pressure. You would need to reconfigure the interior to have more airlines seats and maybe a shop?
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
2 trains per hour instead of the current 1 every 2 hours? Slight overkill I would have thought! If one is cancelled is there no provision to join a Glasgow originator, either by Scotrail via Glasgow or TPE via Carlisle, rather than wait two hours?
Anyone travelling from Edinburgh to London on Avanti is doing so because they've been priced onto that service given that it is something in the order of two hours slower. Adjusting fares would presumably fairly easily resolve any overcrowding issue fairly easily. Obviously two trains into one doesn't go so cancellations will always result in overcrowding. Obviously there's intermediate demand, but that should really fit into an 11 car Pendolino fine.
lrbvoyager
2 Jan 2025
Sorry I meant 2 trains in 2 hours so 1tph, my bad!! Like one at 12:00 from Euston to Edinburgh then one at 13:00 from Chester to Edinburgh then 14:00 Euston to Edinburgh if you get what I mean?
NCT
18 Apr 2025
Surely the most logical thing to do is to lengthen the Manchester Airport - Scotland service?
amahy
9 Dec 2024
West Dunbartonshire
Could a potential solution to the Edinburgh problem to have standardised Manchester/London to Scotland pairings? So instead of London - Birmingham - Scotland and Manchester - Scotland alternating between going to Edinburgh and Glasgow, you could have the following:
1 tph London to Glasgow fast (as currently)
1 tph London to Edinburgh via Birmingham
1 tph Manchester to Glasgow
This way, the Edinburgh service is always at least 9 coaches, avoiding the crush loading onto a 5 car TPE when the previous Edinburgh train is cancelled. Although I'm not sure Manchester would be happy losing their direct Edinburgh service, nor would the Midlands be happy about losing their direct Glasgow service.
AndrewE
9 Nov 2015
the trouble is that this option does nothing at all to enhance the capacity or timetable options northbound from Crewe or Warrington, Crewe being (ironically) the worst-served WCML node on this route!
The elephant in the room (or you could say the gap in the timetable) is not that Euston needs 2 trains an hour to Glasgow but that the trains via Brum are overcrowded due to cheap fares all the way to Scotland being offered on these slow trains, when the capacity is most needed London to Wolves and Brum to Scotland.
By all means run the recent extra Euston - Blackpool trains via the Trent Valley to Scotland instead, but make them serve Crewe and relieve the current Edinburgh trains by going on to there too!
cle
17 Nov 2010
I would say that if we had to fix the services, Birmingham also has Edinburgh via York.
But eventually HS2 will need Edinburgh from Euston again.
And therefore, all Manchester goes to Edinburgh? And Liverpool-Glasgow increases towards hourly?
I recall a splitting plan for that Liverpool service once upon a time - which could be a faff but cover Manchester - Glasgow off.
Extras to Blackpool/Lancaster - would these compete with additional Liverpool services?
lrbvoyager
2 Jan 2025
This is just a suggestion but you could have as follows:
Glasgow-Euston (fast) 1tph
Carlisle
Preston
Crewe
Euston
Glasgow-Euston (Semi-Fast) 1tph
Motherwell
Carlisle
Penrith North Lakes
Oxenholme Lake District
Lancaster
Preston
Wigan North Western
Milton Keynes Central
Euston
Glasgow-Euston (Via Birmingham) 1tp2h
Motherwell
Carlisle
Penrith North Lakes
Lancaster
Preston
Wigan North Western
Crewe
Stafford
Wolverhampton
Sandwell & Dudley
Birmingham New Street
Birmingham International
Coventry
Milton Keynes
Euston
Edinburgh-Euston (Via Birmingham) 1tp2h
Edinburgh
Haymarket
Carlisle
Penrith North Lakes
Lancaster
Preston
Wigan North Western
Crewe
Stafford
Wolverhampton
Sandwell & Dudley
Coventry
Milton Keynes
Euston
Edinburgh-Chester 1tp2h
Edinburgh
Haymarket
Carlsile
Penrith North Lakes
Lancaster
Preston
Wigan North Western
Chester
Glasgow-Manchester Airport 1tph
Motherwell
Lockerbie
Carlisle
Penrith North Lakes
Lancaster
Preston
Bolton
Manchester Oxford Road
Manchester Piccadilly
Manchester Airport
Glasgow-Liverpool Lime Street 1tp4h
Carlisle
Penrith North Lakes
Lancatser
Preston
Wigan North Western
St Helens Central
Edinburgh-Manchester Airport 1tp2h
Edinburgh
Haymarket
Lockerbie
Carlisle
Penrith North Lakes
Lancatser
Preston
Bolton
Manchester Airport
Edinburgh-Liverpool Liverpool Lime Street 1tp4h
Edinbrugh
Haymarket
Carlisle
Penrith North Lakes
Lancatser
Preston
Wigan North Western
St Helens Central
This might be very over kill! It’s just what I thought would work. Means not always stopping.
NCT
18 Apr 2025
That's far too many services for the available infrastructure to handle.
Topological
20 Feb 2023
Swansea
IF you want more direct trains from Scotland for places like Chester and Liverpool then portion working with the Manchester is most likely to be the answer.
IF there is an available path then probably the additional London is the best use (as per the thread title)
However, the fast should not serve Crewe. Platforms at Crewe can create delays and Crewe would have the semi-fast to Glasgow with very little time differential compared to the fast (and likley with more space/lower fares)
Sorcerer
20 May 2022
Carlisle
Preston
Crewe
Euston
Motherwell
Carlisle
Penrith North Lakes
Lancaster
Preston
Wigan North Western
Euston
Picking up on these two specifically. If we assume the timetable and pathing permitted these services, I feel like the fast would be better off not calling at Crewe and instead simply running non-stop to Preston and calling only at Carlisle and quite possibly Lancaster afterwards. It'd be comparable to the fast Edinburgh on the ECML running non-stop to York and serving only Darlington, Newcastle and Berwick-Upon-Tweed, and from the new winter timetable will call only at York and Newcastle.
It would, but the passenger flows for Preston, Carlisle and Glasgow, and the number of paths available, don't easily support such a service missing out the other stops.
Sorcerer
20 May 2022
Certainly not if the service was hourly, hence why I was operating on the assumption that we were able to get both a fast and a semi-fast as is currently the case with LNER Edinburgh trains. I remember the 16:30 calling only at Preston being scrapped because the following 16:33 to Preston was so packed even if it was still a shorter formation. Indeed if this hypothetical semi-fast terminated at Preston you'd have even more demand for the fast going further north.
Manutd1999
21 Feb 2021
How about this for a switch-around?
1) Merge the Manchester-Scotland with an existing XC Manchester service, but starting from Birmingham NS. This could be operated by Pendalinos to give a capacity boost to both Birmingham-Manchester and Manchester-Scotland, also releasing some much needed Voyagers to strengthen other XC services.
2) Switch the existing London-Birmingham-Scotland to run semi-fast via the Trent Valley. This could continue to alternate between Glasgow/Edinburgh to maintain existing connections but could be weighted more towards Glasgow if we think the demand is there (say 4tpd to Edinburgh, with the rest to Glasgow). Pathing up to Crewe may be challenging.....
3) The current Glasgow service can then run faster, skipping Warrington/Wigan/Penrith to take 10+ minutes off the headline journey times.
4) If needed, run an additional Birmingham-Preston stopper to maintain connectivity to Wigan/Warrington.
2) Switch the existing London-Birmingham-Scotland to run semi-fast via the Trent Valley. This could continue to alternate between Glasgow/Edinburgh, maintaining existing connections whilst reducing journey times into London. Pathing up to Crewe may be challenging.....
Just pass the existing Crewe service to the InterCity operator and link it to the existing Birmingham to Glasgow path from Crewe.
Do people from Birmingham really want the delay of having their Scottish connection going via Manchester? How much time does that add to the journey? It was bad enough in the CrossCountry days with that detour.
By my reckoning, 1-3 alone needs a net extra 10-11 Pendolinos, plus 1-2 more platforms at New St, none of which exist.
